Question about Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360)
I have connected a wireless adapter and it connects to the belkin router but the belkin to the internet wont work even though i can use the laptop and i pod which can connect
    Sergeant:
  • 415 Answers
WE JUST HAD THE SAME PROBLEM WITH A WIRELESS BELKIN ROUTER
QUICK FIX GO BUY NETGEAR WIRELESS N ROUTER FOR 50.00. PROBLEMS SLOVED!
Posted on Nov 12, 2010
My Belkin Wireless Adapter connects to the router but says there is no internet connection on my laptop even though there is when I connect to a hard line. All wires have been checked and other items are...
check what encryption your laptop will work with, if its an older laptop then its probably only 64 bit and your router is running on 128 bit encryption, and this will give what you have connected to router but no internet connection
Jan 04, 2011 | Belkin F5D7050TT Wireless Adapter
What is a belkin n wireless usb adapter model # fsd8053v4 used for and can u connect to the internet with it and where do i get the driver?
The wireless adapter is used to connect wireless to the internet, You can use it to make your desktop wireless and laptop.
You can connect to the internet as long as you have a wireless router in your place that will supply the wireless signal.
The driver can be download on this website
http://www.belkin.com/
cheers,
KA
Jun 15, 2010 | Linksys Wireless-G WRT54G Router
Can't get online, even though computer says connected
As the router is working and connected to the internet - then its probably and issue with the wireless setup on router or your PC
1) remove any wireless profiles on your PC read here - how to do that http://mgmcc.forumotion.net/networking-tutorials-f17/removing-an-existing-wireless-profile-t109.htm then when reconnect it will ask for the key again 2) A firewall maybe blocking your access - disable any firewalls 3) Remove the wireless security if enabled in the router and see if you can connect - if this is the only wireless device connecting - it may interference try also changing the wireless channel in the router - use 1 or 6 or 11
Mar 14, 2010 | D-Link Computers & Internet
Trying a add another desk top to an existing Belkin wireless G router at home. Right now there's a desk top and laptop working off this router.Try several times and still can't connect to internet.
Make sure the Belkin wireless is the only device directly connecting to your internet service provider's router/modem. Usually that port is labelled "WAN" or even "Internet". The Belkin should have extra ports/jacks for WIRED connections, right? You then connect the PC into the other remaining ports/jacks on the Belkin (if they're wired) or just use the wireless for the laptop if the laptop has wireless. After getting the wireless going, though, you should lock it down by using WPA encryption key if possible.
Feb 24, 2010 | Belkin (F5D7230-4) Router (587009)
Router won't connect to the internet
I managed to figure it out. I had to clone the MAC address to get the router to connect to the Internet.
I still have another problem though, my laptop still won't connect to the router. I'm using Vista, is this a possible network adapter issue? My laptop is fine at connecting to other wireless networks round my friend's houses/libraries...
Mar 21, 2009 | Belkin (F5D7230-4) Router (587009)
Hi. I have a Belkin Wireless G Plus MIMO Router, which has been fine to connect my laptop to the internet (although seems slow sometimes). I just got a Wii, but this wont connect to the internet. The Wii...
Check for the wireless encryption settings associated with this. If you're trying to join a network with "Open" settings to a encrypted network it won't work very well.
Nov 17, 2017 | Belkin Wireless-G Plus MIMO Router with...
Have dlink router but belkin wireless adapter cant connect
sounds like a security conflict, if you log onto the router and disable the wireless security will the laptop connect to the internet?
Dec 31, 2008 | Computers & Internet
Wont work my belkin usb
All wireless adapters use the same radio channels so your adapter will work with your router. (If that wasn't the case, it wouldn't be so easy to connect to networks with a laptop with built-in wireless.)
Dec 03, 2008 | Belkin N1 Wireless USB 2.0 Network Adapter...
Cant connect to wireless router
Make sure the wireless adapter is enabled on the elonex laptop and its properly installed.
Connect wirelessly on the elonex one laptop using the same SSID and security key that you used on your main laptop.
Aug 07, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin n1 wireless usb adapter
Dear Friend,
1. Connect your ISP modem to your PC and configure as Bridge mode.
2. Remove your ISP modem and connect your wireless router to your PC and configure as PPPOE mode. (refer http://www.wi-fiplanet.com/reviews/article.php/3645166 if any doubt on configuration)
3. Now connect your ISP modem to wireless router, The modem should connect to your WAN cable.
4. And Give the wireless router's IP in your laptop as Gateway (In TCPIP settings of your Laptop wireless adapter / or configure DHCP)
5. Now you can access internet on both systems.
Feb 02, 2008 | Belkin N1 Wireless USB 2.0 Network Adapter...
Open Questions:
See all Microsoft Wireless Network Adapter Xbox 360 Questions
Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360) Logo
106 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
