Question about Linksys Wireless-G WRT54G Router
My computer is picking up the wireless connection but won't connect to the internet.
    Problem Solver:
  • 7 Answers
When you say picking up the wireless connection, you mean you are associated to the Router? If you goto Start, then Run, and type in "CMD" and press enter it will open a new window. Then type in "ipconfig /all" into the window and let me know what it says. You should have an IP address, Subnet Mask, Default Gateway, and at least one DNS server. If any of those are missing its not going to work.
Posted on Nov 10, 2010
DOESN'T DETECT WIFI
The wireless feature on a Gateway computer allows you to connect to a network without the hassle of cables. This allows you to browse the Internet conveniently wherever you are. Gateway computers rely on Windows operating systems, which come with a built-in feature to manage your wireless connection. This feature makes turning off your wireless connection an easy process if, for a moment, you prefer to connect to the Internet using a wired connection.
Click the Windows "Start" menu and click the "Control Panel." Click Network and Internet Connections > Network Connection, if you are using a Windows XP Gateway computer. You should see your wireless connection. For Windows Vista and 7 Gateway computers, click "Network and Sharing Center" from the Control Panel and click "Manage Wireless Connections." You should see your wireless connection. Right-click your wireless connection and click "Disable" to turn it off. Close "Network Connections" when you are done.
Mar 03, 2013 | Gateway ONE GZ7108 All-in-One Desktop PC
Acer Aspire 7540 won't connect to wireless or ethernet
Ensure the Acer software is installed along with the system and boards drivers.
Jan 10, 2018 | Acer Computers & Internet
INTERNET NOT WORKING, WON'T PICK UP WIRELESS FOR SURE. THE LIGHT DOESN'T EVEN COME ON FOR WIRELESS. IT'S A DELL INSPIRION 1525. ANY HELP?
You sayin you download the new drivers for the wireless card? Check your device manager tab in control panel and see if the networks adapter is red or yellow. It should say what is wrong with it
Feb 15, 2012 | HP Pavilion Computers & Internet
Why won't laptop connect to wireless internet? Wifi is working, another computer in home is fine
are you at home or Starbuck? location matters.
so, the compaq must be setup correctly.
your router broadcasts the SSID name seen by you on all devices, see that on the Compaq (y/n)
then you must pick wep. or wpa, or wpa2 encyption mode.
as set in your router, we cant see inside you router only you can
then set the passphrase to what you router wants.
is this XP, windows
does the wifi chip look ok in device manager?
Is XP infected.? with malware as all are now.
never post about computers lacking what operating system you have, or answers will be wrong, even all answers.
Feb 12, 2018 | Compaq Presario CQ62-215DX Laptop
Was working ok then internet down and red light on router constant - have done the turn off turn on routine and reset router to no avail. have also plugged indirectly to computer - green light then comes...
Try rebooting both the modem and the router. It could be that the modem didn't pick up it's ip number when the internet went down. Then try pluggint you computer directly into the modem first to make sure it is setup and working properly. Then plug in the router (to the modem) and the PC plugged in directly to the router and check.
Once you have it connecting at that point then check the wireless settings on both the router and the pc. Then enable the wireless on the pc, unplug the LAN and switch to wireless network on the pc and see if it won't work.
If it works plugged in on the LAN but then not on the wireless then either your configuration isn't correct (ie wrong gateway ip number...gateway should be the same ip number as the router...ie 192.168.***.***) or perhaps the wireless part of the router died. It is possible for the wireless to die and the LAN (hard wired connection) to still work.
Aug 08, 2011 | Belkin N Wireless Router wireless router
Unable to connect to the my wireless Internet
Try "rebooting" your internet. If it's fed through a router, disconnect the power to the router, as well as all of the connections, then reconnect them. Re-connect the power last.
Also, try moving closer to the source of your wireless internet. Sometimes the Dsi won't pick up on the signal because it has a weaker wireless receiver than a computer or most devices that will connect.
May 19, 2011 | Nintendo Dsi Pink Console
My computers are picking up the wireless but can't connect to the internet
It's a good thing that your computers are picking up the Wifi connection. But the connection to the Internet is another matter. Call tech support of your ISP (Internet Service Provider) to make sure that your Modem (Cable or DSL) is configured to connect to the Internet at all.
Jan 31, 2011 | D-Link AirPlus Xtreme G DI-624 Wireless...
Using a Acer Aspire Revo. Running with linux Unbuntu 10.4lts. I have a BTHomeHub trying to connect my NWD-270N Wireless N-lite USB Adapter however it picked up the Hub and established a connection...
Select from the computers default internet networks, Recent computers are wireless enabled as the prefered networking. Attempting to introduce another network would share the connection capacity to any availabe signals. decide on the network type required. Pick wireless and disable the remaining networks to achieve an express signal reception and transmition.
Jan 29, 2011 | Zyxel NWD270N Wireless N USB Adapter...
My dell inspiron e1505 tells me that it cannot pick up wireless networks. My computer was picking up wireless earlier today in front half of house. we extended the signal via ethernet cord and plugged in...
Depends apon the signal and how you have the computer settings some of the older computers have programs where differant places will not be picked up !
Did you check your internet options in your control panel?
1.Check your internet options and see if your lan settings have a check mark in the top box for lan atuomatic detect settings click ok then your internet should pick up ..... if you are still haveing prombelms please let me know ... Lala linda
has a check mark on the top box so there is a
Dec 24, 2009 | Dell Inspiron 1501 Notebook
I cannot pick up a internet connection
Click on Start - Control Panel - then Network Connections - then right click on your Wireless Network connection - click on Properties.
Then in "This connection uses the following items, scroll down to Internet Protocol (TCP/IP) and click on Properties. Under the General Tab make sure Obtain an IP address automatically and Obtain DNS server address automatically are selected. Click OK.
If you do not see TCP/IP in the Wireless Network Connection then click on the install button and then install the TCP/IP driver.
IF TCP/IP is OK then before you do the following, turn off or disconnect the power to your wireless router, wait for 1 minute before connecting the power again. Wait till the LED lights indicate that it is on line again and the wireless is on then :-
Click on Start - Control Panel - then Network Connections - then right click on your Wireless Network connection - click on View Available Wireless Networks
Do you see your wireless network (ie. your wireless router)?
If so click on your wireless router and then click Connect.
You can also click on Repair to try to reconnect to your wireless router.
Let me know if it works.
Feb 28, 2009 | HP Computers & Internet
Linksys Wireless-G WRT54G Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
