Question about Sony KP-41T65 41" Rear Projection Television
No pictue, no sound, is plugged in. Last thing seen was circle wth red, green, blue that reduced to a dot and was gone. how can i fix this. are there parts available?
Red standby light blinking
Posted on Mar 27, 2011
The picture is green ?
The screen colors are all derived from three distinct colors. Red, Blue and Green. The colors can change due to a few problems. The purity or converge could have been disturbed due to magnetic interference, one or two of the color amplifiers have stopped working or the picture tube has failed. Color problems can be as easy as circling a high magnetic field coil in front of the set, known as 'degaussing' or extremely technical, frustrating and then hence expensive. Not much help, I know, but good luck.
Jul 13, 2014 | ESA ET427E 27" TV
Dvd player connected to panasonic viera. picture has blue skin tones and picture isn't centered
I always try the simple things first. check the connection. if hdmi .. then try a differnt cable.
It almost sounds as if one of your connections is plugged in the wrong place.
On component.. red to red, green to green and blue to blue .. then the extra red and white go to the video part .. also may want to check the tv manual - sometimes they share those connections with regular rca connection and easy to plug in wrong place.
Rca connetions - Yellow is video - red and white audio.
S video - one big plug and then red and white audio - make sure the big plug is fully in on both devices - I've seen similar things with s-video plug not fully connected on one end or the other.
Good Luck,
Bill.
Nov 29, 2010 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Why got green dots / image seen on screen?
Those green dots are dead or "tired" pixels. The only thing you can try to fix this, is doing a pixel massage. Grab a pen and put some sort of towel over it and make a circling move over the pixel.
If it won't work the only thing you can do is get used to it that you have a dead pixel. ( i also have one. Very annoing)
May 21, 2010 | Philips 42FD9932 42 in. Plasma Television
I think the video cable for my xbox is messed up. Why does it keep showing up these little circle things? Whenever I turn on my xbox it doesn't come up anything but a black screen with little circles...
NOT HD: Make sure red goes to red, white on white, and yellow on yellow, also make sure the switch that is on the xbox wire plug says TV not HD.
HD TV: Make sure red on red, white on white, yellow on yellow, blue on blue, green on green, etc. Also make sure the switch that is on the xbox wire plug says HD not TC
Oct 18, 2009 | Microsoft Xbox 360 Console
60 in sony grand wega
if it turns to red most likely you need to replace the bulb.
Larry D
Aug 15, 2009 | Televison & Video
Picture is fine, but the sound won't work
Are the yellow, red & white cables RCA phono plugs?
Yellow = Video
Red = Right Audio
White = Left Audio (mono)
The red, blue & green cables are for picture only and don't include sound. Have you tried using the red, blue & green for the picture and using the other cable, red & white for just the sound? Don't use the yellow.
- Jim
Feb 10, 2008 | Sanyo HT32744 32" TV
Samsung Plasma TV
from the model number you have a 42" set,,the v_set and v_scan voltages need to be set 15vdc lower..this should take care of it,,if not then the plasma panel is bad
Nov 08, 2007 | Samsung HP-R4262 42 in. Plasma Television
Tv with power but no picture or sound...
you have no deflection and don't leave the dot on to long it will burn the crt's.
Aug 11, 2007 | Mitsubishi VS-5043/44 50" Rear Projection...
No red
There're video guns. Red, Blue, and Green. Sounds like they maybe going bad and need replacing. The red is already going out. Could be about $200 or more to fix.
Jun 24, 2007 | Toshiba 36A42 36" TV
RCA 25: television
Sounds to me like a bad picture tube with circle rainbow like colors.Good luck.
Sep 03, 2006 | RCA F25423 25" TV
Sony KP-41T65 41" Rear Projection Television Logo
16 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
