Question about MagLite Mag-Lite& Flashlight
I have changed batteries, bulbs done everythiing I know of. Maybe in the Switch??????????????? It is a 2 D cell flashlight. fairly new
    Genius:
  • 1,015 Answers
I have several maglites and have used them for years. The first thing I would make sure of is that the bulb you replaced was the right one for 2 D-cell flashlights, specifically for maglites. Other bulbs won't work properly. Next I would make sure all contact points for batteries are clean. The ones you can reach on batteries,base of bulb and base cap for light can be cleaned with fine grade sand paper, emery board or steel wool. On the contact bar that runs the length of inner tube you can check where switch makes contact. If corrosion is evident you can lightly scrape with long blade screwdriver or other tool or knife. I have rarely had a bulb burn out immediatly after installation. I would check bulb again and then make sure that end cap and top assembly are threaded in place. Also try rotating beam adjusting setting back and forth several times. I'm sure it could be the switch I've just never had that problem. Hope this helps. thanks
Posted on Nov 10, 2010
I cannot get the one d cell battery left out of my 5 d cell mag flashlite I've done everything with no luck I don't want to destroy it with my frustration can someone help me please
Remove the lens end of the flashlight. Remove bulb. At the switch there is a small screw that should release the socket for the bulb and what ever else is left in the tube. If battery still stuck should be able to push it on through with what ever you have that will fit in the tube,.
Feb 06, 2016 | Camping, Backpacking & Hiking
Tip
Flashlight Battery and Bulb Installation and...
FLASHLIGHT
BATTERY INSTALLATION FOR TORCH:
Open the Torch Battery Door located on the bottom of the Torch.
Insert 4 “A A” (1 .5V UM-3) (not included) batteries (alkaline
batteries are recommended) into the torch compartment. Be sure
the polarity (+ and
-) matches, as marked inside the battery
compartment.
FLASHLIGHT:
Slide the Torch Function Switch to the “FLASH” position, the Torch will light. To turn off, slide the Torch Function Switch to the “OFF’ position.
FLASH/BLINK FUNCTION:
Slide the Torch Function Switch to “FLASH/BLINK” position, tha Torch will light and thc bulbs on both sides of Torch will blink.
BULB REPLACEMENT:
Rotate the Torch Cover anticlockwise to hear “click”
then p
ull out the cover, remove the old bulb. Then pull
out the torch cup, remove the blinker’s
old bulbs and
reinstall new bulbs. Replace the torch cup, then reinstall
on Mar 05, 2009 | Jeep KNG36-JXLWBC AM/FM/Weather Radio
How do I replace the led in a 2w d cell maglite
Unscrew the top half of the flash light and pull the bulb straight up, and it's out,
Not to mention there's usually a spare bulb in the base of the flashlight under the spring in a piece of foam. unless someone used it already,
Line up the two pins and slide it back into the to pin holes on top and with the bottom of the flashlight back on with battery's try the on off switch and make sure it lights up and not have dead battery's, if it lights up throw away the old led and screw on the top of flashlight,
If it still don't light check for new battery's.
Oct 03, 2014 | MagLite Mag Instrument Mag Lite 2 "D"...
Keeps blowing new bulbs
Since this is a simple construction flash light (no electronics) make sure you are installing the correct bulb for the voltage of the batteries.
If you use a bulb that is for a 2 cell (3.0 volt) in a flashlight that takes 4 cells (6.0 volt) the bulb will burn out every time.
Oct 15, 2010 | MagLite Camping, Backpacking & Hiking
My son dropped the flashlight acouple times and now it wont work
Either the bulb is burn or just faulty or the switch is bad.
Jul 16, 2010 | Surefire 6P BK 6P Original Personal...
I had to change the battery 2 D and now it doesn't work. I have never had one work after I change the batterys what am I doing wrong?
Unless the bulb is burned out or you are putting the batteries in wrong there is not much that can go wrong with a flashlight.
Jan 22, 2010 | MagLite Mag Instrument Mag Lite 2 "D"...
Area light works but not the spotlight
Check the contacts going to the batteries. The negative contact is
going the flashlight body. While the other starts at the center of the
bulb socket that goes to the switch and finally to the positive terminal
of the battery. Get it done and send an e-mail .
Oct 03, 2009 | Vector Camping, Backpacking & Hiking
Have put new batteries in bulb is ok just stopped workin 5 cell dd batts
First of all are you certain the bulb is ok? Test for continuity across the light bulb. The filament in light bulb will have a very low resistance. if you are not handy with a multimeter then respond back with a new thread and I can give you more tips on using a multimeter.
Next, clean the contact surfaces off where the battery terminals contact the flashlight copper contacts. You can use a high grit sand paper if necessary. They sell battery terminal cleaner solutions/supplies at Automotive stores if you like. However, distilled water and/or alcohol will probably work just as good.
Next connecting one probe of your multimeter to the top inner contact and then the other probe of your multimeter to the lower inner contact turn off and on the switch. When the switch is on, you should see the same resistance that you checked the resistance of the light bulb filament.
If you don't see the same resistance then switch is bad.
If resistances are equal then place batteries back in flash light and everything should be good to go!
Aug 04, 2009 | MagLite Flashlight Type: Black D Cell 5:...
How do you change the bulb in a minimaglite
1. Unscrew the "bell" (top) of the flashlite. 2. Remove the bulb by pulling upward. 3. Replace with new bulb (be sure you have the correct bulb . . . it will have two small wires protruding from the bottom). 4. CAREFULLY insert new bulb through hole in the bottom of the reflector. 5. Screw the top of the flashlight back on.
Oct 22, 2008 | MagLite Camping, Backpacking & Hiking
MagLite Mag-Lite& Flashlight Logo
156 people viewed this question
Top MagLite Electrical Supplies Experts
ken skalski
Karl Kittsteiner
ray gallant
Are you a MagLite Electrical Supply Expert? Answer questions, earn points and help others
