Question about Reddy Heater-70,000 BTU Kerosene w/T'stat
Reddy Heater R55 55,000 BTU heater spits and sputters but CONTINUES TO RUN. Air pressure is at 3.4 (was 4.0). new lines, Plug is firing well, fuel is old but clean. My question is: is there supposed to be a fuel filter on this model? The black plastic piece in the tank is just hollow. Any ideas on why this unit is spitting and sputtering but continuing to run? Thanks Dave
  • 232 Answers
If you brought the heater to my shop with the great (no lie!) description of the problem we would immediately grab a flashlight, shine into the tank and look for water droplets rolling on the bottom of the than. (Keep in mind that a layer of water can be on bottom & not show up with the light)
The next thing would be to use soapy water and try to find a crack in or around the plastic cover and move all the way to the nozzle looking for an air leak. 3.4 at the gauge doesn't mean the air is going all the way to the nozzle.
Next, remove the top cover. Does the heater run fine once removed? If so, replace the worn out nozzle. That heater has some age on it and DESA recommended annual replacement.
The filter is more of a strainer than a filter. It is hollow.
Read more troubleshooting tips.
Posted on Nov 10, 2010
Testimonial: "Thank you tbugger for the fast and informative response I will follow your suggestions. THANK YOU VERY MUCH FOR YOUR HELP!!"
  • desch550 Nov 13, 2010
    Nozzle LOOKS Clean and OK, Replaced nozzle, BAM! Perfection. Just like new again. Thanks again!! Dave
  • Jerry Magee
    Jerry Magee Nov 13, 2010
    Glad to help!
R55 starts 1 out of ten times , Take the cover off fires right up
Posted on Jun 13, 2011
Reddy Heater
check lines for blockage
May 30, 2017 | Reddy Heater-30-55,000 BTU Variable
REDDY HEATER 40,000 BTU KEROSENE&DIESEL
Clean your nozzel, check your fuel & air lines, you may need to replace Spark plug and filters. You can go to the manufacturers website at www.desatech.com and they offer service manuals. I hope this helps you!
Jan 23, 2010 | Reddy R60A Utility Heater
Heater sputters and spits
change nozzle, check fuel tank is clean and fuel line and filter are clean
Oct 29, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
60000 heater kerosene fires up but shuts off shortly after
Check the entire fuel like to the tank. They tend to break, plug up, etc. which causes a lot of problems. The strainer in the bottom also plugs up. Rick
Apr 08, 2009 | Reddy Heater 60,000 BTU Kerosene...
Reddy heater shuts off when shell is put on
check out the fuses getting blown out on the internal chip circuit board and also the overheating component on that same circuit boasd.the burnt component will look little bit extra blackish on its sides.
Mar 03, 2009 | Reddy HEATER R115 115,000-BTU PORTABLE...
Reddy Heater won't stay running
Dear travelinman4, 02-21-2009 18:24 EST (USA)
Re: Reddy Heater "Won't Stay Running"
Model R150A
Old Fuel? Added a Can of Fuel Booster? Used Starter Fluid?
Spark Plug or Igniter?
Gas, Propane, or Kerosene?
jack
Feb 21, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy heater runs then stops
it's the ignitor itself, if everythingelse is working or new then your just not getting enough spark. Also check your air lines as they do tend to get brittle and if your not getting enough air it won't light either.
Jan 27, 2009 | Reddy Heater-30-55,000 BTU Variable
Reddy heater will not fire.
Your problem is most likely the lack of pressure from the air pump. Your pressure is extremely low. Pressure on a 100k heater should run 5psi. At 3psi there is not enough fuel and not enough air to atomize whats there. Bump the pressure up. If it won't come up, then you have an air leak. Test w/ soapy water. Keep your fingers clear of the fan!
Dec 04, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater-70,000 BTU Kerosene w/T'stat Logo
1,332 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
