Hi my desktop has an issue it had that blue screen and want to do a memory dump that was fine the next screen was the startup screen with safe mode etc on it with timer this froze,when i rest computer it started with a continous beep. After reading things on net i took out the memory stick and cleaned it put back in the beeping changed to 1 beep ,pause and two beeps, tried the above process again and it started up no problem but then seemedmy mouse froze did another rest since then its at the pattern of 1 beep,pause and 2 beeps is my motherboard alright or is it a memory issue.
    Problem Solver:
  • 12 Answers
Google computer beeps and you might find the problem.
This is sure to be a hardware problem. When you get the "Blue Screen", this is an indication that an error occured which the manufacturer of the operating system does not know how to handle.
Posted on Nov 10, 2010
    Guru:
  • 254 Answers
is your video card is on-board on the motherboard? if so, put external video card compatible with your motherboard and power it on.
your on-board video card is faulty you need external video card!!
Imac g4 freeze restart
This is a sign of memory issues with your Mac. Replacing the memory should not be very expensive.
Oct 10, 2012 | Apple iMac G4 Desktop
Computer won't startup gets stuck in driver loop
if you have a PC then when it has the codes there will be options so you click on "start windows normally" because it is in safe mode that happens after your computer has dump crashed. so if you change it that might help! good luck
Oct 05, 2012 | Sony VAIO VGC-RA820G (027242657700) PC...
It turns into blue screen with white texts and from below, its says terminating (memory-something) and has a countdown... and reboots itself. computer: Compaq Presario PC SR5050NX
Its probably saying memory dump and the countdown. This is mostly encountered after some kinda change on the pc. It can be new hardware, software or just plain windows update. Lots of times it ends up being a corrupt driver. Try to boot in to safe mode and see doe sit still do same thing. if not than you know it is software related and you can do system restore. To boot in to safe mode on reboot keep on tapping key F8 and choose safe mode. Once in safe mode if it works go to start, all programs, accessories, system tools and choose system recovery. choose like a week back and click next and this will do a restore to when pc was working, fine. If you cant boot into safe mode it is possible it has issues with hardware and this should be checked out by a pc repair shop. Another option you can try if same mode dont work try to do same thing on boot keep on tapping key F8 and instead choosing safe mode try choosing Last Known Good Configuration. this is similar to restore. Hope this helps.
Apr 17, 2011 | Compaq Presario 2200 (292600-004) PC...
I need to reset ... it will only go to a blue screen . Saying crash dump
To solve this issue boot your system to safe mode. Restart your computer and press F8 while booting a select Safe mode option. Once it logged in to safe mode, Go to start -> RUN and Type msconfig. So you will get a window. You need to click on START UP tab and search for DUMP or any files with DUMP phrase.Once you found it uncheck the entry and Click on APPLY and OK. Restart your system normally.Now you can see your system working fine. see the pic below
Dec 05, 2010 | Acer Aspire Z5600 PC Desktop
Hp pavilion a6110 stuck at HP startup blue screen
Have you tried to boot up in safe mode and selecting to "reboot computer using last settings that worked"?
Jul 08, 2010 | HP Pavilion a6110n PC Desktop
Hi, my windows XP pro is no longer runing. i end up with a physical memory dump Screen. But no longer open on my desktop PC screen.
Download Malwarebytes from filehippo.com and run on both computers in safe mode
Go to start and right click on my computer click on properties and then advanced then startup and recovery click settings. Where it says write debugging info click(small memory dump (64kb)
Jun 27, 2010 | Microsoft Windows XP Professional Full...
I keep getting a system dump/blue screen. i tried
You might have bad memory, a corrupted registry file, corrupted system files. Try starting up in Safe mode then backup your data. Goto My Computer and right click on the hard drive and select properties. Goto Tools tab and select error checking of hard disk on startup. Might need to reinstall Windows
Aug 05, 2009 | Averatec D1002UHCE-1 All-In-One Intel...
Dell Dimension 4600 Blue Screen
Usually this blue screen appears due a hardware issue or drivers conflict.
1) Try to boot in safe mode (hit F8 after starting up) and select "Safe mode"
If you don't get access try doing this:
2) Run the OS CD and use the option Recover Console (R)
This will fix the problem.
3) If the problem continues, you will need to install the OS again.
Oct 07, 2008 | Computers & Internet
Blue Screen of Death
Just use ORIGINAL OS CD and repair OS everything will work fine!
Dec 27, 2007 | Computers & Internet
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
