Question about Monster Cable (MPHTUPS1000MKII) UPS System
The power goes in but no output - Monster Cable (MPHTUPS1000MKII) UPS System
  • 165 Answers
Fuse? it will probably have one some where
Posted on Nov 10, 2010
Accidently had peaker connect to A side while in bridge mode wud mixer be damaged
Hi, When an two channel (stereo) amplifier is connected in bridge mode the polarity of one channel is reversed, for this example say channel B. An identical (mono) signal is applied to both channel inputs.
The output is now connected between the two channel +ve outputs. As channel A's output goes +ve , channel B's output goes -ve, thus doubling the output voltage.
On this Behringer powered mixer, the bridge switch simply connects the power amp section inputs, the required way.
The bridged output is wired to the B output between pins 1+ and 2+ of the 4 pole Speakon connector. (Because usually pins 1+ and 1- are used, stereo operation is unaffected.)
So.... If you connect a speaker from the A output alone then I would expect it to work, BUT if there is already a speaker connected from the bridge output, then what happens will depend on the amplifier design.
At best the A channel will see too smaller impedance, and hopefully shutdown.
This is a Behringer, it has digital (class D) power amps, and it does Not claim any amplifier protection !!!
If the powered mixer works in normal stereo, then it is probably OK.
If it then does Not work in bridge mode it is likely to be the connector wiring.
All the best.
Apr 07, 2014 | Behringer Pmp4000 Europower 1600-watt...
My monitor won't come out of sleep mode
when the computer enter the sleep mode, it is possible that the computer remove the check mark from this output activation.
When you have multiple ouptut like a internal LCD and output on a monitor, when going into sleep then waked up, laptop reactivate the internal LCD without reactivated the secondary monitor.
you could need to go in desktop property and reactivate the secondary monitor with the check mark listed : Activate.
If you only have one monitor but still a dual output card or two separate video card same thing can happend. try to connect the monitor on the second VGA or HDMI output and see if the video goes there.
then reactivate your secondary output and make it principal.
Does also happend when your computer is connected to a UPS power and your monitor is directly on the sector. (laptop issu also)
if a brief power outage arrive then the monitor shut down (no power) and the computer continu, as there is no monitor on the output any more Windows will automatically deactivate this monitor. when power goes back, this output is no longuer providing video. I suggest putting the monitor on a UPS as well.
Jan 03, 2014 | Westinghouse Electric L1916HW 19" Monitor
TV shuts down, power light blinks nine times
1) test the power supply: a) line cord, b) fuse c) c.breaker d) rectifier e) filter,f) switch,
2) measure the horizontal output +125Vdc
3) all other circuit +12Vdc-
4) vertical output +80Vdc
Oct 16, 2012 | RCA Scenium D34W20 34" TV
Turn on my tv and it goes right back off
tried to disconnect all the output connectors from the power supply board, then make a voltage checking if output voltage is available. if no output dc voltages or drop you have bad power supply board.
Sep 03, 2012 | Sanyo DP46849 46 in. HDTV
Our home audio/video system. Has an orange light on the power button. But when pushed. Goes on then makes clicking sound then goes into protect mode. . What can we do to fix it?
The amplifer goes into a "protect mode" as there is error or current drain into the stages, usually the output stages.
This can be due to faulty /shorted speakers, shorted output drivers ( MOSFETS), of even a fault in the power supply as if there is a malfunctioning for poor regulation. The fault can be several and needs a good probe with points of elimination to confirm the suspected component. Remove speakersm to test, check the outputs before you can go further.
Oct 04, 2011 | Harman Kardon Audio Players & Recorders
Error f61 in panasonic sht540
The abnormalities an output or power supply circuit of POWER AMP.
In normal operation, when DCDET2 goes to "L" (Low) (Not during POWER OFF condition), F61 appears on FL Display and PCONT goes to "L" (Low).
This is due to speaker output has DC voltage or fan is not working.
May 28, 2010 | Panasonic Audio Players & Recorders
When turning on the Panasonic DVD player the unit stays on for 3 seconds and reads "Hello", then reads F61 and turns off. What causes this and how can it be resolved?
May 18, 2010 | Televison & Video
Wiring two circuit pull switch boat lights
3 terminals.. 1 power input & 2 x outputs
Main positive goes to 1 terminal = power in to switch.
The anchor goes to another terminal = power out from switch to anchor
3rd terminal is another output for lights/anchor.
Mar 28, 2009 | Cole HERSEE PUSH-PULL SWITCH -- OFF-ON
Powering off
hello, i think that your output stks are gone, replace them
Nov 04, 2008 | Pioneer VSX-D509S Receiver
Can I connect a power amp to this unit?
If your 2100ES has a selectable INPUT AND OUTPUT and if you're intending to send all signal to the power amp, i.e. not bi-wiring or using the 2100ES to run mid-range or treble then you simply send Left & Right audio (White & Red cable) from a 2100ES output, probably AUX OUT ( it doesn't really matter apart from Phono on some units) straight to the power amp on AUX IN.
We should be just dealing with audio here, so connect the NAD audio output to CD or DVD IN. Select CD or DVD IN on 2100ES input switch and switch output to AUX OUT (whatever you decided goes to the power amp) on the 2100ES. Turn power amp to AUX IN and it will now get an audio signal from the 2100ES for amplification.
Speakers connect to the power amp as a normal amp, so pos and neg etc. The 2100ES now only acts as a signal feed, the power amp does all the work.
So, summary - switch on the NAD, press play - video goes separately and audio goes to the 2100ES. Turn 2100ES to INPUT for NAD. Turn 2100ES to OUTPUT allocated for power amp. Turn INPUT on power amp to allocation for 2100ES.
Turn it up!
Jul 27, 2008 | Sony STR-DA2100ES Receiver
Monster Cable (MPHTUPS1000MKII) UPS System Logo
67 people viewed this question
Top Monster Cable Computers & Internet Experts
David Payne
David Payne
Are you a Monster Cable Computer and Internet Expert? Answer questions, earn points and help others
