Question about Pelonis Heating & Cooling
The power button does not turn on the heater. It is plugged in to a owrking outlet. Is there a switch problem?
    Genius:
  • 1,015 Answers
Does your heater have apush button switch or toggle type. Either way if you push in button type and it won't stay in then switch is bad. Will heater come on if you push switch on and hold it? There should be a small red light on top and fan inside of heater. Do they work? If it was me and I really thought that switch was bad I would remove back and wire around switch. If you don't feel comftortable doing this then you are probable better off just getting a new heater. If you do decide to try wiring around switch make sure heater is unplugged and try to trace wires to switch. If it's just a simple on off switch there should be two wires going to it. Disconnect them from switch and temporarily connect together.Plug heater back in and if it works you know switch is bad. Remember if you don't feel comfortable doing this then don't do it. Most of these small electric heaters are available for around twenty dollars,so I wouldn't spend much time or money trying to fix this one.Hope this help some. Thanks
Posted on Nov 10, 2010
Heater does not turn on
Is it plugged in? is the electrical outlet working?
Jan 25, 2014 | DeLonghi Heating & Cooling
Heat surge amish heater turns off and trips reset button
Do NOT use this unit as is!.
My experience is you have to pay to ship it for repairs and if out of warranty you should buy another heater. All electric heaters use the same power for the same heat unless its a heat pump, so save money and buy $30 WalMart heaters.
Nov 17, 2012 | Heating & Cooling
Why does red light on "on" button stay on?
The reason the red light on your rinnai vent free gas heater stays on simply is because it is having power on it, if it is unplugged, it will go off, or if you turn off the switch from the power outlet, then it will go off too.
As long as there is power supplied to the rinnai vent free gas heater, the power light will remain on.
Take care and good luck
Dec 01, 2010 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
My rinnia wont turn on help plz!!
Not much to go on so I am going to assume some things. If unit not getting power (no lights light up) check plug and outlet. Check fuse on circuit board. Check circuit box for a tripped breaker. Is the outlet the heater is plugged into on a light switch?
Is the unit getting gas? Check the shut off behind the door on the right side of the heater. Is it on? Is your gas meter turned on or is there gas in your propane tank?
Lastly, is there any error codes? You can check by turning the heater off and then all at the same time press on the Economy button, the up arrow and the down arrow and hold for three seconds.
Feb 08, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
I plugged for the first time my laptop on to the VGA input tv screen showed a sign that read something like: no signal, tv will turn off. then it switched off and now it wont turn on on the on/off switch...
There is a button on your laptop for switching from laptop screen to external screen, This button is usually in the top row of special function buttons, did you press that as it will tell your computer you are connected to another monitor. Also some times you have to leave the monitor off for about 5 minutes so it will reset itself.
Oct 09, 2009 | Televison & Video
My c4480 printer will not turn on. I checked the connection on back of the printer. I used different A/C outlets.
Try the following solutions if there are no light indications, no noise, and no movement from the printer when you turn it on.
Solution 1: Make sure you use the power cord that came with the product
Solution:
• Make sure the power cord is firmly connected to both the product and the power adapter.
Plug the power cord into a power outlet, surge protector, or power strip.
• If you are using a power strip, make sure the power strip is turned on. Or, try plugging the
product directly into a power outlet.
• Test the power outlet to make sure it is working. Plug in an appliance that you know works,
and see if the appliance has power. If not, then there might be a problem with the power
outlet.
• If you plugged the product into a switched outlet, make sure the outlet is switched on. If it
is switched to on but still does not work, then there might be a problem with the power outlet.
Cause: The product was not being used with the power cord provided.
If this did not solve the issue, try the next solution.
Solution 2: Reset the product
Solution: Turn off the product, and then unplug the power cord. Plug the power cord back in,
and then press the On button to turn on the product.
Cause: The product experienced an error.
Solution 3: Press the On button more slowly
Solution: The product might not respond if you press the On button too quickly. Press the
On button once. It might take a few minutes for the product to turn on. If you press the On button
again during this time, you might turn the product off.
Cause: You pressed the On button too quickly.
Solution 4: Contact HP to replace the power supply
Solution: Contact HP support to request a power supply for the product.
Go to: www.hp.com/support.
If prompted, choose your country/region, and then click Contact HP for information on calling
for technical support.
Cause: The power supply was not intended for use with this product or it had a mechanical
failure.
Solution 5: Contact HP support for service
Solution: If you have completed all of the steps provided in the previous solutions and are still
having a problem, contact HP support for service.
If prompted, choose your country/region, and then click Contact HP for technical support.
Cause: You might need assistance to enable the product or software to function properly.
Good Luck
Chris (ziraffa)
PS Have you changed the fuse in the plug? Just a thought..
Dec 22, 2008 | HP PhotoSmart C4480 All-in-One Printer ...
Got a hoover washer /dryer wdm 1300 , it wouldnt empty properly, watched the impellor on the pump and some times it would run and then stop , a quick flick with a screw driver and away it went again ,also...
HI CHECK THESE....
Step 1: Make sure the washer is receiving power. Check the cord, the plug, and the outlet. If a wall switch controls the outlet, make sure the switch is working. Look for blown fuses or tripped circuit breakers at the main entrance panel. If the unit is receiving power and still won't run, press the reset button on the control panel (if the washer has one).
Step 3: Make sure that both water faucets are turned on and that the drain and soap-saver return hoses are properly extended, without kinks. If the washer has a water-saver button, make sure the button is depressed; water may not circulate through the filter nozzle if the basket is not full and the button is not depressed.
Step 4: To make sure the water is the proper temperature, check the temperature selector switches on the control panel to make sure they're properly set. Also check the water heater temperature control. It should be set no lower than 120 degrees F.
THANKS
Sep 12, 2008 | Washing Machines
My philips GOGEAR SA6045 MP3 Player won't turn on
Runa Repair in the Philips Device Manager - make sure the lock switch is not engaged.
Jul 17, 2008 | Philips SA3125\02 MP3 Player
Heating & Cooling Logo
496 people viewed this question
Top Pelonis Heating & Cooling Experts
Paul Carew
Mack Baxter
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Pelonis Heating and Cooling Expert? Answer questions, earn points and help others
