Question about HP Vs17 17" LCD Flat Panel Monitor
The Power Off - On button tip broke and fell out of the frame housing. Luckily the monitor is in the On position so it is in use. Can the button tip be replaced so that the On - Off feature may be restored?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 93 Answers
Yes the button can be fixed, but you should go to a mechanic or try an expert on it, do not try it yourself.
Posted on Nov 10, 2010
The power button broke off
Best way to fix this is to take off the board that is over the power button and hot glue the button back in place. Only apply glue to the side of the button where it hinges - the other side needs to move freely or it won't contact the switch and operate correctly.
Nov 18, 2012 | Sony STR-D965 Receiver
Power light or screen will not come on my hp w2007 monitor. It's only 13 months old.
Possible answer as I had same issue. I found the button you press has small tip that presses the actual switch to turn the monitor on. My tip broke off so switch can not be made. Hp does not sell button as that is what I am looking for myself.
Dec 13, 2009 | HP W2007 LCD Monitor
Power button blinking and no screen...just black. What to do?
I just did this to a friends monitor as well, a different model and not much different in build. I think you might have 3 screws on lower back side of cover. Start your separation from the bottom of the frame.Your power switch will remain on the front frame while the wire will remain with the rest.
HOW TO OPEN A SYNCMASTER2.gif 2053BW
NO SCREWS!!! Assuming that the stand mount has been pulled out..The seam around the screen frame is where you start. The frame has the prongs, the back cover has what the prongs slip over.The frame is coming off first! I got the side to open by finger, then used a small standard screwdriver to pry ever so gently(lifting frame from rearcover). Leave the power button assembly on the frame, pull wire only a little to relax any tension..you get about 3/4" in extra taped to panel. The hard part is done.;) Still holding the frame...Now lift the panel (where the power button assembly wiring goes under panel) with the power housing that is under it as a whole and you will see where the powerbuttonassemble detaches.Remove frame. Now..holding edges of panel into back cover, lift and flip the whole thing over and place panel face down on a perfectly flat surface..a towel on my desk works. Lift and remove back cover.Your now looking at the back of the board housing. The ribon is simple, on the panel end of the ribon, squeez the outer clips together and slide it away against the panel..The secondary tin plate is removable(if you need to remove it), two clips super close to where the sets of wires come around the housing and into the panel. Unhook the 4 plugs(blues and pinks)...Now lift the power housing off of the panel. The big board has the power. One screw to remove a ground plate first. Two screws to remove power board. Pics from phone.56ec44b.jpg
aae8fab.jpg The capacitors top-plain should be flat(not rounded) and there should be no color whatsoever coming through the top of the cap lines(google "bad capacitors"). The specs of the cap are on the cap. The 2 caps cost me $4.00. Now keep in mind there are hazards to this.Google them;)
Nov 17, 2009 | Samsung SyncMaster 204BW LCD Monitor
My Samsung SyncMaster 2463UW no longer auto detects the video input. I normally use it with my MacBook Pro - I turn it on, it detects the digital output and Bob's your uncle. Today, I turned it on and it...
OK UncleBob...Try this for me..does hitting the menu button on the monitor do anything for you?..NO huh...Do any of the other buttons (besides power) do anything for you?..Probably not?! Your in the early stages of my fixed problem...Is your warranty still good?lol I had to throw that one in....So ....
Power button is flashing.. input box is floating around and changing input signals...well first
try another monitor on your computer. The other monitor works huh?!
I just did this to a friends monitor as well as my own, a different model and not much different in build. Some might have 3 screws on the lower back side of the cover. If not then proceed to How to open a Samsung SyncMaster 2053bw.. Start your separation from the bottom of the frame.Your power switch will remain on the front frame while the wire will remain with the rest.
aae8fab.jpg The capacitors top-plain should be flat(not rounded) and there should be no color whatsoever coming through the top of the cap lines(google "bad capacitors"). The specs of the cap are on the cap. Markings on the cap and board show how it is installed. The 2 caps cost me $4.00. Now keep in mind there are hazards to this.Google them;)
Nov 09, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Monitor turns off after 2secs power light on
Oct 23, 2009- This is how it went for me..I have a Samsung SYNCMASTER2.gif 2053BW. I leave my monitor on and let it hybernate when I shut down PC. I'm 3 months outside of my warranty. Two weeks ago something started happening. I boot PC and video doesn't come up for 10 minutes, and when it came up it worked perfect. VC/Monitor/MB?? It became 20 minutes and ...now..I have the analog/digital box in top left screen, power light on monitor flashing, no menu available on monitor and none of the other buttons work for anything. I test the monitor on Laptop..nothing(same as above)..I break out the old(working) monitor from deep within the closet. Plug it in and I'm up and running. So...
