Question about Electrolux Guardian Bagged Canister Vacuum
I have a Guardian that we purchased maybe 10 years ago. The swivel joint connecting to the brush head has worn and the brush does not operate unless you turn to extream angle. How do i resolve?
    Novelist:
  • 147 Answers
If this is the same one as what is pictured in the picture next to your description, then this is a common problem.
For starters you will want to disconnect the power brush from the wands or poles.
Look on the neck piece, towards the front of the neck, you are looking for either a screw, or a round cover. If its a round cover, you want to remove it to reveal the screw, and then remove the screw.
Once the over is off you should see 2 wires, brown and orange. They should both be connected to the pins for the electrical connection on the power head.
What I suspect here is that the wires are 1) off 2) broken. If they are off, just replace it onto the pins and your good to go. If the wires are broken, you will have to fix those wires. Fixing the wires is not so bad, you do have to make sure there is no exposed wire when your done, however, soldering them and taping them is not uncommon.
Good luck,
Mark
Posted on Nov 10, 2010
Canister vacuum
Without the make or model... We are speaking in GROSS GENERALITIES... but
ELECTRICAL Trouble...
The light & the BRUSH not working ... when considered TOGETHER.. would indicate a NEED to check your electrical connections...
My best advise would be to:
make sure the cords & wands are fully connected
make sure the (HEAD) motor is running ...
If the motor (brush head) is running... belt looks good and brush is not seized (or jammed)...
You will need to look to the DRIVE PULLEY on the motor OUT-PUT shaft...
Hope this helps
Jul 25, 2016 | Vacuums
Body of sebo x4 automatic not rising or falling
This could be due to the brush roller being worn.
If the brush roller is worn, then the height sensor makes the vacuum head go down fully. There still isn't enough resistance to the brush, but there is nowhere else for the height adjustment to go, so it just stays there. If you look at the cleaning head from the side you should be able to see that it is fully down.
The brush roller light is supposed to come on, but in my experience, it might not.
Feb 28, 2016 | Sebo Automatic X4 9570AM White/Gray, 10...
Body not rising or falling
Turbine Head Brush Tool - Noisy
See if there is something wrapped around the brush area itself which could cause the noise
Jun 06, 2012 | Dyson Vacuums
The head on my guardian suddenly quit working while I was using it. The reset button seems stuck up. Are their any more reset buttons
No, that's the only one. Make sure there is nothing wrapped around the roller brush. If so, clear it. Try pressing the reset button, then start machine. If nothing, there's good possibility the switch is broken or worn out. I recommend taking to the nearest Aerus Electrolux store to allow the service tech to check it, and repair if necessary.
If you don't know where the nearest store is, follow instructions on following site.
You can also call and ask for someone to pick up the machine and take in. Just be sure to let them know you are absolutely NOT going to buy a new machine. Yours should have lots of years left in it, especially with some periodic cleaning and maintenance.
http://www.aerushome.com/storelocator/
Nov 04, 2010 | Electrolux Guardian Bagged Canister Vacuum
How do you access the belt on the electrolux guardian
Flip the power head upside down and look for 5 black screws recessed in the bottom of the head...2 mid way back and 3 along the brush area. Once removed the lid should lift off. Be careful not to disturb the wiring harness.
The brush roll has a pulley and bearing end. Both should be cleaned and any hair or thread removed. The motor screws will have tensioning positions for the new belt so leave enough slack so the new belt depresses slightly. You will find a replacement at vac shop or thru AERUS Electrolux dealers
Oct 20, 2009 | Electrolux Guardian Bagged Canister Vacuum
Just bought new power head electrolux guardian and
Did you get new wands with the power nozzel? The wires that power the nozzel run through the wands from the hose to the nozzel.The connectors at the end of the wires are fomous for getting too big and making a bad connection. This causes the on/off problem. This will only get worse if you continued use. The wires in the hose handle, the hose and the power nozzel elbow can all be changed out. You will not have to replace the hose handle or the wands unless the plactic has been burned. (A loose electrical connection causes heat). Take your hose,wands and nozzel to the shop for repair. Don't let the sales/service manager tell you that you need new parts until you can see the parts are bad. I think they saw you comming when they sold you the new nozzel.(just my opinion)
Oct 15, 2009 | Electrolux Guardian Bagged Canister Vacuum
Electrolux Renaissance power nozzle turning on and off, brass pins hot
The deal with the Renny is that it runs off of circuit boards. Usually the problem of the main motor shutting on and off is caused by one of the Triac boards located inside the canister. Another problem could be the thermostat wire located on the inside of your motor itself. It's almost never the thermostat, so the triac board is most likely the issue.
As far as your power nozzle goes, the head eminating from the swivel body is in most cases due to an older design of the power nozzle. I would suggest investing in a new elbow assembly that includes a new swivel body as well as newer style of wiring that is proved to reduce arcing and heat production within the power nozzle.
In some cases, fixing the power nozzle will fix the problems you are experienceing with the main motor as the arcing happening in the power nozzle can in fact turn off your machine. So investing in a new elbow assembly for your power nozzle could in fact solve the problem in its entirety.
Oct 26, 2008 | Electrolux Guardian Bagged Canister Vacuum
Electrolux Guardian Bagged Canister Vacuum Logo
57 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
