Question about Philips VR330 VHS VCR
Phillips VR 339 'P08'
The machine just won't accept tapes any more and shows 'P08' on the front screen. Any ideas? Thanks
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 242 Answers
Retime the gears
Posted on Jul 17, 2010
Sony RDRGXD455 have tried both DVD-RW and DVD+RW discs from Phillips and they do not work. I have tried VR and Video modes. Do you think Verbatim DVD-RW discs would work?
It depends on what you are trying to record on them. These machines have copy protection built in. So if they detect that they won't let you record on the disc.
Mar 26, 2017 | Sony Televison & Video
Red light blinking won't accept tape
If a tape "hung" up and it won't accept one you have a loading issue.
The unit may use a belt to drive the tray or a geared mechanism.
In any case someone needs to open the unit up to "see" what is happening. Most of these a tape can be inserted with power off and manually cycled into the unit to see the issue---we usually use a old cassette with the tape inside removed to avoid issues.
If you cannot do that consider looking for a shop who will (some no longer work on this type of equipment.)
Dec 05, 2012 | JVC BR-DV3000U DV/Mini DV VCR
Canon zr700 won't play tape
That is the pinch roller. If it does not press the tape against the capstan, then the tape will not pass the read/write heads. Replace it.
Jun 25, 2017 | Canon ZR700 Mini DV Digital Camcorder
Phillips Pocket Memo 381 The button you press in when recording will not press in! Any ideas tThe machine plays back tapes OK
You cannot push it in without a recordable tape in the unit. The mini cassette tapes have a removable erase prevention tab on each side in the front. If removed, you cannot push record. Try another tape. Otherwise the recorder needs repair.
Aug 16, 2011 | Philips Pocket Memo 381 Handheld Cassette...
I have just bought a second hand good condition Phillips VR Video Machine. I can play tapes, eject, reverse and forward on the machine itself, but the I can't track, get menu, reverse, forward or play...
The chances are that the person who supplied it to you gave you a Phillips remote for another VCR. Many makers remotes will work parts of a different model of the same firm, but only the true remote will operate ALL functions.
If you have the user manual check to see if it list the part number of the remote. If you don't have it look around the net for Philips VR630 remote. See if it matches yours. If it doesn't you will have to replace it.
Nov 01, 2010 | Philips VR630 VHS VCR
MFC-7840w keeps saying "toner life end"
After I figured this out, it was quite easy to resolve. Remove the toner cartridge from the drum cartridge. Remove the black plastic cover on the left side of the toner cartridge (3 Phillips screws). There is a "flag", which is a small plastic tab on the outer side set to the right at about 2 o'clock. Turn the gears until you fully reset the tab going counterclockwise to the 10 o'clock position (fully to the left). Reinstall the small black cover and the three phillips screws. And the idea to install black electrical tape over the small clear plastic windows on both sides is also a good idea to prevent the early and false message that the cartridge is empty. Make sure you do not allow that tape to get into the gears.
Sep 25, 2009 | Brother MFC 7840W Printer
Vr / 712 / hifi / picture scrammble / fuzz /
From your description it appears you may have dirty heads. Either try a video head cleaner tape or better still , remove the casing & using either a proper head cleaning tool & an appropriate head cleaner fluid (isopropal alcohol) very gently wipe the heads, Do Not put too much pressure or rub too hard as this will damage the heads. If this does not cure the problem then new heads will be required.
Your VR 354 is possibly the whole of the tape path needing cleaned especially the pinch roller (black round roller on the right hand side) this might be worn & again needing replaced
Jul 20, 2009 | RCA Televison & Video
Prologic on Kenwood VR-407 not working
plug front speakers into the a side
May 31, 2009 | Kenwood VR-407 Receiver
How to install and set up a VR 750 Phillips Video Recorder
that doesn’t, have power on and play, when you insert pre-recorded tape. The on-screen displays are a bit odd too, the main menu is called up using the auto-install button, which only works when the VCR is in standby mode.
Sep 14, 2008 | Televison & Video
Philips VR330 VHS VCR Logo
130 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
