Question about Phil & Teds Baby Gear
My tyres is flat and making a noise when it is pushed is it just needing pumping or is it needing a new inner tube
    Guru:
  • 541 Answers
Visit your local bike shop they'll pump up the tires and replace the tubes if required.
Posted on Nov 11, 2010
I need a place to change my dirtbike tire and tube
get 4 bricks and place wheel on top , release air , stand on the tyre to push it off the seal , both sides , then carefully lever tyre over outer edge , make sure to push one edge of tyre in and DONT CATCH THE INNER TUBE ! take inner tube out and do the same the other side ! get new tyre and replace in reverse order !
May 01, 2014 | Motorcycles
The tyre keeps going flat. The valve on the inner tube was replaced and the tyre pumped up, but by the time I got the tyre home it had depflated again. There was a worn area on the inner tube and there...
Not a guru on Bertini but most strollers with pneumatic tires use standard tyres and tubes as used on kiddy bikes. I get tyres for Bugaboo's at my local K Mart. The size should be on the side wall of the tyre.
Apr 23, 2011 | Baby Gear
Back wheels keep deflating
hi, the chances are you have a puncture os something sharp sticking into the inner tube inside the tyre, what you need to do is buy a puncture repair kit then using the repair kit you take the tyre off the wheel then take the inner tube out.
now blow the inner tube up and place it in bowl of water and you should see bubbles coming off the inner tube, mark this with pen when dry so you know where the whole is, now use the puncture kit and place a patch over the whole, you can buy glue type patches or stick on patches without glue, you peel the back off the patch and put glue on or stick it over the whole if its a stick on patch and not glue.
then whilst this dry run your fingers around the inside of the tyre and check for any thorns or something sharp sticking in the tyre if you feel anything remove it and you should be ok, then when glue dry put the inner tube back in tyre and fit the tyre back on wheel now when you pump it up it shouldnt go back down unless you get another puncture.
if you are unsure what you are doing then taking your stroller into any bike shop and ask them to repair the punctures for you and they will do this for you whilst you wait.
Jul 10, 2010 | Quinny Buzz Three Wheel Stroller
My quinny rear wheel keeps losing air, ive replaced inner tube but it keeps going flat
Hi it sounds like you have something stuck in th tyre itself that is punturing the new inner tube, take them out & feel inside the tyre if there is anything sharp there remove it. Then you can repair the tubes.
May 30, 2010 | Quinny Baby Gear
My quinny rear tyre is flat tried to inflate the tyre but still does not work what should i look out for
you have a few choices
but if you want a long term fix you are better off getting a new inner tube as once a puncture occurs with the quinny wheels they will carry on doing it but theey are cheap enough to replace via ebay for about £6
if you dont want to replace you will need to remove the rubber wheel from the hub as you would a bike tyre then remove the inner tube
pump the tyre up put in water so you can find the hole then fix with a puncture repair kit
if you want to carry on using you can fill the tyres with tyre weld as you would a car they dont puncture and makes the quinny a smother ride
and if all else fails you can buy a used or new pair of wheels from ebay between £15 and £30
hope this helps x
Dec 14, 2009 | Quinny Buzz Three Wheel Stroller
How do you fix a flat tyre on a maxi cosi mura?
If you have a puncture and there is only one hole, you can get a puncture repair kit for bikes from somewhere like Halfords and repair the inner tube.
I found the inner tube on one of our tyres was faulty and there were about 20 small holes around the seam. I got a bit fed up with arguing whether or not the guarantee should cover this and so we ended up buying a new inner tube from our local tyre place http://www.etbtyres.co.uk/ it was only £5.
Sep 28, 2009 | Maxi-Cosi Baby Gear
Where can i buy new inner tubes for the phil & ted old version e3 local to southgate , london n14. where can i check that tyres are still ok as a very old pram
I think that these are standard 12 inch inner tubes, so would recommend that you purchase these from a local bike store, a lot cheaper and should do the trick fine. Note, if you can get a hold of the inner tubes with the bent valves, this will make pumping the tyres much easier. Failing that, contact Out n About who will help you.
I hope this helps.
Sep 10, 2009 | Baby Gear
Flat tire, S500
The wheel will have to be removed firstly.
Then with something blunt, (like a spoon handle, not too flexible, and smooth,)
carefully pry up the bead of the tyre over the rim of the wheel, now it's easier to take a second lever or spoon handle, and repeat the process, a couple of inches away from the first.
Then you should easily be able to run the smooth lever, around the tyre and rim, to expose the tube.
Then push the valve through the wheel, if neccesary, and remove the tube.
You should also inspect the inside of the tyre, thoroughly, to make sure that there isn't anything in there that shouldn't be.
After you are sure all is well, just reverse the procedure.
Just make sure that the tube does not get 'pinched' between the tyre and wheel.
Hope that helps.
Jul 12, 2009 | Schwinn Windwood 26 Women s Cruiser...
Front tyre is flat..
I've had two flats on the back tyre on my jane power twin - the first time myself and my husband bought a tyre puncture kit and fixed it. The second time we tried the same thing but the puncture was in such an awkward position that the patch wouldn't adhere to the tyre so I needed a replacement. I went to my nearest Mothercare shop which sells the power twin and asked them to order me a new tyre. It took a week but the part came it and it wasn't just a tyre it was a whole back wheel. They charged me 10 euros (7 Stg approx). Hope this helps.
Dec 19, 2007 | Jane Powertwin Azulon Stroller
Help- wheel problem!
Call or email the company. I had the same problem and they sent me a new inner tube for free b/c my stroller was still under warranty (yours should be too). I took the new tube and the stroller to a bike shop where they finished the repair for me for $5.
Oct 06, 2006 | Bugaboo Cameleon Jogger
Baby Gear Logo
89 people viewed this question
Top Phil & Teds Baby Gear Experts
Jennifer Rock
Jennifer Rock
ray gallant
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Phil & Teds Baby Gear Expert? Answer questions, earn points and help others
