How to clean the pump on a whirlpoolb front loader
The red light is on and the machine keeps stopping
  • 413 Answers
Remove the three screws securing the bottom access panel. There you will find a pump filter that you can unscrew and remove debris.
Removing the pump from the mounting position and pulling forward slightly will make draining a little easier.
UNSCREW AND DRAIN SLOWLY as there will be lots of water to catch..
Posted on Jun 17, 2008
Where do I clean the pump filter? Light keeps lighting to clean pump. Whirlpool front loader. A+A 5kg / 1200 AWO/D 4505
You have a code telling you to clean the pump now thats a first are you sure it says clean the pump filter? more info as to why you are needing to clean the pump filter its not really easy trust me, unless you have done it before which i am guessing you havent.
Mar 07, 2016 | Whirlpool Washing Machines
How do I clean the pump on a front loader Whirlpool washing machine, when the filter is spotless. (Red Pump clean light is on) Machine doesn't drain properly leaving clothes soaked.
If you have a top front small panel, unscrew 3 or 4 screw then you can pop out the cover. The pump is right there, you can counter clockwise the filter out and clean the pump. Be aware to do it with the power off.
If you don't see the front small panel, you have to open the back cover at the back of the unit.
Oct 13, 2013 | Whirlpool Washing Machines
Front loader has stopped mid wash and red light has come on saying clean my pump. How do I do this?
Not knowing which model you have makes it a bit difficult. Most front loaders have a little trap door down on the front panel somewhere. Behind this door is access to the pump filter. Usually, it just unscrews, and you pull it out. If your machine is full of water, expect a mess. remove any buildup of fluff, foreign objects etc. If your machine has no trap or access. Unplug the machine and drag it away from the wall. Lean the machine back against the wall to gain access underneath. You should be able to see a large hose from the tub to the front ( or side) of the pump. They are usually held on by a spring clip. Slide the clip back or unscrew the clip to enable you to pull the hose off the pump. Clean out any foreign objects you find. As before, if the machine is full of water, expect a mess. Front loader drain hoses usually exit out the top of the machine so lying the end of the drain hose on the ground wont drain the water.
Jul 26, 2011 | Whirlpool Washing Machines
A Whirlpool Front Loader WFS1273BD. Red light says "Clean Pump". How do I do this?
there is a pump filter in the bottom front right side get a screw driver pop the cover off unscrew the plug/catcher & clear anything out thats in there and if it still doesnt work the pump has probably failed.
Jan 15, 2011 | Washing Machines
Won't spin or drain, have tried to rerun cycle and checked drain hose
Check pump / outlet filter , refer to instruction book , clean and replace then re- try
Nov 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
How do you clean pump on front loader washer? red light said to clean
Theres a tutorial to clean a pump. Dave
Jan 13, 2009 | GE WSXH208A Front Load Washer
Red light on - clean pump
remove bottom panel 3 screws7mm once removed access to pump im front clean and reinstall thats it
Jan 03, 2009 | Washing Machines
Washing machine
bottom right corner behind the little door
Sep 27, 2008 | Whirlpool AWM5125/1 Front Load Washer
Our simpson 100 enviro won't drain. We think we need to clean the filter, but we can't remove the filter from the machine. How can we do this?
front loader filters are at the bottom use a screwdriver to remove it may be stuck full of coins.also make sure you dont have a button pressed in by mistake.hope this helps you
Mar 09, 2008 | Washing Machines
Washing Machines Logo
87 people viewed this question
Top Washing Machines Experts
