Question about Dell POWEREDGE 2400 Server
I am try to do the usb in the bios to enable but no respone to do enabled
  • sawalhaia Nov 10, 2010
    ok thanks but what can i do
    please help
    Problem Solver:
  • 12 Answers
Please elaborate on your problem.
If you are trying to install from USB, you first have to enable the USB in the BIOS.
Older models of Dell PowerEdge servers does not support the USB function. It is all dependent on the mother board.
Posted on Nov 10, 2010
Testimonial: "good note"
My USB port is off, how do i turn it back on? also, no enable option
u gotta change that in BIOS !!! restart the system boot to BIOS and change the setting in decive configuration.
Jan 07, 2015 | Computers & Internet
How to use a usb keyboard
as a P/S2 keyboard.plug it in the USB contact in the back.in any USB port.
Apr 08, 2013 | Dell Inspiron One 2305 Desktop Computer...
Keyboad failure on dell gx520 boot
Usb or Ps2 keyboard ?
Shut down the computer and disconnect the USB keyboard. Connect a PS/2 keyboard to the PS/2 connector port on the rear of the computer. Enter bios restart your computer you will see a certain to press to enter set up usually the Delete or the F2 key this will vary depending on you computer and bios. Wait for the main BIOS setup screen to appear. Press the right or left arrow keys to move the cursor to the "Advanced" or "Advanced Settings" menu option. Press the "Enter" key. Move the cursor to the "Integrated Peripherals" or "Peripheral Configuration" menu option. Press the "Enter" key. Press the down-arrow key to navigate to the "USB Controllers" option. Press the "+" or "-" key to change the menu option to "Enabled." Move the cursor to the "USB Legacy Support" or "USB Legacy Function" field. Press the "+" key repeatedly until the value option changes to "Enabled." Press the "F10" key to save changes to the BIOS settings and exit the setup utility. Wait until the computer begins to restart and then press the power button and hold it for approximately four or five seconds. The computer shuts down completely. Unplug the PS/2 keyboard from the computer and set it aside. Reconnect the USB keyboard restart the computer. As soon as you see the initial boot screen, tap the "Delete" key several times and wait for the BIOS setup screen to appear. If you are able to access the BIOS setup screen with the USB keyboard, USB support is active in the BIOS.
Enable PS2 & USB in BIOS You can enable PS2 and USB settings in BIOS by entering the BIOS setup screen when the computer boots. You will need to changes to the appropriate settings in this screen. The exact procedures vary by system, but there are a few common methods that may work if the motherboard manual is not available for guidance. The general procedure is the same for any modern computer system, but the menu arrangement and keystrokes to enter the setup program can vary greatly from one machine to the next. Power on or restart the computer and watch the initial boot screen to find the keystroke required to enter BIOS setup. This is often shown at the bottom of the screen. Typical keystrokes include pressing the "F1," "F2," "F9," "F10" or "Del" key. Press this key when the prompt appears on the screen. You can find the proper key in the computer's motherboard manual or on the website of the motherboard or computer manufacturer. Enter the BIOS setup screen and look for the "Advanced" or "Onboard Device Configuration" menu. Use the arrows to select your choice and press "Enter." Change the settings for the PS2 port by moving the menu choice to the "PS2" setting. Press "Enter" to bring up a smaller menu with the options to enable or disable the PS2 ports. Select "Enabled." You can also use the arrow keys or the plus key to change the current selection from "Disabled" to "Enabled" in order to enable the PS2 port. Change the settings for the USB port by moving the menu choice to the "USB" setting. Press "Enter" to bring up a smaller menu with options to enable or disable the USB ports. Select "Enabled." Alternatively, use the arrow keys or the plus key to change the current selection from "Disabled" to "Enabled" in order to enable the USB port. Save the settings and exit by pressing "F10" or using the "Esc" key to back out of the current menu. Choose to save and exit from the main menu if needed. Follow any additional instructions on the screen to save or navigate the menus. Hope this helps.
