Question about Sharp AL2030CS Black and White Copier
Sharp al-2030 error code l4 32 - Sharp AL2030CS Black and White Copier
5 Suggested Answers
checkitright
  • 1362 Answers
SOURCE: H3 ERROR CODE SHARP AL 1631
H3:
00:TEMPERATURE OF FUSER UNIT HIGH,THERMISTOR CONTROL BOARD FAILING
Did you replace the thermistor? check the thermofuse also for continuity
Posted on Oct 20, 2008
SOURCE: Sharp AL 1641 CS L4 Code
under the glass copier/scanner bed, in the area where the copies eject, there is a clear plastic dial that can be turned either to the "lock" or "unlock" position. Turn this clear plastic dial. Be sure to lock the unit when transporting it.
Posted on Feb 04, 2009
  • 118 Answers
SOURCE: CODE L4-02 JUST ILUMINATE ON MY SHARP AR-M 350U PHOTOCOPIER
That code means you have a drum drive motor failure. The drum is the long, cylindrical green-blue tube you'll see when you open the left-side door.
Chances are some paper jammed up inside the drum process unit (that black frame that holds the drum) and it's keeping the drum from turning. Check the drum/process unit and make sure they are clear of any material that could cause a jam.
Posted on Aug 28, 2009
xptareq2000
  • 1447 Answers
SOURCE: error code L4 30
L4 error code mean your copier motor fail problem.
Please press # Interrupt C interrupt press 16 press start key or print key.If are not fix this problem please check motor fuse or any kind of gear was broken.
Posted on Dec 16, 2009
Clearing service man on 5320 sharp copier
Hello, NICOLAS
Let me give you, a url when you can find sharp error codes and fix by youself, if you have any other cuestion, please write a comment, im here for help you.
How to solve the h4 subcode 00 error message on sharp AL-2030 copiers
http://www.en.rellenadodecartuchos.com/2014/05/how-to-solve-h4-subcode-00-error-message-on-sharp-al-2030-copiers.html
thanks for comment if need more help
Nov 16, 2015 | Sharp Office Equipment & Supplies
Sharp al-2030 h4-00 code
H is a heater problem H4 is more specific, not sure but it could be the lamp, thermistor or triac. It will be one of these or even a bad connector on the heater section
Aug 28, 2014 | Sharp AL-2030 All-In-One Laser Printer
TENGO UN ERROR 4 l EN UNA FOTOCOPIADORA AL 2030
H4 mean heat roller low temperature detection
08bbjn9rbri+xdkjoq0fkqpdkucvv87lg66brrj5rzvk2vgkrs9uaz1auaie3rmbc17pbhis8ry2etxu+pffwlcypo2vmp+hmnkpzqro3omzqzp3yebq5d34amdixrh6r1b2aaaaaelftksuqmccpress 14 press start then ready to make copy
Mar 25, 2011 | Sharp AL2030CS Black and White Copier
Sharp al 2030 with a code of ch
Believe it or not. Change the toner cartridge and it should go away.
Aug 03, 2010 | Sharp Office Equipment & Supplies
Sharp SF 2030: How do I clear code 115?
we don`t have code 115 in 2030 model .maybi it is H5 but your led doesn`t show.
May 18, 2010 | Office Equipment & Supplies
I have a H2 error on my AL 2030--no number pad), what can I do?
enter:
[#] key → [*] key → [C] key → [*] key
then enter
14 (with the copy +/- keys)
then press
Start/Copy key
Feb 03, 2010 | Sharp AL2030CS Black and White Copier
I have error H 2, what to do?
This error indicates: H2-0 Fusing unit temperature error
Unless you are technically capable, you will want to have a qualified technician diagnose and repair.
If you want to try and diagnose it yourself, follow these directions.
You have to reset fuser errors with simulation 14. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective replace
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE***
Feb 03, 2010 | Sharp AL-2030 All-In-One Laser Printer
Sharp AL2030CS Black and White Copier Logo
711 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
