Question about RCA H100 MP3 Player
It died on me and now it won't turn on.
I've had this player for about three months. Yesterday I was listening to it and the thing just shut off and now it won't turn back on, or charge. Any ideas on how to fix it or what might be wrong?
  • 4,472 Answers
1995 Olds Silhouette rattled badly, died while running
I think you had better have a local shop inspect this for a failed engine connecting rod.
Aug 23, 2012 | Oldsmobile Silhouette Cars & Trucks
I have a 2 cycle Troy-Bilt TB90BC line trimmer. Won't idle. I've had the carburetor dipped, installed a new carb kit, replace the gas lines, but will only run at full speeds. Dies out easily....
One of three things is occuring here. The IDLE SPEED SCREW (Phillips head) on the throttle plate is screwed in way too far. The L and H mixture screws are open way too much allowing the carb to use excessive fuel, even on startup. Those 2 screws may need adjusting. The metering lever in your carb is not adjusted flush with the carb body flange and is holding the gas needle open constantly. Check these things and post back.
Sep 09, 2011 | Troy Garden
My Toshiba BDX 2500ku won't turn on...Ive used it before...now it won't even open...please help....its only about 4 months old and we've only watched about 2 movies....
check the back of the player to see if the power cord has come loose, some units have a removable cord and it can get pulled.
Jun 20, 2011 | Toshiba BDX2000 Blu-Ray Player
The mp3 player is an element gc-823. I just finis...
Mine is doing the same thing exect that if you unplug the head phones from mine you can hear music how do I shut the external speakers and listen to it with head phones? kdalton05@swva.net
May 19, 2010 | Audio Players & Recorders
My 2000 road king fuel injection starts right up runs a few moments and dies and will start back up but will not run long, it just started this yesterday
this could be a couple of different things first thing is to make sure your fuel pump pressures up the system,turn on ignition and listen for your fuel pump to come on,second is to your ignition on and off at least two or three more times this will reset your idle air contol.(make sure you are not on the throttle when you shut the bike off) If this does not clear up the problem you could have a bad senser or loose connection. good luck
Mar 13, 2010 | 2000 Harley Davidson FLHR-FLHRI Road king
The engine just shut off while driving my 2000 windstar SEL
I would start by getting the trouble codes then go from there.
there has been a common issue with windstars http://www.fordwindstarrecall.info/#Problem1 it might be the issue
Sep 26, 2009 | 2000 Ford Windstar
The screen is turning white when I change song
You could possibly try recovery mode?
or formatting it and starting over, see if that helps
easy way to format
1.Shutdown player
2.Hold Rec button
3.Turn player on
4.Plug your player into the PC
5.Go to My computer
6.Find a Icon named 16Mb Format
7.Open that and make a new text file
8.Name it sansa.fmt
9.unplug player and it will say Formatting.....
10.when its finished it will reset , or shut off, when its done turn it on and see if that helps
May 08, 2008 | SanDisk Sansa e260 MP3 Player
Why is my battery draining so fast?
you must hear only two songs per day.
Aug 11, 2007 | SanDisk Sansa e130 MP3 Player
Mp3 Problem...
format it man. it will be alright.
Feb 27, 2007 | SanDisk Sansa m230 MP3 Player
RCA H100 MP3 Player Logo
18 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
