Question about Jacuzzi BK37959 White Era?? Two-Piece Elongated Toilet BK37
Jacuzzi BK37959 White Era Aside from the known issue with low water in bowl, there is very little water washing down the sides of the bowl during a flush! Can this be addressed? The toilet does have strong action for flushing, but not removing any material on the sides of the bowl-YUK!
  • 528 Answers
Is there a good flow from the small feeder tube going into the center tube the flapper mounts to? It is possible your flush assembly has mineral deposits,rust,calcium,etc. build up and is not allowing sufficient flow through that tube to rinse the sides of the bowl. You could also Try dumping undiluted C L R (calcium,lime,rust) cleaner into that tube and allowing it to clear the passages. If the passages are blocked you will notice the water flooding back out of that central tube in the tank and may be able to use a small inspection mirror and a piece of baling wire to clear the exit ports around the rim of the bowl. You may also be able to clean the entire flush assembly by removing the water line from the bottom of the tank then removing the flush assembly and soaking it in C L R for a half hour - or, just replace the entire assembly. I hope this helps!!
Posted on Dec 01, 2010
Jacuzzi toilet does not fill enough water in the bowl
Check to see if there is not a clog in the trap. This could keep your bowl from filling up. Also check the flapper and see if it is staying afloat in the tank long enough during the flush. Either of these could be the cause here.
Jan 14, 2013 | Jacuzzi BK37959 White Era?? Two-Piece...
Jacuzzi espree toilet leaking water from bowl without flushing. water on floor in front.
Hi!Maybe the problem of your toilet is in the mechanism inside the tank that's why its always leaking.Kindly check the tanks fittings of your toilet and replace it if necessary.
Sep 01, 2011 | Jacuzzi BK37959 White Era?? Two-Piece...
Toilet is very slow filling tank with water to flush
look inside the reservoir. There is a cylinder sticking up at about water level or above. That cylinder should have a small hose (tube) going into the top of it attached with a small clip. This helps fill the bowl with water. These come off from time to time and just fall down into the water and dont do what they are supposed to do. Hopefully this is the problem.
Mar 26, 2011 | Jacuzzi BK37959 White Era?? Two-Piece...
Are these toilets not suppose to have much water in the toilet? I'm not talking about the supply tank.
Yes, many of the new low water usage toilets carry very little water in the bowl....
they still work well though...
heatman101
Aug 18, 2010 | Jacuzzi Bath Era BK37 959 White toilet...
Please tell me how to get more water in my toilet bowl..not the tank..the bowl please..thankyou. It is a Jacuzzi Era Elongated bowl.
The water level in the bowl is determined by the built in trap in the back of the bowl. Water is allowed to enter the toilet and it then "over flows" the p trap in the back when flushed. Once it's flowing, it syphons the water out of the bowl. While the tank is re-filling, a small portion of water should be running down the overflow from the small hose clamped onto the overflow This rinses the inside of the bowl, as well as helps-refill the bowl. Be sure that hose is directed inside the overflow tube. To see what the max water level in the bowl can be, add some water from a cup or glass. Once it's full you can keep adding and it won't get any higher. This will be the max level you can expect.
Jul 07, 2010 | Jacuzzi BK37959 White Era?? Two-Piece...
Need to order a replacement toilet seat for Model Jacuzzi Era toilet. We have looked at Lowe's and other home improvement stores and all the available elongated replacement toilet seats do not seem to be...
Try checking plumbing supply houses instead of home improvement stores. Im not sure where you are located. Here in MO. I use Harry Cooper Supply or Riback Supply or Southern Materials. A good supply house should be able to help you find what you are looking for. Hope this helps.
May 04, 2010 | Jacuzzi BK37959 White Era?? Two-Piece...
My flapper leaks,only 1yr. old.jacuzzi model bk37959
Hi and welcome to fixya, try giveing some slack to the chain that conects to the handel, its likliy too tight and keeping it open.
Feb 10, 2010 | Jacuzzi Bath Era BK37 959 White toilet...
Jacuzzi BK37959 White Era?? Two-Piece Elongated Toilet BK37 Logo
303 people viewed this question
Top Jacuzzi Home Experts
US Parts Center
US Parts Center
Mike
john h
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
