Question about Cisco Computers & Internet
I cant set up my linksys wireless-G ADSL, my laptop recognizes linksys but i still cant connect to the internet, when i clicked on troubleshoot to correct the problem, it says DNS isnt recognized
  • 64 Answers
    Go to a cmd prompt. To go there, simply type cmd in the search. You can access it by going to your C hard drive, find Windows folder, in the folder locate System 32 - look for cmd.
When you are in cmd:
    Type IP config and see if you have an @ssigned IP in the range setup in the router. If not try C:\ipconfig\release then C:\ipconfig\renew Likely that this won't work.
    The steps I took were:
    1.) Go to Start/Control Panel/Network Connections. Right click on the wireless connection. Go to TCP/IP in the components section and click the properties button. Make sure Obtain IP and DNS address are both set to automatically.
    2.) I had WEP enabled, make sure your wireless card and the router are both set to the same encryption 64 or 128 and make sure they are both on the same channel.
    3.) Try C:\ipconfig\release then C:\ipconfig\renew again and hopefully you'll get an IP address.
Posted on Nov 10, 2010
Laptop cant connect to internet
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Apr 06, 2010 | Linksys Wireless-G Broadband Router
Linksys Wireless-G2.4 GHz Broadband that my laptop doesnn't recog
If that doesn't work then upgrade the firmware of the router.
Firmware is the software of the router. After upgrading the firmware, it is recommended that you should reset the router and reconfigure the router.
Click Here to know more about router and network
Feb 13, 2010 | Linksys Wireless-G Broadband Router
I need to complet my router setup
Have you secured your Linksys from unauthorized access?
The encryption code protects your wireless router from unauthorized access. The wireless card in your computer/laptop needs to be configured with the router's encryption settings before the computer/laptop can access the router.
For details on configuring the wireless router and the wireless card, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Jan 06, 2010 | Linksys Wireless-G WRT54G Router
Appreciate any advice on how to set up Linksys Wireless G Router
here's a basic SoHo set-up.
But if your looking for manual, please provide me your e-mail address so that i can e-mail you.
Thanks.
Feb 09, 2009 | Linksys Wireless-G WRTP54G Router
Password settings
hullo
open up you Linksys user inaterface click on the wireless tab then security then go to the field called WPA SHARED KEY
then type your password to secure you wireless connection. Dont forget to save the settings.
Best of Luck.
Jul 01, 2008 | Dynamode RADSLC4WG Wireless Router...
Un secured linksys router
first need to reset your router push the reset button at the back of the router for for 10 sec. then open internet explorer type 192.1681.1. enter type password admin enter ,..configure again your router enter the IP address. , Subnet mask , and DNS put the setting Static IP ,next click mac address clone and click "clone your pc mac" then click wireless at wireless network mode put it mix, at wireless channel put to the highest ghz. then after that check your line by trying to conect to the other pc using your UTP cable if it is working connect it again to your laptop
Jun 23, 2008 | Linksys Wireless-G WRT54G Router
Internet access problem with a Linksys 54g router
Try setting the default gateway on the laptop to the ip address of your ICS gateway machine. Some routers separate the wireless and LAN connections on different subnets.
Try comparing your laptops ip information with that of one of the working wired computers. You can do this by going to Start up to run and type cmd then click "ok"
At the black prompt screen type "ipconfig" without the "".
You want to compare the IP Address, Submet Mask, and Default Gateway.
If one has an ip of 192.168.1.* and the other has 192.168.0.* then the wireless and wired are on seperate networks.
If the subnet masks are something like 255.255.255.0 and 255.255.255.1 they are on seperate subnets. Both should be fixable by putting in the same default gateway.
For example if your ICS gateway is 192.168.1.1 then set that as the default gatway on the wireless laptop. This can be done by going to start >> Control Panel >> Network Connections then right click your wireless connection and goto properties then double click on the "Internet Protocol (tcp/ip)" option. This will list all of your ip information (if its static) if its dynamic (ip gotten from router) you can still click "Use the following DNS server address" and set preffered dns to the gateway ICS ip. Or click "Advanced" and click Add under Default Gateways and add the gateway ICS ip there.
Jun 20, 2008 | Computers & Internet
Connecting wireless router to laptop computer
Please confirm that this model is indeed a wirlles Modem/ ADSL Router and not just a Wireless Router without the ADSL/ Modem capability??
Apr 20, 2008 | Linksys Wireless-G WRT54G Router
Dsl internet connection sharing
Did you run the set up cd? If so, then try to do powercycle. Reboot everything. if your wired connection works then access the set up page by typing 192.168.1.1 on the address bar of the PC that is already online. Leave username blank, "admin"  (lowercase letters is your password). Click status, if you already have an ip address and Dns then you are good to go. If you dont have then do a mac clone under "set up" then check the password for wireless connection under wireless security. you can use that to log on to the wireless netowrk on your two pcs.
if all of these seems to be confusing, you can call. 18003267114 for manual help.
Oct 16, 2007 | Computers & Internet
Computers & Internet Logo
89 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Gareth Tomlinson
Gareth Tomlinson
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
