Question about Whirlpool Duet GHW9150P Front Load Washer
I have an f35 flashing....none of the buttons will work...so i cant even turn it off....this has been happening frequently....i have been turning the breaker off and then back on for it to reset itself but its not really solving the problem....help!!
  • Whirlpool Master
  • 8,220 Answers
Remove the service panel and look for your tech sheetI have an f35 flashing....none of the buttons will - themobilian_62.jpgthemobilian_64.jpg
Posted on Nov 10, 2010
  • Dan Webster
    Dan Webster Nov 10, 2010
    On your tech sheet is a list of failure codes. Use the tech sheet to diagnose the F-35 problem. Check the lint buildup inside the clean out while you are at it. The 2 biggest problems associated with these machines is oversudsing and junk in the pump filter.
Bn59 00463 volume works nothing else cant turn on
Step 1: Remove the batteries
Step 2: Press the power button (red button) on the remote control 5 times.
Step 3: Replace the batteries and your remote should work fine.
Oct 20, 2009 | Samsung Televison & Video
The washer stops and flashes f35 and some times
F35
This typically indicates slow drain condition. Check for any clogs or kinks in the drain line. Also check that the pump is not clogged and that no pump impeller blades are missing/broken and that the impeller moves freely. Any broken/missing blades or if the impeller won't turn freely will indicate a faulty pump. Hard objects can sometimes make it to the pump and cause damage. Hope this helped and best wishes.
Good luck
Oct 05, 2009 | Kenmore Elite 45986 Front Load Washer
Turned off when i was looking at it
You need to replace the battery in this unit as its not putting out enough charge to power the unit even tho it says it charged.
hope this helps
Aug 22, 2009 | Creative Labs Zen Digital Media Player
Kenmore Elite HE5t Error Code F35
we have a kenmore HE2 Plus washer, front loader. been getting F28 code for last several months. usually we can push cancel button, and it clears, unlocks the door, we restart and complete the wash. But now it is locked and we can;t clear it. have even unplugged the machine over night, it still will not reset. any ideas?
May 09, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Washing clothes all day have an F35 flashing
F35
ANALOG PRESSURE SENSOR FAILURE
If this failure is displayed, there is any malfunction of the steamer
component detected by the Steamer Electronic Board.
Possible Causes/Procedure
1. Check if pressure hose is fixed correctly.
2. Check if the airtrap is not blocked.
3. Check if the hose is not blocked.
Check these problems.
Plesae leave a solved rating before you leave the site
Jan 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Keypad acting up!
SURGICAL - you need to replaced the mobile flexcable in the phone also have the repair center flash the keypad flexfile back into the phone.
BRENNA - replaced the flexcable
VGETSON - you need to flash a file call keypad flex into the phone to correct the keypad freezing up on you.
Sep 27, 2008 | Motorola Mobility RAZR V3
Ph will turn on but keypad won't work
You need to replace your keypad. Frequent use deteriorates the interfacing connections.
Sep 13, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Buttons on camera won't work.
I finally got the menu button to work by firmly pressing downward on the mode dial while turning it. Once the menu opened, I went to set-up and initialized all settings. This action reset all the settings to default and now all of the buttons are working.
Jul 15, 2008 | Sony Cyber-Shot DSC-W7 Digital Camera
The flash
You could try pressing the right button next to the zoom button, but usually when this happens, it is because the flash unit or transformer has died.
Bob
Jan 30, 2008 | Fuji FinePix A500 Digital Camera
Whirlpool Duet GHW9150P Front Load Washer Logo
26 people viewed this question
Dan Webster
Dan Webster
Sal De
