Question about InFocus ScreenPlay 4805 Multimedia Projector
Fan stopped working then globe and remote stopped
Hi, the fan on my sp4805 wasnt working working so I replaced the fan with a computer fan. It seemed to work fine until I switched off the projector and when I switched it back on the remote doesnt work and there is no light (the bulb is practically new). It looks like other people are having the same problem. Is there anyway to identify/fix the problem without having to buy new boards or a new projector.
Thanks
  • nphil70 Jun 18, 2008
    Thanks. Yes I would greatly appreciate the service manual if you have it. Since its out of warrantee and service centers cost a fortune I am trying to fix myself.... crazy I know J
    The fan was slightly different but I only had it running for about 1 min. Everything including bulb and remote was working so I switched it off at the power and put the unit back together. This was when everything stopped. I put the old fan back in so when you switch it on you can here the fan try to ramp up, the green light flashes. I have pressed the buttons on the unit but they dont appear to do anything but I assumed you would not be able to tell if they worked because the bulb doesnt work......I may be sadly mistaken.
    The original fan works fine if you plug it into 12V, but in the unit it tries to ramp up then stops then tries again etc
    Thanks
  • dqfinch2 Sep 05, 2008
    I am having the same fan issue.  how do you take off the shell to access the fan, and what is the fan you should use.
    Problem Solver:
  • 16 Answers
Hi there
Yes, unfortunately it is another common fault, sad really lol
The remote not working could be due to the little remote sensor board that you will have seen when taking it apart (I have a service manual if you would like it), do any of the buttons on the unit itself work that you know of?
The bulb not lighting issue can be a number of things, usually a safety wise. When you replaced the fan, what were the specifications of the fan you used? Usually computer fans differ slightly to the ones used in this model, and can cause them to fail and the unit to over heat. If the projector switches on for a bit and then turns off, it means the safety thermostat in it is cutting out preventing overheating, you could try bypassing it just to see if the bulb will ignite. I know it may sound a bit dumb but check the safety switch on the door is fully in?
If you would like the service manual I could send it to you, I found it very helpful with mine, also a forum, I think AVS was extremely helpful aswell.
Sorry if this doesn't help, I will look into it further
Posted on Jun 17, 2008
  • Richard Ayala Nov 20, 2010
    Hey rustee, you still around? Could you please send me this info? I really need it. I just can´t figure out to exactly where you hard wired the nokia charger and if you recommend any type of on/off switch. I know that to "hard off" (unplug) the projector from the electrical outlet all the time, is a no no for the life of the bulb
RECENTLY THE REMOTE AND THE WALL SWITCH WILL NOT OPERATE EITHER THE FAN OR THE LIGHT IN OUR HUNDER FAN. THE REMOTE HAS MODEL UC7848T ON THE BACK. I CANNOT FIND ANY NUMBERS ON THE BODY OF THE FAN. THE...
Hi Does the light fixture have a globe under the fan? What does the light fixture look like? Most of the light fixtures have small screw surrounding the globe that simply unscrew and the globe drops down. All fans are different and I will have to know what this one looks like. In the mean time I will look at some hunter fans on line and see what I find.
Jul 25, 2011 | Hunter 27187 Remote Control
Remote stopped working, fan and light do not
click the reset and turn off the fuse box and then turn on
Feb 15, 2010 | Casablanca Fan 3245T Ceiling
No clips to hold globe on ceiling fan
You best resolution now may be to replace the light kit with one available at Home Depot ..
Jun 07, 2009 | Hampton Bay 52 In. White Redington...
Ceiling fan with light and remote stopped working
It's most likely the receiver for the remote (transmitter) -- it's located under the cover at the top of the fan -- will need replacing.
May 27, 2009 | Hampton Bay 52 In. White Redington...
Airtech ceiling fan with remote, unit in fan not responding
Replace the globe with a LED that will last longer
Nov 20, 2017 | Dryers
Hunter Douglas Ceiling Fan Does Not Work
have hunter douglas fan glass globe broke cant find repalcemants i have all the serial no do you no wher i can go to find 91/2 globe
Oct 30, 2008 | Dryers
SP4805 Fan Issue
the fans in these models do not have a speed sensor wire to let the main board know to turn off the lamp to not risk overheating. so if the fan goes, the lamp remains on. however, if the lamp exploded, check the vents for dust. there is a temp sensor that will shut down the projector if it gets too hot. if the vents are clogged, blow the dust out of the projector with canned air. the dust keeps in the heat that the projector is trying to expell. easiest way to repair the fan w/o buying a part: splice the fan wires together. they can share voltage. if the 80mm fan does not work at all after that, replace the fan (pn: 526-0192-xx).
Jul 31, 2008 | InFocus ScreenPlay 4805 Multimedia...
Remote problems
This sounds like one of the most common problems with Hampton Bay's remote-contolled fans...either the transmitter (remote control) or the receiver (mounted in the fan, typically inside the ceiling canopy) has gone haywire. A circuit has blown or something is short-circuited, and it has a mind of it's own. Some things work, others don't, and others only intermittently. The only fix is to replace the receiver and transmitter, which are relatively cheap and sold as a pair at your local Home Depot and Lowes.
Hope that helps! If you ave any other questions, feel free to ask!
May 19, 2008 | Hampton Bay 24002 Ceiling Fan
Broken globe on Hampton Bay Ceiling Fan (Vercelli model HD278017)
My fan just stopped working - no lights no fan :( and I just can't seem to find any type of switch - only the remote, which lights up just fine. Can anyone help???
Apr 04, 2008 | Dryers
InFocus ScreenPlay 4805 Multimedia Projector Logo
135 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
