Question about GPS
Ac servo drive Errors
Dear Sir, Please solve my problem as soon as possible i want to know about error code of panaconic ac servo drive and reasion and salutation of everu err. code. 1) Ac Servo Drive: MEDDT7364003 2) Ac Servo Drive: MDDDT3530003 3) Ac Servo Drive: MBDDT2210003
Dear sir,
i got a problem in my servo drive (mbddt2210003) error 21. plz solve this problem for me. thanks
Posted on Jul 01, 2011
Error 46
Posted on Feb 24, 2011
Seus burro
Posted on Sep 11, 2008
Error code message
What Does Your Treadmill's Error Code Mean? - LifeSpan
www.lifespanfitness.com/.../what-does-your-treadmills-error-code-mean
Free
May 21, 2015 - If the running belt stops after 6 seconds of starting the treadmill, this may indicate that either the ... If there is no belt movement, or you notice a burning smell coming from the motor area, this ... An E6 or E7 error code is an incline error code. ... This will cause the incline motor to raise the running deck up.
[PDF]ERROR CODES: ADDITIONAL ERROR CODES:
www.gympart.com/TSB/.../Treadmills/.../Sportsart%20Error%20Codes.p...
ERROR 6: INCLINE ERROR - CHECK INCLINE OPERATION AND CALIBRATION. ERROR ... ERROR 1-1: AC SERVO ERROR - AC SERVO MOTOR ENCODER HAS FAILED ... error codes listed by category: treadmills, bikes, elliptical trainers. ...ERR1 Condition 1: Press speed key; walk belt doesn't move; ERR1 appears.
[PDF]Error Code Troubleshooting Guide
Jan 19, 2016 | Exercise & Fitness
Error code AC-6
ERROR 6: INCLINE ERROR - CHECK INCLINE OPERATION AND CALIBRATION ...ERROR 1-2: AC SERVO ERROR - MOTOR IS OVERHEATING (SPEED RESTRICTED ... error codes listed by category: treadmills, bikes, elliptical trainers.
[PDF]Precor Error Codes
My orient split a.c shows Ec error in digital display
sir plz answer me my ac orien 1 ton showing EC error on display what is this i can't understand what is this plz reply
Jul 12, 2014 | Heating & Cooling
Treadmil t733 shows E9 error and soes not start
Dear Sir:
Hello I hope you are o.k
I wil give some tipoe with this Error code:
Error 09 - Lower PCA Memory Test Errors
Description
Error 09 checks lower PCA memory locations during the power up test sequence. If a fault is
found during the power up test sequence, error 09 will be displayed. This error code is only used
on products utilizing the dual microprocessor system.
Possible Causes
1. This error message almost always indicates a lower PCA problem when it is consistently
displayed. Failures causing this error message to be displayed are rare.
Possible Remedies
1. If the error message is consistently displayed when the unit is powered up, the lower PCA
should be replaced. It is possible to see this error message displayed intermittently due to
external causes. If the units A.C. input significantly dips during the power up test sequence
the test could fail resulting in this message being displayed. Treadmills operating on
non-dedicated A.C. circuits may see this message displayed on an intermittent basis.
Thank you in advance, sincerely. Blessing.
If you need additional Help, please reach me.
E.CUADRA
Managua, Nicaragua. C.A.
Sep 28, 2011 | Exercise & Fitness
It does not start and shows E9 error
Dear Sir:
I hope you are o.k
I will help you:
Please follow this step:
Description
Possible Causes
Possible Remedies
If you need additional Help , please reach me.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
My v fit treadmill is not working. It is displaying E1. Is this a trouble shooting code?
Dear Sir:
Hello, I am glad that you contact us.
I will give some Tips:
1) Your Error C is for Troubleshooting, only that message, is must be special some times.
2) Your Error C, has some interpretation depend of the factory.
3) Example: E 01: Mean Replace VSD( Variable Speed Drive) to due some Microprocessor Chip Failure: The Option will be replace Board VSD, but you must contact to the Company for to Fix the Board.
4) The another Alternative: If your equipment has Servo Motor:the enconder is Malfunction: You must Re-Start Machine, and follow again. If the problem persist, You must exchange: a) Servo Motor b) or The Drive Board.or Both.
5) The following alternative is:
Description
Errors 00 through Error 04 check upper PCA memory locations, RAM memory locations and
EEPROM checksum during the power up test sequence. If a fault is found during the power up
test sequence, the appropriate error code will be displayed.
Possible Causes
1. These errors messages almost always indicate an upper PCA problem when they are
consistently displayed. Failures causing these error messages to be displayed are rare.
Possible Remedies
1. If the error message is consistently displayed when the unit is powered up, the upper PCA
should be replaced. It is possible to see one of these messages displayed intermittently due
to external causes. If the units A.C. input significantly dips during the power up test sequence
the test could fail resulting in one of these messages being displayed. Treadmills operating
on non-dedicated A.C. circuits may see these messages displayed on an intermittent basis.
I hope that you can resolve this, and take your final step.
Thank you in advance, sincerely. God bless you.
I you Need additional help, you can reach me.
E.CUADRA
Sep 27, 2011 | Exercise & Fitness
9.1.0 TREADMILL PRECOR PACE ERROR 3
Dear Sir:
Hello I hope everything is fine.
Description Errors 00 through Error 04 check upper PCA memory locations, RAM memory locations and EEPROM checksum during the power up test sequence. If a fault is found during the power up test sequence, the appropriate error code will be displayed. Possible Causes 1. These errors messages almost always indicate an upper PCA problem when they are consistently displayed. Failures causing these error messages to be displayed are rare. Possible Remedies 1. If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see one of these messages displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in one of these messages being displayed. Treadmills operating on non-dedicated A.C. circuits may see these messages displayed on an intermittent basis.
In other words, you need recalibration in your equipment, I recomend after you make a test for a RAM MEMORY.so contact your service call. I recomend Strong, INSTALL regulator Voltage is cheap about us$15,00 Radio Shak or another Electronic Place.
Thank you in advance , sincerely. Blessing. If you need additional Help, please do not hesitate to contact me.
E.CUADRA MANAGUA, NICARAGUA. C.A.
Sep 25, 2011 | Precor 9.21 Treadmill
Hi. The Sportasrt T680 Treadmill shows Error 2_1. Does anybody know, what should I check in the AC Servo Driver? The IGBT bridge is okay. Any other? Thanks.
hi,
The primary reason for E2-1 is that the drive board detects IGBT over current signal
Check the folowing.
A. Re-start the unit.
B. Inspect whether the servo motor wires are connected properly to the motor.
C. Replace the drive board.
D. Inspect the servo motor windings for a break. If so
E. Replace the servo motor
Aug 28, 2011 | Exercise & Fitness
When I started my DELL Inspiron 1525 running Win 7 Ultimate, I got a white-on-black screen which questioned the voltage from power adapter. Diagnostic program run.. Stopped with the following msg: Error...
2000-0142 and 2000-0146 are hard drive SMART errors, indicating the HDD will fail.
To boot message about the AC adapter was a BIOS level message that normally appears when a Auto/air ac adapter or other 65 watt ac adapter is used to power the system.
Jul 16, 2011 | Dell Inspiron 1525 Laptop
GPS Logo
354 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
