Question about Datacard SP25 Printer
Data Card SP25 Printer wont print in color after changing ribon
SOURCE: want to solve my problem
Hi Supermarco:
You are experiencing a common problem whit card printers, usually it happens when the printer needs maintenance. Two things might be producing your problem:
It could be the rollers, may be they are dusty and the card slips, that produces the error message you are experiencing. To solve it I recommend you to clean the rollers using a lint free cloth moistened with isopropyl alcohol. You can press the cloth against roller and move it turning the blue knob located at printers left. I also recommend you to run a cleaning card to the printer as specified on users guide (every ribbon replacement), that will also help you.
Another possible cause of your problem is a blocked by dust sensor. Datacard printers sensors rarely broke, when they produce problems is always due to dust. You can buy a compressed air can and spay with air all the interior of printer, just don’t forget to remove the ribbon and cleaner roller first. In that way dust accumulated on sensors will be removed and your printer will work properly again. I recommend you to operate your printer in a dust free environment, this kind of printer is very sensible to dust and debris. If you still have problem don’t hesitate to ask.
Regards
Posted on Jan 11, 2009
SOURCE: dell 924 dell printer head ;error 1203;change
Hey do a power drain by removing all the cables from the rear of the printer and then hold the power button on the printer of 15-20seconds with all the cable out connecting the printer... Then power on the printer if you still see the error code message displayed on the printer display screen do a nozzle clean in the computer, check on if the printer prints the nozzle clean test page perfectly.If not remove the cartridges and clean the nozzle of the cartridges with a clean cloth and be careful so that you do not destroy the copper contacts, clean the same you see on the carrier(where you place on the cartridges). I think this should work.
If not call in technical support.
Regards,
Dev,
Printer Technician.
Posted on Feb 27, 2009
alexvelez052
  • 40 Answers
SOURCE: Datacard SP25 only printing half of ID Card
it sounds like a driver error try to reinstall the software
Posted on Jul 08, 2009
  • 13 Answers
SOURCE: printer printing one color
Go to smart driver printer tool box, then select
brightness 0
contrast 0
sharpness 0
cyan -------centre----------
magenta ------centre----------
yellow -----centre-----------
From toll box select clean printer
Go to advanced setup
select monochrome
Down -3
Left 140
By doing all the above setting hope your problem will get solved , check the ribbon also , move two to three rounds change in the ribbon by manually .
Posted on Aug 08, 2009
  • 39 Answers
SOURCE: After ribbon change, can't print ID card background colors - only text is printed
The problem could lie in 3 areas:
  1. Printer
  2. Printer driver
  3. Card issuance software
I would start by changing the ribbon with a fresh one. As you probably know, the ribbon spool contains a chip that tell the printer what type of ribbon it is.
Next, I would run the clean up utlity for the printer and get rid of the driver then reload the print driver.
Lastly, I would back up all the projects and databases, uninstall the ID issuance software then delete the BIN directory.
Hope this helps
Next
Posted on Aug 19, 2009
Warning ribbon in V53.16.7Z
The "ribon in" warning is because you set the printer to print DIRECT THERMAL insted THERMAL TRANSFER. The first mode is for printing directly on the thermal labels, not for using a ribon. The ribon sensor detects that a ribon is pressent and you get this message. You need to change the printing mode to Thermal Transfer from the printer Setup Menu, or from the Print Driver instaled on PC.
Jan 19, 2015 | Zebra Office Equipment & Supplies
Sp25 won't print colors
Roll back drivers and check print heads for flow
Apr 22, 2014 | Datacard SP25 Plus Plastic ID Card Printer
Datacard sp25 plus is only printing black and white
a) You bought a black Supply(check code and catalog)
b) You have set your driver to print only black dots(check your driver settings)
Jan 20, 2014 | Datacard SP25 Printer
Printer doesn't recognise the color ribbon and print only in mono.
Try !SA command to calibrate ribon and printer, send command from the driver
Oct 07, 2010 | Zebra P330i Thermal Card Printer
Datacard sp55 printer won't recognize ribbon
PR-01726 Ribbon Out
Out of print ribbon.
Possible Cause 1 : The print ribbon Cartridge is empty.
Solution 1 : Reload the print cartridge. Change the cleaning sleeve and replace the cartridge in the printer. Run a cleaning card as soon as printing is completed.
Possible Cause 2 : The printer ribbon is not loaded correctly.
Soultion 2 :Load the printer ribbon correctly and then close the cover.
Possible Cause 3 : This ribbon has been completely used.
Solution 3 : Use a new roll of ribbon.
Tips for Success
* When this message appears, replace the old ribbon with the new ribbon of the same type. The printer has already prepared the card data for this ribbon type. You can change the colors of monochrome ribbon (such as from dark blue to gold).
* If you must change the type of ribbon (such as (YMCKT to KT) when this message appears, install the new ribbon, cancel any cards waiting to print, and change the ribbon type settings. Finally, return to the card creation program to send the card data to print.
* If the ribbon was repaired, the wrong take-up spool was used. Repair the ribbon again, using the correct take-up spool.
If you cannot fix the problem contact your service provider for assistance.
FTB
Nov 23, 2009 | Datacard Group SP55 Card Printer
I have a DataCard SP25 card printer that won't power up. I switched cords to a known good one and still no power. I suspect it's the power supply in the unit. Is this replacable and what might the cost be?...
There is no power supply in the printer, the power supply is external, nothing user replaceable inside, sounds like you need a new system board, you would be better off trading in for a discount on a new SP25 Plus.
Check midwestIdSolutions.com
Nov 10, 2009 | Datacard SP25 Printer
Jul 08, 2009 | Datacard SP25 Printer
Datacard sp25 ID card Printer printer about half of the picture is this a printer problem or a ribbon cartridge problem?
you need consider:
1) it should be no gap between roller--ribbon--card and base when it printing need enough pressure on the card. if not enough pressure it could be printing bad.
2) the ribbon move under the roller might be not normal, to check or adjust it
3) the ribbon near the end, need to change
hope it help you
May 12, 2009 | Datacard SP25 Printer
THE RIBBON BROKE ON MY DATACARD SP25 PLUS.
to fix the problem that is causing the ribbons to brake or the broken ribbon it self?
1. check edge to edge settings in printer toolbox
2. to fix broken ribbon re wrap it straight over the take up spool and use a piece of tape to hold in-place.
Dec 31, 2008 | Datacard SP25 Printer
Datacard SP25 Printer Logo
108 people viewed this question
Top Datacard Office Equipment & Supplies Experts
Safe-Card ID...
Level 1 Expert
james laughton
james laughton
Are you a Datacard Office Equipment and Supply Expert? Answer questions, earn points and help others
