I have a gateway desktop that is beeping before post. It beeps and will not post.
    Problem Solver:
  • 7 Answers
It depends on the motherboard model, but here is an example of the error codes for a gateway:
Beeps Error Message Description 1 Refresh Failure The memory refresh circuitry on the motherboard is faulty. 2 ECC Error Error Checking and Correction (ECC) is supported on this product. 3 Base 64 KB Memory Failure Memory Failure in the first 64 kilobytes (KB). 4 Timer Not Operational Memory Failure in the first 64 KB, or Timer 1 on the motherboard is not functioning. 5 Processor Error Ther processor on the motherboard generated an error. 6 8042 - Gate A20 Failure The keyboard controller, 8042, may be bad. The basic input/output system (BIOS) cannot switch to protected mode. 7 Processor Exception Interrupt Error The processor generated an exception interrupt. 8 Display Memory Read/Write Error The computer video adapter is either missing or its memory is faulty. This is not a fatal error. 9 ROM Checksum Error Read-only memory (ROM) checksum value does not match the value encoded in BIOS. 10 CMOS Shutdown Register Rd/Wrt Error The shutdown register for complementary metal-oxide semiconductor (CMOS) random access memory (RAM) failed.
Posted on Nov 10, 2010
4 Suggested Answers
  • 2666 Answers
SOURCE: Post Error Beep Codes for System Board
Beep codes are here
http://support.gateway.com/s/Servers/COMPO/MOTHERBD/WME859199/WME859199faq2.shtml
Posted on Jun 30, 2009
joecoolvette
  • 5660 Answers
SOURCE: Gateway Desktop gives me 3 long beeps
Sounds like Ram Memory failure.
Try removing the Ram memory modules ('Sticks'), and cleaning the contact pins with a pencil eraser. Corrosion can develop on the contact pins after a given time.
This isn't hard to do.
1) Computer unplugged from power, open the computer case.
(Unplug the power cord from the Surge protector, and NOT the back of the computer. {Power Supply)
2) Follow Anti-Static precautions BEFORE you reach inside your computer.
[Anti-Static Precautions:
Your body carries Static electricity.
Static WILL fry out (Short Circuit) the delicate hardware components inside a computer.
Computer unplugged from power, work on a table. Press the Power On button in, and hold it in for a count of 10 seconds. (To relieve any residual power)
Computer case open, TOUCH the metal frame of the open computer case.
This action will relieve your body of Static.
Should you walk away in the middle of working on your computer, upon your return TOUCH the metal frame again ]
3) Unplug all cables from the computer. If you are not VERY familiar, with where these cables plug into on the computer, it would behoove you to make notes, and a drawing if you wish.
Lay a towel or similar object on your work table. Helps to prevent scratching the table, and your computer.
Open the computer case. You will be removing a Side Panel. Facing the computer it is the Right side panel that you will remove.
Facing the back of the computer, there are two Thumbscrews you need to loosen. One towards the top, one towards the bottom.
Turn these Thumbscrews to the Left to loosen. They should not come all the way out, and will hang there.
You will see a raised 'Hump' (Protrusion), in the Side Panel. This is an area in which you place your fingers, to remove the Side Panel.
The rear of the Side Panel swings away from the computer, in order to remove it.
(Like a door)
[ Barring that my instructions may not be very clear, you can download the User Guide, with instructions, and photos for this,
http://support.gateway.com/s/PC/R/1009151/1009151ul.shtml
Left-click on -
8511050 - Gateway Computer User Guide.
This is a PDF file.
It may take a few seconds before you see the first page, and additional time to fully download.
Suggest you let the file fully download before looking through it.
Opening the computer case starts on Page 51 ]
Once the Side Panel is removed, lay the computer on it's side on the towel, opening facing up.
Makes it a lot easier to access the Ram Memory modules.
Removing and installing ram memory modules starts on Page 55.
To me the information, and illustrations are unclear.
I'm going to detail my own information.
When you open your computer there will be many cables (Wires), which makes it tough to see the Ram Memory modules, and the ram memory slots they reside in.
In order to better clarify where the ram memory slots are located on the motherboard, I am going to give a link to Gateway Support, and an actual photo of the motherboard in your computer.
(No hardware components are installed on the motherboard. Bare motherboard)
http://support.gateway.com/s/MOTHERBD/Shared/4006136R/4006136Rnv.shtml
At the top left of the motherboard are two Black ram memory slots, and two Blue ram memory slots.
