Question about Zebra LP 2844-Z Thermal Label Printer
When I tried to installed the driver of the new Zebra LP 2824 Plus, I was asked to choose the Model LP 2824 Plus ZPL or LP 2824 Plus EPL So, what 's the difference between them and which one should i choose
2 Suggested Answers
  • 127 Answers
SOURCE: i am trying to install a lp 2824 plus zebra label
Thank you for posting to Fixya.com and it is my pleasure to guide you.
I have done some research on your printer. Click this link for LP 2824 Plus User Guide P980644-001 Rev A (en) Manual Part #P980644-001 Rev A
http://www.zebra.com/id/zebra/na/en/documentlibrary/manuals/en/printer_manuals/lp_2824_plus_userguide_en.DownloadFile.File.tmp/P980644-001_RA_English.pdf?dvar1=Manual&dvar2=LP 2824 Plus User Guide P980644-001 Rev A (en)&dvar3=LP 2824 Plus
If the link does not open, copy and paste it to IE, or what ever you use.
Doing a search in the manual for ZPL I found that this is the default for the printer. The printing is for a more 'fancy' label.
"EPL Line Mode printing is designed to be command compatible with EPL1 programming language used in early model LP2022 and LP2042 printers."
".. is ideal for basic retail (point of sale - POS), shipping, inventory, work
flow control, and general labeling." "The ZPL style label provides a more intuitive and functionally descriptive naming conventions.."
So, if you want just basic labels, use the EPL. To do more on the label, use the ZPL, which is the default.
Again, download the manual and that will help you decide and will guide better than I can here.
Good luck and please post back that you are successful and give thumbs up if my solution has worked for you. If I can be more helpful just reply.
Posted on Jun 20, 2011
Lp 2824 plus won't print. Have windows 7 till switch off and on again
printer driver conflict or windows 7 driver incompatibility. contact zebra for proper driver installation.
Oct 21, 2014 | Zebra LP 2824 Plus Label Printer
Zebra LP 2824 Plus Giving Endless Labels
OK where is the print spooler on the remote client or the server. Have you check whether this is clearing and not an issue with your remote setup and not the printer does the printer work correctly attached directly to the server break the problem down in stages
Dec 07, 2012 | Zebra LP 2824 Plus Thermal Label Printer
Zebra TLP 2824 Plus does not print barbell labels
You need to run win7 in XP mode. I am not sure the Zebra software will run in 64bit.
Feb 27, 2017 | Zebra Office Equipment & Supplies
Confuse about which drivers need to install for my lp2824 plus? ZPL or EPL? What's the difference between those? When to use ZPL and when to use EPL?
EPL & ZPL are both printer script languages. If the label of your printer has the extension "Z" for ZPL (eg: 2844z-10320-0001) - then use the ZPL Driver.
If the product code has not the extension "Z" (eg: 2844-10320-0001) the unit has the EPL Engine.
Sep 09, 2011 | Zebra LP 2844 Thermal Label Printer
I am trying to install a lp 2824 plus zebra label printer and i need to know whether to select epl or zpl?
You should probably select ZPL, but that depends on which program you will use together with the printer.
Jun 20, 2011 | Zebra LP 2824 Printer
Send a .txt file (zpl language to COM1) to theTLP 2824-Z.
Help!!! I can not print barcode with DOS-command "copy barcode.txt com1". DOS Version is 6.1.7600. The printer zebra TLP 2844 does not recognize the EPL commands.
j.zh
Jul 28, 2009 | Zebra TLP 2844-Z Thermal Label Printer
S4M doesn´t print
The S4M comes with either EPL or ZPL programming language installed. (installed at factory) The S600 is a ZPL only printer. Check that you have correctly specified the S4M as a ZPL printer. Print a config label to check. If it is set as an EPL printer contact your supplier and ask him to download the correct programming language. It should only take a competent engineer about ten minutes (If he knows what he is doing)
Jan 20, 2009 | Zebra S4M Thermal Label Printer
Zebra LP2824 not printing
Sounds like you put your printer into line mode. Line mode prints code so you can see what is sent to the printer to look for possible mistakes in the code.
To switch from line mode back to page mode.
  1. Turn printer off.
  2. Press and hold the feed button down. And switch printer on.
  3. Release the feed button when the LED flashes red.
  4. When the LED flashes green, press down the feed button.
  5. When the LED flashes amber release the feed button.
  6. Try printing now that the printer is back in page mode which is used for print your labels; line mode prints the labels code.
  7. Do this fast or else it wont work if you are slow.
Jan 13, 2009 | Zebra LP 2824 Printer
Can we use any commaon laguage for all Zebra printer.
Can you explain what is is you are trying to print on the label?
May 22, 2008 | Zebra LP 2844 Thermal Printer
TLP 2824 Sebra
is the printer an EPL or ZPL model? i will need to see a hex dump of what you are sending to the printer to pin point the error but it sounds like a label layout issue.
is the barcode content the same on each label? if the barcode content is changing the barcode will grow and move to the right.
Nov 07, 2007 | Zebra TLP 2824 Printer
Open Questions:
See all Zebra LP 2844-Z Thermal Label Printer Questions
Zebra LP 2844-Z Thermal Label Printer Logo
300 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Gateway information...
Marvin
Marvin
Joaquim Martins
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
