Question about Sangean RCR-1 Clock Radio
The atomic clock aspect of our sangean rcr-1 alarm clock radio has broken. the dial simply spins and the time will not set.
4 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: manual for Sangean RCR-22 clock radio
You can get the manual on the link below.
http://www.thiecom.de/ftp/sangean/rcr22/rcr22-manual-e.pdf
Posted on Apr 28, 2010
Testimonial: "I know my clock radio is easy to set for time & stations but without my manual I was lost! Fixya got me a manual within a few hours."
jyackle5
  • 8197 Answers
SOURCE: Resetting am stations for Sangean rcr 1 clock
You can get the manual on the link below it will tell you how to reset the stations.
RCR
-1-Atomic-Clock-Manual.pdf">http://igor.chudov.com/manuals/Sangean-RCR-1-Atomic-Clock-Manual.pdf
Good Luck
Posted on Nov 29, 2010
  • 484 Answers
SOURCE: i do not know how
Alarm settings can be made with clock/radio on or off.
The Alarm Clock/Radio is equipped with two independent alarm
systems each of which can activate the Human Wake System Buzzer
or turn on a preselected radio station.
Using Alarm with a Preselected Radio Station:
Select desired station using + or - Tuning Button [18] or select one
of the 1-7 presets.
Set the desired volume level using Alarm Level Adjustment [9]
Select alarm system 1 or 2 by pressing the alarm button [14] or [15].
Display will blink with selected alarm
Press alarm set button [16]
Display will blink showing selected alarm hour and alarm mode
and beep
Press alarm Mode button [20] to select alarm mode
Use + or - button [18] to set alarm time hours.
Press set button [16] to set minutes using + or - button to
set minutes.
Press alarm days selections 1-7 (Sunday-Saturday) to select
alarm days.
Display will show the days on which you wish to be awoken by the
radio alarm.
Pressing alarm button 1 or 2 will confirm settings and a beep and
display indicates radio alarm is set.
Note:
If alarm days or alarm mode are not selected display will blink
all the days for a few seconds indicating the alarm is not set
and the alarm will not be activated.
If you would like to be awoken to the station you are presently
listening to press alarm button 1 or 2 for more then 2 seconds.
This allows the station you are listening to be stored into
memory. Then follow above procedures.
Using Alarm with HWS Alarm Beep:
Display will blink with selected alarm Press alarm set button [16]
and beep
set minutes
alarm days.
buzzer humane alarm
display indicates buzzer humane alarm is set.
Note:
Cancelling Alarm Setting:
Alarm functions can be cancelled:
and beep
Press alarm Mode button [20] one or two times (depending if you
were in the alarm radio or alarm buzzer mode) till display blinks.
Press alarm 1 or 2 button again to confirm alarm cancellation.
The symbol will stay on the display for about 2 seconds
and disappear.
You may also select days you wish to be or not to be woken after
pressing the Set button while display is blinking. Press 1-7
(Sunday-Saturday) of button [19] to make a selection.
This is the figure of your device and you can find which button where is:
Thanks.
gylacz
Posted on Jun 10, 2011
The atomic clock on my Sangean RCR-2 has not set after 2 days.
I think the white cord is the fm antenna. The gray one with the thick end is the am antenna. The frequency used to contact the atomic clock signal uses the am antenna.
Dec 26, 2012 | Sangean RCR-22 Clock Radio
After setting the time manually on my rcr-22, the next morning radio's time is 3 hours behind what it should be.
Underneath make sure the switch is set to your time zone. Also check the day light savings setting.
Jul 08, 2011 | Sangean RCR-22 Clock Radio
I do not know how to set the alarm for my Sangean RCR-1 alarm clock.
of the 1-7 presets.
and beep
set minutes.
alarm days.
radio alarm.
Note:
and beep
set minutes
alarm days.
buzzer humane alarm
Note:
and beep
and disappear.
Thanks.
gylacz
Jun 10, 2011 | Sangean RCR-1 Clock Radio
I got a new Sangean clock radio R22. Te atomic clock doesn't pick up the time and I can't get it to set manually either. It reads ony L 0 on the right side. I have the part that receives set in a window....
I just had the same problem which you find posted here on FixYa.com. The problem solved itself overnight for me. I left the RCR-22 unit plugged in and searching for the signal when I woke up the next morning the time was set and the Atomic signal indicator was solid instead of flashing. It has kept perfect time since then. My only issue is that setting the alarm clock-radio is complicated.
Robert Hovestadt
Dec 30, 2010 | Sangean RCR-22 Clock Radio
Sangean RCR-1 Clock Radio Logo
Top Sangean Audio Players & Recorders Experts
Gyula Lacz
Are you a Sangean Audio Player and Recorder Expert? Answer questions, earn points and help others
