Question about 2wire (2701HG-B) Wireless Router
How many computers can the router handle? - 2wire (2701HG-B) Wireless Router
    Problem Solver:
  • 15 Answers
The 2701hg-b Wireless Access Point (WAP) has 4 ethernet connections, that's the physical limit, for that, unless you "cascade" a bridge or another router off of a port.
It also supports wireless. I know of no documented limit as to the number of concurrent wireless connections... there probably is one, but it isn't "published", that I know of.
The "real" limits on the wireless side are "activity" and "channel" conflicts.
The "activity" conflict factor has to do with how much somebody/anybody is using "doing" with your WAP. Sooner or later, you'll see "saturation" of the wireless bandwith.
The "channel" conflict factor usually occurs when there are two (or more) WAPs (or other wireless devices) within "range", that are using the same "wireless channel".
From the "user" perspective, the effects of "conflict" are similar to "saturation", except that you'll likely see more "dropped connections" with "conflict".
Posted on Nov 17, 2010
Guest access cisco connect
If you give your password out indiscriminately, someone could get into your router and change the configuration (password). Not sure if this pertains to your router. Try to configure the router again and close down guest access until you can get a handle on who you can trust.
Dec 19, 2013 | Computers & Internet
Fix broken ejector handle
You need to obtain a replacement flash ejector handle first. If you open the router out, you can push the broken ejector handle out with a small flathead screwdriver, it just slides out forward toward the face of the router if you apply a bit of pressure. Then you just slide in the new ejector handle, which is "keyed" on one side. There is also a small metal lever pin that you need to line up with the spring hole when sliding the new ejector handle into place. Once inserted is will snap gently into place and you are done.
<a href="http://www.ciscobuy.com">Sell Used Cisco Equipment</a>
Mar 15, 2012 | Cisco 2801 Router - 2801
How do i put a password on my router
Take a look at the manual here and read Chapter 2.
Choose WPA2 (TKIP&AES) if your computers can handle the encryption (WinXP Service Pack 3).
Let me know if you have more questions!
Feb 28, 2012 | NetGear WGR614 Wireless Router
Will setting up a wireless laptop on Linksys WRT54g router mess with 3 computer ethernet wired connections ? I want to set my lap top to WPA2. Right now it's at WEP:(
it all depends on the win version you have.
Please go here (http://homesupport.cisco.com/en-us/wireless/lbc/WRT54G) and hopefully it will have the answer you are looking for.
Obviously you know how to set up your router, since you already have three computers hooked up.
I have many wireless/wired pc's and wireless/wired mac's on the same router, with no problem at all.
Many routers can handle upwards of 30-40 connections without a problem and high quality ones can handle 254 (that's the max for a class C subnet).
Good luck
Dec 14, 2010 | Linksys Wireless-G WRT54G Router
Set router to handle 4 puters
Plug all computers into router, configure and enable DHCP.
If you need more plugs purchase a network switch with at least 5-ports. 1 for each computer and one to plug it into the router.
Your Internet provider should be able to help if you have the patience to work with them.
If this helps please vote for my solution.
Sep 15, 2010 | Computers & Internet
The modem light is off on my Motorola modem.
Ah, someone that actually makes use of the word "nor" I would first unplug the CAT-5 cable that goes from your modem into your router to check that it's not your router's fault. To make sure that every computer that is plugged into the router is on the network you should PING each computer to see if you can reach it.
Find out the IP of your computer by clicking Start then Run then type in CMD. Once your in CMD (Command Prompt) you should type in IPCONFIG. That command will give you a response with your IP Address in it. Take that IP and go to another computer in your network and use the PING command in CMD by typing PING 192.168.1.??? in CMD.
If your PINGing session is successful then it's a problem with your ISP (Internet Service Provider) and should be handled by contacting them and having the problem fixed because it's an issue at their end. If it's not it's a problem with your router and can be handled by having a specialist come to your home and to fix/set up your network or I could remotely control your computer to fix it.
It's your choice, but the specialist will cost and I won't.
Thanks,
Brandonmxb
Dec 11, 2009 | Arris Wireless G Broadband Router (wr850g)
The router now has 6-8 computers on it at a time, and it seems to be crashing. Is it because there are too many computers on the router?
Generally a Router can handle 254 System/Computer at a time.
Try Rebooting and then Re-configuring the Router if the issue persists after rebooting the Router.
Jul 29, 2009 | D-Link AirPlus DI-614+ Wireless Router
Router cant handle two pc's connecting to same server
Try to do port forwarding. Search for the port number that the game uses and open it on the router's Setup Page using Port Forwarding.
Apr 25, 2009 | Linksys (WRT54GC) Router
Hard Drive Failure - Coincidence?
Vista and XP are not compatable on the same network if the router is not specifically designed to handle this. It depends on the router. Either a, use one operating system across the network, or b, purchase a router which can be configured to handle both OS.
Sep 18, 2008 | Computers & Internet
Internet connection
Install Router Commander. This program can optimize router settings and speed up your internet connection.
Mar 10, 2008 | D-Link DSL-G604T Wireless Router
2wire (2701HG-B) Wireless Router Logo
793 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Bruce Silvernagle
Bruce Silvernagle
Level 1 Expert
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
