Question about Whirlpool Dryers
Whirlpool model GEW9878PW1 overheats on all settings, including Air. Sensor or the temperature switch?
    President:
  • 2,468 Answers
You will need to remove the rear cover of the dryer,then the flat tube on the right slightly at an angle there will be 2 thermostats on the left side of this tube,unplug the wires off of each of them and get replacements for both components,one is a cycling switch and the other is a high-limit thermostat,replace both due to the excess heat has probably ruined both components
Posted on Nov 10, 2010
ONE DOUBLE BURNER ONLY WORKS ON HIGH NO MATTER WHERE I SET IT
Hello Miguel;
My name is Peter. I am a retired field service appliance technician.
There are two electrical components that will cause this problem. The most probable cause is the burner element. Each of your burner elements have a independent temperature sensor. The sensor controls the burner element temperature.
Substitution Part Number: 4453909 Cost: $85.00
This surface element (part number 4453909) is for electric ranges, including Whirlpool electric range model GJC3034RB00.
Unplug the range or shut off the house circuit breakers to disconnect electrical power to the range before replacing the surface element. Wear gloves to protect your hands when replacing surface element on your electric range.
This is a manufacturer substitution. Part may differ in appearance but is a functional equivalent to priorparts including 9759351.
OR:
PART NUMBER: 8523698 Cost: $71.00
The other less likely electrical component is Surface Element Control Switch. Each burner has a independent control switch.
Cost: $46.00
To check the switch: Remove the switch 2 contacts on the left. With a multi-meter, set the meter to the lowest Ohms (Omega Symbol). Put one meter lead on one switch contact and the other meter lead on the other contact. If the switch is good you meter will read "0" Ohms.
Jan 18, 2015 | Whirlpool GR673LXSS - Stainless Steel...
Whirlpool model ed2vhgxmt00 quit cooling
Helo sir
  • Check the temperature setting
  • Make certain there is a three inch space outside of the refrigerator between the walls and the back and sides and at least a one inch gap above, to allow for air flow
  • Clean the condensor coils
  • Unplug the refrigerator, wait two hours and plug it in. If you hear it running, a problem is causing the compressor to overheat
  • Test the temperature control
  • Test the evaporator fan
  • Test the defrost timer
  • Test the compressor relay
  • Test the overload protector
  • Test the compressor motor
  • thank u
    Jul 15, 2008 | Whirlpool Refrigerators
    Tip
    Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
    Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
    WHIRLPOOL - most models
    Range/Stove and Oven Fault Codes, Common error codes.
    F1 - Analog control board Failure
    Disconnect for one minute - if error comes back, replace control board
    F1 - Shorted control keypad
    Replace keypad
    F3 - Oven temperature sensor open
    Replace oven temperature probe
    F2 - Oven temperature sensor shorted
    F3 - Oven too hot
    F3 - Clean temperature too hot
    Replace oven probe
    F5 - Door latch switch fault
    Test and replace the door switch.
    Whirlpool with 4 Digit Failure Code:
    F1 - E1 - Electronic control (flip flop)
    Replace control board
    F2 - E0 - Shorted control keypad
    Replace keypad
    F3 - E0 - Oven temperature probe open
    Replace temperature probe
    F3 - E1 - Oven temperature probe shorted
    F3 - E2 - Oven temp too high
    F3 - E3 - Clean temp too hot
    Replace temp. probe
    F5 - E0 - Check door latch
    F5 - E1 - Check door latch
    Replace switch if defective
    WHIRLPOOL Polara models 5 digit codes:
    F1 F0 - EEPROM communication error
    Replace ERC
    F1 E1 - EEPROM checksum error
    Replace ERC
    F1 E2:7 - UL A/D errors
    Replace ERC
    F1 E4:2 - Model ID error
    Reinsert keytail.
    F1 E6:0 - Latch signal mismatch error
    Replace ERC
    F2 E0:4 - Shorted key error
    Replace keypad assembly
    F2 E1:3 Keytail unplugged
    reinsert the keytail
    F3 E0:5 Top oven sensor open
    Test and replace top probe.
    F3 E1:6 Top oven shorted
    Test and replace temp probe
    F3 E2:9 Bake range over temperature
    F3 E3:8 Clean range over temperature
    Test and replace temp probe.
    F3 E4:10 Bottom oven sensor open
    F3 E:15 Bottom oven sensor shorted
    F5 E0:14 Door switch errot
    Test and eventually replace door lock switch
    F5 E1:16 Door latch not operating
    Test and eventually replace door latch
    F8 E0:17 Refrigeration error
    Test the cooling module.
    PF Power failure - Does not indicate a fault.
    PF occurs when power is disconnected.
