Question about Dell E173FP 17" LCD Monitor
Monitor says 'auto detect, entering power save mode' and then goes black, moving cursor or buttons doesn't help
    Problem Solver:
  • 12 Answers
This is usually not a monitor problem.
You have to start trouble shooting with elimination. First try to connect the monitor to another computer with the correct cables then if that works, you know your problem is on the computer end.
If not, you probably have the wrong cable.
There is also another option and that is that the screen resolution from the graphics card is not compatible with the resolution of the monitor.
This can be changed in the display settings in the control panel of your computer.
Posted on Nov 10, 2010
Acer pc and lg monitor blank screen says power save mode on start up, anyone know how to fix this?
Actually during start-up there is a slight delay before the HDD & OS is detected by the CPU. Normally all monitors slip into power saving mode within 10 secs of inactivity of either mouse or keystroke. This inactivity is read by the monitor which promptly switches to power saving mode. However the moment the HDD LED starts blinking, the monitor wakes up & starts displaying. This power saving mode in most of the flat screens is only associated with movement of mouse or keypad. This does not register till the CPU starts up & thats why the monitor switches over to power saving mode till it starts receiving signal from the CPU.
It is a normal behaveour, so don't get worked up over it, plus you can always hit the Auto set feature on the monitor after booting the PC completely. ( I think the time out for the monitor to enter power saving mode is only 10 secs). Hope this helps.
Oct 08, 2012 | Computers & Internet
Hello, Hi, I've just got myself a brandnew Dell desktop with windows 7 32 bit on it. Everything seemed to work fine, but my computer enters Power saving mode at completely random times while im actually...
The simplest thing to do, as it is a desktop computer, is go to the control panel, power options and set everything to never so the computer never goes into standby mode.
If this does not prevent the machine going into standby mode then we need to perform further troubleshooting.
Jan 29, 2011 | Computers & Internet
How do I turn it on
Hello.
To power on the Gateway VX750, press the power button on the front. The power button has 3 sides with a "G" in the middle.
The LED indicates the power status of the monitor.
  • Not lit - The monitor is turned off or does not have power connected.
  • Blinks one time and then goes off - The LED blinks one time when the monitor's power cord is plugged into an AC outlet to indicate that power is detected.
  • Lit solid blue - The monitor is turned on and active.
  • Blinking blue - The monitor is in power saving mode. Before entering power saving mode, a message briefly appears.
Hope this helps.
Aug 12, 2010 | Gateway VX750 (Black, Platinum) 17" CRT...
Power Save mode on, can not use computer
If your computer is indeed running, simply unplug your monitor from the wall, and then plug it back in. This will bring your monitor out of power save mode instantly.
Apr 22, 2010 | Dell Dimension 8400 PC Desktop
My dell inspiron 531 desktop enters auto detect power save mode
start your computer in safemode and then turn off all power saving features
Apr 10, 2010 | Dell Inspiron 531s Desktop Computer
Screen goes black while in use
If your monitor it's good the reason may be that the settings of the refresh rate is to high for your monitor. Try to enter in Safe Mode (Press F8 key before booting in OS and from the menu choose Safe Mode) and then from Control Panel try to remove de video driver and then restart the computer. After restart, the OS will detect your video card as standard VGA card. After that install your video driver again.
Apr 09, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
My LG flatiron W1943TB turns on, says analog power saving mode, goes black and then the power button flashes.. but the monitor is hooked up to my dell notebook bc my LCD died
Hi erin mckinle,
That is probably it's, uh, analog power saving mode. When the screen goes black and the power button flashes, make some mouse gestures or hit some keys that would not affect anything (try spacebar). That should bring up the screen. If you think it goes into power saving mode too fast, go to Control Panel --> Power Options, and change the values. Hope this helps.
Jan 02, 2010 | LG W1934S-BN 19" Monitor
My monitor shuts down after one second.
Dell monitors automatically go into power-save mode after a preset amount of time when the computer is inactive. The Dell monitor will go completely black, instead of showing a screensaver. This doesn't mean that your Dell computermag-glass_10x10.gif has shut down. Instead, this allows your monitor to essentially turn off until it's needed again. You can change how long it is before the Dell monitor goes into power-save mode by changing your display settings.
  1. Step 1 Press any key on your keyboard or move your mouse. Either will turn off power-save mode. Alternately, you can press the power button on your Dell computer tower or laptop.
  2. Step 2 Press any key a second time if the monitor goes from power-save to stand-by mode. Stand-by mode allows the screensaver to appear.
  3. Step 3 Enter your user name and password into the login prompt if your computer requires a login. Press "Enter" to begin using your Dell computer.
  4. Step 4 Change the display settings on your Dell monitor to prevent your monitor from going into power-save mode prematurely. Right-click anywhere on your desktop and choose "Properties." Click the "Screensaver" tab and press "Power." Beside "Turn off Monitor," choose a time amount from the drop-down list and press "Apply."
Nov 13, 2009 | Dell Dimension 3100 PC Desktop
Monitor displays breifly then goes to blank screen
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
Monitor in Power Save Mode
The inverter power logic is probably going bad. You can get it here as well as look at instructional videos on DELL monitors.
http://www.lcdrepair.us/e176FPf-inverter-power-logic.html
May 04, 2008 | Dell E176FP 17" LCD Monitor
Dell E173FP 17" LCD Monitor Logo
1,375 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
