Question about Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out, Center Discharge, 240V, w/Hair & Lint Pot
I have a sta -rite valve and the handle does not turn. What could be the problem?
  • 310 Answers
If I can assume that you are speaking about a sta-rite multi-port valve it is one or all of the following.
1. The silicone disk underneath the handle is worn (this is what makes the handle glide when trying to turn it)
2. The spider gasket inside the valve is worn and sticking.
3. The handle spring is rusted and catching on the valve body.
Solution: Replace spring, silicon disk and spider gasket.
Posted on Nov 10, 2010
How to prime sta rite pool filters
put water in pump basket and turn on after opening valve 1 at a time
Nov 03, 2013 | Sta Rite StaRite DuraGlas Pump 34 HP...
Just replaced circuit board on my sta rite 333 nothing happens and it reads E-06. What does this mean?
check gas is on if ignitor lights no gas valve see if voltage to gas valve if ok bad gas valve if no voltage bad board or safety circuit
Oct 31, 2013 | Sta Rite 333 Btu Natural Gas Heater...
My sta-rite pump leaks out the backwash port looking for a rebuild kit
If you remove the bolts around the top the handle and lid assembly will pull out. Under that is a spider gasket that needs to be replaced. Clean out and dry the slots where the spokes of the gasket go, and replace with a new gasket using contact adhesive or vinyl adhesive to glue the gasket in. Do not put anything on the top of the gasket.
It's a good idea to replace the diverter o ring and bearing while you have it open. This requires removing the handle from the diverter. The o ring is on the diverter shaft, the bearing is the white plastic ring that goes between the lid and the handle. After that the backwash valve will work like new.
Mar 26, 2013 | Sta Rite Sta Rite Above Ground Sand...
How to clean out filter
Shut off power,
Move Filter Valve Handle to the backwash position
Turn on Filter
Let filter run until the water is clear.
Turn back off and move the handle back to the filter position.
TIP: Replace your sand every two years!
For more info, go to:
http://www.oskopoolnspa.com
Sep 16, 2012 | Sta Rite StaRite Aboveground Pool Sand...
Missing filter ring
First, let me inform you that if you contact Pentair, either through email or phone, and let them know that you can not read the valve label on your filter, they will send you one through the mail.
One thing that helped me remember the position of the valve handle was that the WASTE position is always located over the Waste Port on the filter. If you know where the FILTER position is, stand by the filter so that FILTER would be at the top, or the "12 o'clock" position. Now, going to the right, clockwise, the positions are as follows: FILTER, RINSE, RECIRCULATE, BACKWASH, CLOSED, WINTERIZED, WASTE.
To change the position of the handle, you will need to stop your pump, push down on the handle-lifting up the pointed end- spin the handle so that the pointed end will sit pointing toward the position you want.
If you do no have an Owner's Manual, you can find one online at the following link:
http://www.pentairpool.com/pdfs/Cristal-FloOM.pdf
Jul 01, 2009 | Sta Rite Sta - Rite Mod Media 450 Sq Ft...
Pump runs continuously with not water
replace the pressure guage.
prime the pump by pouring in water in the impeller basket area and replace lid-try running pump again
Mar 22, 2009 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out, Center Discharge, 240V, w/Hair & Lint Pot Logo
108 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
Oloyede Monsuru
john h
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