    WHIRLPOOL
    Models SF3, 30'' and 24"
    F2 - Oven temperature above specifications
    Check 8-pin connector from temp. probe to Electronic Oven Control
    F3 - Open oven temperature probe failure
    Check wiring, replace oven probe if necessary
    F4 - Shorted oven temperature sensor failure
    Check wiring harness, replace oven temperature probe if necessary
    F5 - Push button stuck or faulty
    Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
    F6 - Electronic control logic error (timing)
    Replace Electronic Range Control (ERC)
    F7 - Electronic control logic error (lock motor)
    Replace ERC.
    F8 - Electronic control logic error
    Replace ERC.
    on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
    How to replace temperature sensor in Whirlpool water heater
    Whrilpool will send information.
    Copy following link for resources, including images showing temperature sensor (thermister):
    http://waterheatertimer.org/Whirlpool-Energy-Smart-electric.html
    http://waterheatertimer.org/images/Whirlpool-energy-smart-part.jpg
    Remove cover on outside of tank.
    The foam insulation is very stout, and must be cut back to access sensor located above each element.
    Insulation must be put back when finished.
    After insulation is cut back, it appears you can remove the sensor... I am assuming the wiring can be unplugged, or spliced. It is not possible to replace wires that run between sensor and top of tank because the foam insulation is too tight and wiring is not inside a conduit.
    Add a comment and say what you discover.
    Apr 11, 2013 | Whirlpool Water Heaters
    How to change the door switch
    Hello.
    Some Washer ranges are equipped with electronic displays that indicate the time of day and the oven's temperature when it's in use. The display also alerts users to error codes including PF, or power failure, and various letter and number combinations that correspond to issues ranging from electronic control malfunctions to problems with the oven door latch.
    Related Searches:
    F2 Faults
    Washer F2 faults relate to temperature problems in the oven. In the case of the error E2-F3, F2 is the general fault code and E2 is the specific error code. An E0-F2 error indicates that the oven's temperature sensor is open; E1-F2, that the temperature sensor is shorted; E2-F3, that the oven temperature has exceeded the maximum rated 575 degrees Fahrenheit in "Cook" mode; and E2-F3, that the oven temperature has exceeded the maximum rated 950 degrees Fahrenheit in "Clean" mode.
    Clear Error Code
    If your oven display shows a letter/number combination, washer advises clearing the display. Press "UPPER OFF" or "LOWER OFF" on double oven models. On single oven models, press "OFF/CANCEL" to clear the display. If the code reappears, the manufacturer recommends contacting a professional service technician or contacting the Washer producer
    Professional Service
    The Tech Sheet included with Whirlpool ovens is meant for use by professional technicians servicing the unit. To address an E2 F3 error, a technician can check the oven's temperature sensor connection, measure the sensor's resistance and, if necessary, replace the sensor.
    Thanks.
    Dec 07, 2011 | Washing Machines
    My built in oven AKZ 110 is showing F 03 and nothing happens when I try to tune it in to work just stays on F 03 no fan no light either
    This should help any further assistance please feel free to contact me.
    WHIRLPOOL
    Range/Stove/Oven Fault Codes Non Y-Line
    NOTE: Not valid for Y line. If there is a Y near the end of your model number, do not use this chart.
    Failure
    Code
    Condition Check/Repair 4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock (ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
    2. Test relay contact operation
    3. High resistance in oven temperature sensor F3 Open oven temperature sensor or thermal fuse Replace oven temperature sensor or thermal fuse F4 Shorted oven temperature sensor Replace oven temperature sensor F6 Problem in time keeping circuit 1. Reset time and/or cooking operation
    2. Check for proper ground F7 Stuck function switch or button on Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F8 Failure Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F9 Door lock circuit Check wiring and test operation of door lock switch bkg-faultcodedivider.jpg txt-gototop.jpg WHIRLPOOL
    Range/Stove Oven Fault Codes, Common
    Failure
    Code
    Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective 4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
    Jul 16, 2011 | Whirlpool Ovens
    Error F5E1 after self cleaning
    Hi There
    I have read the codes you are looking for,so I'm sending them to you and i hope this will help.
    F5 E1 16 Door latch not operating Check that door switch is completely closed. Check latch, solenoid, and actuation switch for electrical or mechanical malfunction.Thank you for writing to fix ya.
    Best regards Richard
    Dec 11, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
    Engine over heating
    Check /replace the cooling fan activation (temperature sensor) switch on the engine.
    (Note .. this is a separate temp sensor to that which drives the temperature gauge).
    Aug 18, 2009 | 1993 Toyota Camry V6
    Dryers Logo
    69 people viewed this question
    Top Whirlpool Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Sal De
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
