Question about Epson LX-300+ II Matrix Printer
Have an Epson LX-300+ II, installed on ASUS P5KPL-AM EPU Mboard running on Windows 7 OS, having printing error, won't print and it suddenly turn the icon of the printer at the Devices and Printers into with yellow warning sign. I try to connect this printer with same PC environment and same Mboard on the other workstation, this printer will work and print, but not in this PC i have. Would someone help me to solve this problem i have?
printech
  • 159 Answers
SOURCE: Epson LX-300+II, the font problem
yes you can change the font tray to print the printer internal setting tray that press and hold any key by tarn the printer off then on after you tarn the printer on release the key
Posted on Sep 06, 2008
kamal1984
  • 1383 Answers
SOURCE: i need a free download driver for my LX 300+II
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=75683&infoType=Downloads
downlaod from here.
Posted on Jul 06, 2009
jay767
  • 386 Answers
SOURCE: installing LX-300 + II without the CD installer
Hi Good day!! if yoiur using winxp OS it easy to install because it is already installed in your winxp all you need is to activate it. to do: connect your printer and then You need to go to Start, Printers & Faxes, click on Add a Printer and follow on screen instructions. Windows will not auto detect/install the LX3, you need to manually point to Windows the Manufacturer as Epson and select LX-300 and continue.
hope this solution will help you
Thank you for using FixYa
Don't forget to vote thanks!!!
Posted on Nov 20, 2010
SOURCE: need unidrv.hlp to install lx-300+II
Click here Click on above link and download driver and install. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Feb 15, 2011
SOURCE: hw to reset epson lx-300+II
one pin don't work
Posted on Apr 03, 2011
I can't Print from my Epson lx-300+II printer it gives communication error what to do now?
ensure that you have the correct driver installed for the printer
do it from online --select the printer make and model and select the right driver to download
Aug 18, 2015 | Epson Office Equipment & Supplies
Epson Status Monitor 3 : Epson LX-300+II ESC/P 'Communication Error' appears after printing successfully ?
Check all connections and make sure all devices are on. If the power was turned off during printing, cancel the print job. If the error does not clear, see your printer documentation.
Jan 28, 2011 | Epson LX-300+ II Matrix Printer
Setting custom size (tear off) paper
I have some problem, but now have solved
1. replace your original epson lx-300+II driver by IBM ProPrinter II from windows installation driver.
2. in control panel-->printer and fax-->choose IBM Proprinter II ---> click File-->server properties--> click form tab--> chek create new and fill new paper size and don't forget give a name (ex. 8.5x6)--> save form
3.In printer and faxs right click IBM Proprinter II-->choose properties--> click device setting tab --> change tractor feed, manual paper feed and upper paper tray feed to new name (8.5x6)
4. Good luck
Jun 18, 2009 | Epson LX-300+ II Matrix Printer
Poor print quality of pdf documents on Epson LX-300
PDFs are designed to print using Postscript language.
The problem will occur with any non-Postscript printer. You can get better results on Windows printers by clicking on the "Advanced' button in the Print dialogue window. Then check 'Print as Image'.
This has worked well for me.
Dec 10, 2008 | Epson LX-300+ II Matrix Printer
Sep 06, 2008 | Epson LX-300+ II Matrix Printer
Print output
I had the same problem when printing on Windows XP Pro or Vista Business OS while the prinout was fine using DOS or Linux environment. My problem was that every other line the fonts wiggle sidewards towards the right as if it were on italics.
To correct this, simply download the LX300-II ESC/P driver then update your printer driver by re-installing it using your device manager.
Apr 16, 2008 | Epson LX-300+ II Matrix Printer
Epson lx300+ii with serial port to fujitsu pc
use the com1, and use a baud rate like 9600, with 8 and 1 bit stop. dont. be sure that is in ESC/P or IBM as you requiered. if your software use directly the serial port, be sure that the bios set up is properly. i think that the lx300+ have less buffer than lx300+2
and if you use high speed, could loose info.
Jan 28, 2008 | Epson LX-300+ II Matrix Printer
Epson LX-300+ II Matrix Printer Logo
49 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
