Question about Frymaster Dean Kitchen Appliances - Others
Our Frymaster won`t stay lit, fires up then after a few minutes goes out & sometimes it won`t fire up at all. It`s a Mod # M J 3550 Thank`s V F W post# 3863 maintenance man Pete Heid
  • 848 Answers
SOURCE: amana gas dryer
check the thermal fuse ........
Posted on Aug 28, 2008
  • 24 Answers
SOURCE: pilot light won't stay lit.
most common cause of the described symptom overheating the thermocouple! a thermocouple produces millivolts of electricity based upon a differential of temperature between the tip and the base. If it gets too hot it will not work correctly. If the pilot flame is too large or the main burner flame is contacting the thermocouple or the thermocouple is too cheap or old all can cause this issue.
Posted on Dec 18, 2008
  • 11 Answers
SOURCE: HI showing on digital display frialator 14ss/chhov
When high is displayed it means that the probe and controller is reading that your oil temp is 30 degrees over your set temp. Use an external probe, locate it about one inch above your probe in the tank check actual temp and compare to your set temp. If you find that it is not 30 degrees over than there may be a problem with your probe, wiring or the digital controller. With a multi meter you can check your probe resitance it should be at 942 ohms at 350 degrees.
Posted on Feb 02, 2009
  • 2463 Answers
SOURCE: Dyna-glo parts
thermocouples you can buy from any heating spares oulet or national energy a hone well is most common for useing as a replacement
Posted on Feb 07, 2009
TheMobilian
  • 8220 Answers
SOURCE: Won't stay lit
You ignitor is working and sensor is working because it will fire up. so those pesky coils are intermittant because they get hot and quit cool off and work some more . replace them
cc8e664.jpgHere is a little ditty I wrote some time ago about this subject
INTERMITTANT COILS
Posted on Mar 07, 2009
Gas fire wont stay lit
The thermostat probably reached the set temp, but maybe the pilot lite blew out. Or the control needs to be replaced.
Nov 25, 2013 | Kitchen Appliances - Others
Jandy lite 2 pool heater will not stay lit.
I'm having the same issue as the above user with Jandy Lite 2 (which from what I can tell stands for the number of times that you can get this POS to work annually)!
The unit LIGHTS OFF, but WON'T STAY LIT! Igniter engages, gas valve opens, unit lights, burns for 10 seconds, and flames out. Error code FL 2, after third attempt, already replaced the flame sensor....
May 12, 2013 | Pool & Spa
Pilot will light and stay lit for 1 to 2 mins. Logs lit once but only for about 30 secs. There is NO gas flow after the fire goes out. If you wait a few minutes there is enough gas to repeat this same...
this is closely guarded secret. get a can of air for dusting computers and lightly blow dust out of piolit assembly.I've made allot of money doing this.merry xmass.if this doesn't work then you probbaly need a new part.or if piolit is too small it might need cleaning.
Dec 24, 2010 | Heating & Cooling
Grill's fire won't stay lit
Try banging on the tubes feeding the burners with a heavy pair of vice grips or a hammer. It usually shakes the carbon loose to allow for free flow of gas.
Aug 09, 2009 | Grilling
Maytag dryer dg712 does not stay lit
Yeah change the coils read my page on intermittant coils HERE
Apr 12, 2009 | Dryers
Dyna-glo parts
Feb 03, 2009 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Open Questions:
Kitchen Appliances - Others Logo
51 people viewed this question
Top Frymaster Dean Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
starztruck4u
Dan Webster
Dan Webster
Are you a Frymaster Dean Kitchen Appliances - Other Expert? Answer questions, earn points and help others