Dec 13, 2012 | Dell OptiPlex GX520 PC Desktop
Sharp notebook pc usb port problem
Try going into the Bios or System Setup and make sure the USB is enabled in it. When you turn on the computer notice what key the screen says to hit to get into the Bios or System Setup. Hit that key and look through the Bios for USB. Since your system is old running Windows 95 it might says something in the Bios about Legacy USB ports.
May 03, 2012 | Computers & Internet
How do I enable a disabled CD drive? The BIOS page does not appear to give me any options. The PC
you can enabledisable the CD drive and USB in the BIOS or go to
regedit:
Hkey_Local_machine\system\CurrentControlSet\dervices\cdrom\start
1=enable, 0=enable
hkey_local_machine\system\CurrentControlSet\devices\usbstor\start
3=enable, 4=enable
May 08, 2011 | Computers & Internet
I have a problem with key bord. i have the latest new keybord. and it's not working.and i put another keyu bord but that also not works. how to solve this problem ?
hello,
you will have to check the BIOS to enable USB keyboard,
to get into the BIOS press F2 or Del to get into the BIOS,
search the setting and look for USB enabled
change it to USB enabled,
press F10
save and exit
it should work now.
Dec 20, 2010 | Intel Motherboard
Setting bios to boot from a usb stick with an abit it7
If your motherboard supports it, it should be enabled by default. If it's not enabled and your motherboard does support it, then you can enable it by selecting the option from the BIOS menu. During boot up, press F2 to access the BIOS. Then, you should see an option that either says, "Boot from USB" or "Boot from External Device". Enable it by pressing enter and then selecting "Enable", If neither of these two options are available or something similar to it, then your motherboard does not support it.
Apr 22, 2010 | Abit IT7-MAX Motherboard
Please can you give steps to disable the onboard usb controllers to use the CPI USB Card. I've installed the PCI Card after the onboard stop working
2.4.2 USB Configuration
The items in this menu allows you to change the USB-related features.
Select an item then press <Enter> to display the configuration options
USB Function [Enabled]
Allows you to enable or disable the USB function.
Configuration options: [Disabled] [Enabled]
Legacy USB Support [Auto]
Allows you to enable or disable support for USB devices on legacy
operating systems (OS). Setting to Auto allows the system to detect the
presence of USB devices at startup. If detected, the USB controller legacy
mode is enabled. If no USB device is detected, the legacy USB support is
disabled. Configuration options: [Disabled] [Enabled] [Auto]
USB 2.0 Controller [Enabled]
Allows you to enable or disable the USB 2.0 controller.
USB 2.0 Controller Mode [HiSpeed]
Allows you to configure the USB 2.0 controller in HiSpeed (480 Mbps) or
Full Speed (12 Mbps). Configuration options: [HiSpeed] [Full Speed]
BIOS EHCI Hand-off [Disabled]
Allows you to enable support for operating systems without an EHCI
hand-off feature. Configuration options: [Enabled] [Disabled]
NOTE!!!
Do not disable the BIOS EHCI Hand-Off option if you are running a
Windows® operating system with USB device
hope above given details with give you a detailed description as you desired.
good luck
Feb 04, 2010 | ASUS P5LD2-VM Motherboard
Hp wireless mouse not getting detected by dell inspiron 1545
First, boot to system BIOS. Check BIOS to see if USB is enabled and might as well enable legacy USB devices as well. To enter BIOS, press enter in most cases. If BIOS checks ok and USB is enabled, your problem is one of two things:
a) You do not have the proper driver for the USB infrared device (download proper driver)
b) The device is not plugged all the way in the USB port or batteries are low, incorrectly installed or have no batteries.
Jan 23, 2010 | HP Wireless Optical Mouse
Ga-6vxd7 keyboard wont work to boot from cd
Plug the USB keyboard into another port (preferably one at the back) restart the PC and enter the BIOS again, this time go through the BIOS and set all the USB controllers to enabled, hit F10 save the changes and exit the bios. The computer will restart and you should now be able to use the USB keyboard to install the OS.
Please post back if you need anymore advice.
Good luck
Jun 15, 2009 | Gigabyte GA-6VXD7 Motherboard
Dell POWEREDGE 2400 Server Logo
133 people viewed this question
Alun Cox
