Question about Acer AL1715 17" LCD Monitor
Black Screen One resistor is found Blown inside BWB but value unknown ! Please help !
    Problem Solver:
  • 12 Answers
Depending on the resistor, the values for a resistor is color coded, meaning that there are a couple of lines of colors and each color line represents a value. Do a google on Resistor coloring chart and you might find your answer. If the resistor is a surface mount one and very tiny, you might be out of luck as these are too small for the manufacturer to print the part number on. Only the manufacturer has that part number and can be very hard for you to contact them about.
Posted on Nov 10, 2010
Lightning damage
Replace the parts with the original ones, a .5 ohm difference on a resistor on the video circuits will cause the unit not to work correctly.
Sep 27, 2008 | JVC HR-XVC27U DVD Player/VCR
The treadmill have dcmd67 control board I need to know what value resistor R 19 have
I can't help you (directly) with the resistor value, but be aware that if it exploded, there is probably another bad component (such as a capacitor, transistor, and/or an SCR). Replacing only the resistor may result in the same problem, or may not even work at all due to another bad component. If you do find out the value, try putting in a resistor of the same value, but with a higher wattage rating. I once had a washing machine in which the model had a known problem with circuit boards blowing. I solved it by replacing a bad transistor and installing a higher wattage resistor that had blown up like yours. It never failed again. The way I found the value of the blown resistor is, I looked up a replacement board online, then magnified the photo, and looked at the color code on that same resistor in the photo. How I found the bad transistor is too complicated to explain in few words, but you can google the procedure. (You'll need a multi-meter at the very least; preferably _with_ a built in transistor checker. However, a _totally_ blown transistor can be found with only the resistance settings on a regular multi-meter).
Best of luck...
Apr 05, 2016 | Exercise & Fitness
Blown resistors
Both resistors are: 1/4w 100 ohm with 5% tolerance (brown, black, brown & gold colors). Best to use the "Metal Film" type because they're more durable than the "Carbon Film" type.
Feb 24, 2014 | Jensen JHT525 System
Hi, my B & D 24v slide in battery charger 5145093-00 stopped working. I've opened the slide-on end, and discovered a blown resistor. The a.c. is still being rectified to approx 26VDC If i knew the...
Hi daggsat, I know this is a longshot but did you ever discover the value for the resistor for you B&D charger. I've got exactly the same problem.
Jun 13, 2011 | Black & Decker Vacuums
Toshiba 55H70 Wont turn on but we get the blinking light of death
it sounds like a flyback problem (the part is around 70.00 but it can hold high voltage so have a pro do it!
Dec 09, 2008 | Televison & Video
Blown resistor
if you mhave the circut diagram please check it .
Nov 23, 2008 | Electronics - Others
Need value for part R14109
R14109=750ohms 5% 1/4w (Resistor(750r5%.25W/R14109/179317) There is much more likely wrong with the TV. Resistor don't normally burn out with help, say, without a failing flyback transformer and possibly taking a transistor or two with it. If you need the manual, go to http://www.samswebsite.com/photofact/pf_search.asp and type in "F31317" into the search field, you will several listings. If you decide to replace it yourself, here's some more part numbers in case you need them. Model: RCA\F25422TX41 Symptom: Dead Necessary parts: Transistor(Q14401) Main Voltage regulator Q14101 Resistor R14109 open. Research indicated the flyback transformer most probably bad \\CTC203AC4\HOT/D2578(Q14101/242224)* Flyback(14536119A/T14401/244229)* Main reg(P9NBSO/Q14101/244223) \Reg(MPS8599/Q14102/147665) Resistor(750r5%.25W/R14109/179317) Reg(MPSA06/Q14103/232218) Hope this helps you. ZT3000 "Beta tester of "0"s and "1's"
Aug 19, 2007 | RCA F31317 31" TV
Acer AL1715 17" LCD Monitor Logo
73 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