HOW TO OPEN A SYNCMASTER 2053BW
NO SCREWS!!! Assuming that the stand mount has been pulled out..The seam around the screen frame is where you start. The frame has the prongs, the back cover has what the prongs slip over.The frame is coming off first! I got the side to open by finger, then used a small standard screwdriver to pry ever so gently(lifting frame from rearcover). Leave the power button assembly on the frame, pull wire only a little to relax any tension..you get about 3/4" in extra taped to panel. The hard part is done.;) Still holding the frame...Now lift the panel (where the power button assembly wiring goes under panel) with the power housing that is under it as a whole and you will see where the powerbuttonassemble detaches.Remove frame. Now..holding edges of panel into back cover, lift and flip the whole thing over and place panel face down on a perfectly flat surface..a towel on my desk works. Lift and remove back cover.Your now looking at the back of the board housing. The ribon is simple, on the panel end of the ribon, squeez the outer clips together and slide it away against the panel..The secondary tin plate is removable, two clips super close to where the sets of wires come around the housing and into the panel.Unhook the 4 plugs(pink inside/blue outside)...Now lift the power housing off of the panel. The big board has the power. One screw to remove a ground plate first. Two screws to remove power board. Pics from phone.56ec44b.jpg
Reassemble but DO NOT re-snap the frame into place....yet... Test it! There is a reason the caps got hot in the first place, therfore it has a good chance of happening again. This is not fullproof...but.....mine has been on now for close to 6 hours with no glitches whatsoever. So I have resnapped mine back together. I hope you can too. - I must also add that this is one of the best producing monitors I have ever seen...in 60hz. The clarity is top notch. If you purchase one get the extended warranty. FYI...I paid $4.00 for those caps. It sounds like this is very common with SyncMasters.
Oct 21, 2009 | Samsung SyncMaster 914V 19" LCD Monitor
Samsung syncmaster 245b plus
Reassemble but DO NOT re-snap the frame into place....yet... Test it! There is a reason the caps got hot in the first place, therfore it has a good chance of happening again. This is not fullproof...but.....mine has been on now for close to 6 hours with no glitches whatsoever. So I have resnapped mine back together. I hope you can too. Oct 23, 2009- I must also add that this is one of the best producing monitors I have ever seen...in 60hz. The clarity is top notch. If you purchase one get the extended warranty. FYI...I paid $4.00 for those caps.
Oct 05, 2009 | Samsung 226BW Monitor
I have a samsumg 226bw that is acting up. When I turn on my computer, the monitor blinks once to show that the computer is booting, then after that no display. If I turn monitor off and on again, the...
You could have a faulty inverter board or faulty CCFL lamp.
Check out LCD Parts for service, parts and DIY info - click on this link to their WEB site. :-
www.lcdparts.net
Sep 27, 2009 | Samsung 226BW Monitor
Hi, I'm having an issue with a Samsung monitor. On
Sep 19, 2009 | Samsung SyncMaster 920NW Monitor
Need to remove front bezel to install a touch screen panel onto a samsung 226bw monitor, cant figure out how to seperate the parts
- This is how it went for me..I have a Samsung2.gif SYNCMASTER2.gif 2053BW. I leave my monitor on and let it hybernate when I shut down PC. I'm 3 months outside of my warranty. Two weeks ago something started happening. I boot PC and video doesn't come up for 10 minutes, and when it came up it worked perfect. VC/Monitor/MB?? It became 20 minutes and ...now..I have the analog/digital box in top left screen, power light on monitor flashing, no menu available on monitor and none of the other buttons work for anything. I test the monitor on Laptop..nothing(same as above)..I break out the old(working) monitor from deep within the closet. Plug it in and I'm up and running. So...
Reassemble but DO NOT re-snap the frame into place....yet... Test it! There is a reason the caps got hot in the first place, therfore it has a good chance of happening again. This is not fullproof...but.....mine has been on now for a day with no glitches whatsoever. So I have resnapped mine back together. I hope you can too. - I must also add that this is one of the best producing monitors I have ever seen...in 60hz. The clarity is top notch. If you purchase one get the extended warranty. FYI...I paid $4.00 for those caps
Sep 15, 2009 | Samsung 226BW Monitor
Syncmaster paower button blinking and no display
First of all plug another monitor to the VC on your PC and do the same for the SamSung"I over heat"SyncMaster2 053BW.
Oct 23, 2009 - This is how it went for me..I have a Samsung SYNCMASTER2.gif 2053BW. I leave my monitor on and let it hybernate when I shut down PC. I'm 3 months outside of my warranty. Two weeks ago something started happening. I boot PC and video doesn't come up for 10 minutes, and when it came up it worked perfect. VC/Monitor/MB?? It became 20 minutes and ...now..I have the analog/digital box in top left screen, power light on monitor flashing, no menu available on monitor and none of the other buttons work for anything. I test the monitor on Laptop..nothing(same as above)..I break out the old(working) monitor from deep within the closet. Plug it in and I'm up and running. So...
Nov 13, 2007 | Samsung SyncMaster 204B 20.1" LCD Monitor
HP Vs17 17" LCD Flat Panel Monitor Logo
63 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