To view the ram memory slots in a closer view, click on this link,
http://support.gateway.com/s/MOTHERBD/Shared/4006136R/4006136Rmvr5.shtml
At each end of the ram memory slots is a white Lock.
The Lock is gently pulled out at the top.
The best method is to pull out on both Locks at the end of a ram memory slot, simultaneously.
This action raises the Ram Memory module up out of the slot.
Only remove one Ram Memory module at a time.
The Gateway GT5220 desktop computer uses DDR2 Sdram, ram memory modules.
(At 533MegaHertz
533MHz.
Mega = approximately 1 Million
Hertz stands for Cycles per Second.
The above ram memory, can operate at a frequency rate, Up To 533 Million Cycles per Second.
Another term used for DDR2 Sdram that operates at a frequency rate of 533MHz, is PC2-4200)
Below is a link for an up close photo of DDR Sdram.
Link given for clarity of the gold plated contact pins.
(DDR Sdram has 184 contact pins. 92 on each side.
DDR2 Sdram has 240 contact pins. 120 on each side)
http://en.wikipedia.org/wiki/File:Generic_DDR_Memory_%28Xytram%29.jpg
(You can left-click on the photo to enlarge it)
Refrain from touching the gold plated contact pins.
You can hold the ram memory module anywhere else you wish. (Body)
The body of the ram memory module is coated with a see-through protective plastic coating.
Using the pencil eraser, start at the top of each contact pin, and stroke down. (The contact pins are on the bottom of the ram memory module)
If you use a pencil eraser that is on the end of a pencil, refrain from letting the metal under the eraser, touch the contact pins.
Once you are satisfied the contact pins are clean, use air pressure to remove the eraser dust.
You can use a can of compressed air for computers, or air pressure from your mouth may be sufficient.
Reinstall that ram memory module, go to the next one.
Viewing the ram memory module, you will note the cutout, or Locating Notch on the bottom.
At a cursory glance, the Locating Notch may look to be centered.
It is Not.
The ram memory module Locating Notch, lines up with a Locating Lug, in the bottom of the ram memory slot.
Align it in the correct position before installing.
The white Locks have a small slot.
The bottom corners of the ram module sit in these slots.
Locks eased all the way out to the side, the ram memory module is lined up with these slots, so taht the corners rest in the slots.
(And the Locating Notch is lined up with the Locating Lug)
As you press the ram memory module down evenly, the Locks come up.
Each Lock has a 'Bump', or protrusion.
This protrusion lines up with a Notch, at each end of the ram memory module.
When the ram memory module is full seated, and the Locks go into the Notches, you should hear two clicks.
The protrusion of the Lock may not fit very well into the Notch, so don't look for a precise fit.
Let's start here, and see where this diagnoses takes us.
[Would also like to add, that the inside of the computer, AND the inside of the Power Supply, should be cleaned on a regular basis as needed.
Computer unplugged from power, computer case open, use a can of compressed air for computers.
(Don't forget about the Anti-Static Precautions)
Use Q-tips on the thick 'Gunk'. You are only using them to break the 'crust'.
Then the can of air will remove the gunk.
Attach the plastic straw to the nozzle of the can of air.
Start at the top Left inside corner of the computer, shoot air across to the top right corner.
Use a spray method like a painter using a spray paint gun.
When you start press the trigger in all the way, as you approach the end of the row you are making, let go of the trigger.
Drop down a space. I drop down 1 inch.
Shoot air across in another row.
Keep going down in rows until you reach the bottom.
As you make your rows going down, you will approach the Processor fan.
Pay special attention to the Fan's blades, center hub of the fan, and the surrounding cage of the fan. (Shroud)
Use Q-tips to dislodge the thick gunk.
Use care when shooting air at the Processor fan.
You Do Not want to spin the fan faster than it was designed for.
Spinning the fan too fast, may lead to premature failure of the fan's bearings.
Use Short Bursts.
Squeeze the trigger in all the way, then let go]
Post additional questions in a Comment.
(Believe upper right of your page)
Posted on Jun 27, 2010
damnor01
  • 1179 Answers
SOURCE: my gateway desktop wont boot, it only beeps 3
Welcome to Fixya!
You will need to remove the RAM modules and clean their gold fingered connectors with tissue paper. Also clean the RAM slots with a vaccum cleaner, be very careful through. Once cleaned install the RAM modules one at a time as one may be faulty and then power on your computer.
