Question about Nokia N91 Cellular Phone
N91 8gb nokia only white screen
I have n91 8 gb which has no display from 4 or five days . its sow only white screen and all fuction is ok such as ridio , incoming call and outgoing call , one i stay my mobile in front of cooler but after that it accure a problem of no display . it only white screen. so plz help me.
  • 2 more comments
  • Anonymous Jun 30, 2008
    same problem with nokia 6630
  • Anonymous Feb 07, 2009
    same here
  • faisalconnec Feb 17, 2009
    white light. no blinking
  • Anonymous Mar 29, 2009
    Nokia N91 4GB just decided to slowley go white. at first it was not so apparent then after a couple days it was permanantly white screen. Worked fine with white screen, played music, camera, but could not see display. ???? What should one do? what is te problem? someone said it was software and the "operating system ???" needs to be reloaded onto the N91.. how? via pc suite?? links and names of software would help..
Vhite screen, hang,n91?
Posted on Oct 13, 2008
Sir i have the problem of hard drive not available what can i do
Posted on Nov 25, 2009
Where is sync?
Pairing a Nokia Lumia 520 to a 2013 Ford Escape
1. To Find "Bluetooth" on the Nokia Lumia 520
  • Slide your finger left on the display.
  • Press Settings.
  • Press Bluetooth.
2. Turn on Bluetooth
  • Press the indicator next to "Status" to turn on Bluetooth.
3. Pair a Bluetooth device with your phone
  • Make sure the vehicle (parked in a driveway) is turned on and engine running. Go tot he Phone Menu, System Settings, Add Bluetooth Device, Push OK, The Sync System will display a 6-digit PIN number. Use the Seek Arrows to change to Special PIN (the system will display 0000), Push OK.
  • Your phone now searches for devices and after a moment, a list of Bluetooth devices within range is displayed.
  • Press the required Bluetooth device (the tab should say Sync).
  • Follow the instructions on the display to pair the Bluetooth device with your phone. Enter the 4-digit PIN
  • The new device is displayed on the list of paired devices.
  • Press OK on the console screen to set as Primary Phone, set 911 Assist and Download Phonebook. Be sure to check your phone screen and check "Always Connect" and Yes to approve the phonebook download. Be sure to check to see is there is also a request to Always Connect for SMS (texting) alerts.
4. Return to the home screen
  • Press the Home key to return to the home screen.
Your phone should now be paired the Sync system. Use the Voice button on the steering wheel to start the process (say "Phone"). Use the Phone icon to answer (a quick push) or hang up (push and hold down for about five seconds).
For more info www.fordtechlane.com Ford Tech Lane Driving you on the fastlane of vehicle technology
Mar 05, 2014 | Nokia Lumia 520 Smartphone - Wireless LAN...
My nokia 5230 sowing memory delet some data,i use *#7370# formula but require code, bt showing code error and default code 12345 is not machting.pls help me Thank u
Ok you can generate the code by using this software.
1. Downoad [ANT] Simple Ant Simple.zip
2. If you have Nokia PC Suite running, be sure to close it by exiting from the taskbar icon.
3. Extract [ANT] Simple ] and run Simple.exe located in the folder
4. Connect the phone via USB to the computer by selecting Pc suit/Ovi suit when prompt a message in your pone.
5.After you've connected your phone, Click "Read Info"
6. On the MAIN tab, click on GET. Your phone IMEI number and model should be displayed on the bottom panel.
7. Now click on the SERVICE tab and click on GET button under USER CODE
8. Your security code should now be displayed on the right side of the application window.
For details How to Generate Your Phone Security code..Only for Nokia bb5
Thanks For visiting Fixya
Sep 15, 2011 | Nokia 5230 Cell Phone
A few days ago noticed my C7 was dark at top of the screen like a shadow. Touch screen works fine. Several days later the shadow has slowly spread down the display leaving the top third of the screen...
Sometimes when we are wearing tight clothes and put mobile phones in the pocket, the screen gets pressed against coins or keys in the pocket. This damages the screen. I think this is the case with you. Now, the only solution remaining is replacing the LCD.
Sep 11, 2011 | Nokia C7 (8 GB) Smartphone
My Nokia phone is display is white so i havenot see my display
my n72 disply when on mobile its comes nokia but start up white display comes
Mar 25, 2009 | Nokia N72 Cellular Phone
Dell xps,no video output and it sows only white backgrounds
hi good day,
on this situation the best way you need to do is to reformat and reprogram the laptop...
Feb 15, 2009 | Dell XPS M1530 Notebook
I m having display problem.
Your display circuit is broken, even if the LCD-panel,
seems to be ok the display is damaged.
This is a very common problem in Nokia phones.
The only way to fix this is to change the display.
You need a T-6 Torx Skrewdriver to do the job.
You can find displays for fair price at :
www.mytrendyphone.com
This is your solution! Please vote!
Jan 29, 2009 | Nokia N72 Cellular Phone
Nokia n95 8gb
i think after all that you should replaced the mainboard
Oct 20, 2008 | Nokia N95 Cellular Phone
Display problem
i also have the same problem...white screen display
May 26, 2008 | Nokia N70 Cellular Phone
Nokia N91 Cellular Phone Logo
814 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