Take care!
damnor01
Posted on Oct 06, 2011
Long beep on gateway computer
pls find the model no. and find the beep codes and match the order to identify the problem
ex:POST Beeping Error General Codes
  • Bad Motherboard - 1 long and 1 short beep
  • Disk drive related problem / Video card problem - 1 short beep then nothing happens
  • Bad video card - 1 long and 2 short beeps
  • Bad power supply - 1) continuous beeps, 2) non-stop short beeps
  • Bad memory - 3 short beeps
Nov 07, 2016 | Gateway Computers & Internet
Gateway LX6810 Desktop turns on but will not boot up
http://www.pcmag.com/encyclopedia/term/38515/beep-codes
here is the explenation to the beeps.
one beep means bad memory.
Apr 16, 2013 | Gateway LX6810-01 PC Desktop
Gateway SX2800 Desktop continuous beeping
There may be a compatibility issue, or the hard drive is not working properly.
Mar 12, 2012 | Gateway SX2800-01 PC Desktop
Computer will turn on but will not boot up
Dear,
Did this situation come with any beep sound. Because, most of the time, in this situation; the computer beeps. Here are some codes. Check if any of these condition apply to your system.
No Beeps Short, No power, Bad CPU/MB, Loose Peripherals
One Beep Everything is normal and Computer POSTed fine
Two Beeps POST/CMOS Error
One Long Beep, One Short Beep Motherboard Problem
One Long Beep, Two Short Beeps Video Problem
One Long Beep, Three Short Beeps Video Problem
Three Long Beeps Keyboard Error
Repeated Long Beeps Memory Error
Continuous Hi-Lo Beeps CPU Overheating
best of luck!
Mar 07, 2012 | Gateway 510XL (2800446) PC Desktop
Gateway GT5058 no post, no beeps - power supply is OK, hard drive spins up, fron panel LED's light up.
Power-down the PC.
Remove all of the RAM modules.
Power-up the PC.
You SHOULD hear a series of Beeps. This is the Motherboard complaining that there is no RAM installed....this is normal.
*IF* you do NOT hear any Beeping, then the Motherboard is bad and would need replacing.....however depending on the age of the PC, it is usually not cost effective to do this, and sometimes you can't find just a Motherboard for sale and have to buy a whole used PC (same make/model,) and put your HD into it.
Post back with what the above test showed you.
Oct 30, 2010 | Gateway GT5058 Desktop PC
I have no video - monitor works with other PC. How can I trouble shoot?
Does the "broken" PC Beep. How many times ? That's called a post code and different BIOS have different codes.
Check the Beep code based on the PC BIOS (check gateway's site or open the case at your own liability and read the BIOS chip label).
If the POST code indicates video replace the card and disable the integrated video if it's on the motherboard. On some BIOS's 3 beeps is bad video on others it different - you have to find the BIOS's POST sheet.
If it's a normal POST code for that BIOS then..... hmmm dunno - replace the video card anyways ? ;-)
Feb 17, 2010 | Gateway 506GR PC Desktop
WHEN i turn on computer i hear 3 beeps and thats it
Hello davidm08868,
Three beep codes at power on self-test (POST) usually indicate a general hardware failure. If the bios is AMI, the three beeps mean Base 64K RAM failure. If that's the cae then try reseating the memory cards.
Here's a web link that has some information about Bios beep Codes: http://webpages.charter.net/dperr/beepcode.htm
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
Have a great day,
martyshaw152
Jan 29, 2010 | Gateway 507GR PC Desktop
Beep codes are here
Jun 30, 2009 | Gateway Computers & Internet
Tower pushing out air and beeping and can't turn on PC
the beeping is post codes. they are telling you something is wrong. the code is a code for what is wrong like 3 beeps 4 beeps 1 Beep then repeatsthat code is 341. first thing i would do is pull out you ram and reseat it. that is the most common problem.
Jun 23, 2009 | Gateway 838GM (RB838GM) PC Desktop
Gateway 838gm
Does the computer beep when you turn it on? If so, count the beeps and google it. Something like "computer beep 3 times at post" or similar.
If it does not beep, remove all buy one of your memory chips. (mind your static charge, keep in touch with your computer case so you don't fry your mobo or memory) Will the system post with only one chip? If not, try all of your memory chips one at a time. Post now? If so, you can narrow down the issue.
If this doesn't work, remove all of the cards. (video, sound, network, etc) Turn the computer back on. If it still does not beep, it is very likely that the CPU is the culprit, with a slight left field chance of it being the power supply.
Jan 17, 2009 | Gateway 838GM (RB838GM) PC Desktop
Computers & Internet Logo
226 people viewed this question
David Payne
David Payne
