Question about Whirlpool Duet GHW9150P Front Load Washer
F05 error message, you have helped me fix it before , but I don't remember what I did. something with wiring. thanks
  • prneumann Nov 10, 2010
    thank you .
  • Whirlpool Master
  • 19,396 Answers
Hi.
F05 means temperature error.
Try tripping the circuit breaker to reset the appliance. If the error occurrs again, then the appliance may be faulty. In that case the repair will consist in checking wiring to the temperature sensor, and eventually replacing the temperature sensor.
Here a detailed story illustrating a repair carried in case of F05.
Regards.
Ginko.
Posted on Nov 10, 2010
  • Ginko
    Ginko Nov 10, 2010
    Hi.
    You are welcome.
    Let me know in case you need more help.
    All the best.
    Ginko.
How can i fix my hotpoint washing machine showing an error code of f05
F-05 Error Message
The fault is associated with drain out (pump blocked or restricted in some way),
pressure switch is jammed on empty or a some problem with pump.
Small panel at rear of machine reveals the pump, pull of the two pipes (Plastic clips hard to get off, slide them sideways), remove wire and unclip pump from base of machine by lifting locking tab and sliding to the left, pump can then easily be cleaned.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 15, 2011 | Washing Machines
Error code f05 hotpoint ultima
In your service manual it states F05 - Pressure switch jammed on full many times I find this is due to a blockage in the drain line and if you take and clean out the drain line it usually alleviates the problem most of the time due to this error. I also find that while doing this it is best to also check the drain line that comes off the water opump as well as the one that goes from the bottom of the tub to the pump as well. Also checking the pumps impellar that it does spin freely assures future useage without problems for a much longer time with your washer. If you have any further questions message them back. Please also remember when our chat has fully concluded to rate how this opinion has helped in your appliance situation. By doing this it allows me to continue helping others in similar situations in the future.
Thank you
Rick
Nov 14, 2011 | Washing Machines
Its dispalying error code F05
Code F05
Description:
Water temperature sensor error. If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, the "F05" error code will be displayed.
Possible Causes / Procedure:
1. Unplug washer or disconnect power.
2. Check the water temperature sensor. Check connections to the water temperature sensor.
3. Check resistance of heating element, if present on this model. (abnormal = infinity).
Replace failed component.
Hope this helps (remember to rate and lave a testimonila about this free answer).
Sep 30, 2011 | Washing Machines
Indesit pwe 8148 w with error code FO5 Is the problem usually either a blockage or the pressure switch? I am going to try to fix it myself but how do i get to the pressure switch to see if it is stuck on...
Hi.
F05 means that the pressure switch shows full all the time:
The fault is usually fixed repairing or replacing the pressure switch. Before replacing the switch check for draining issues that can trigger F05 and clean the hose connected to the PS. The PS is located inside the appliance in the control panel or at the right side of the cabinet. The part is reached removing the screws holding the top and lifting the top. Power must be disconnected before starting.
Here how the switch looks like:
Sep 14, 2011 | Indesit W 123 Front Load Washer
Water is leaking out washing machine door and now F-05 has come up on the machine. The number i got of the front of the machine is AQXXF149PI as am unable to open the door.
as too opening the door you would have to remove the lower panel and reach up on the inside right side and grab the pull cord that is attached to the door lock assembly as to the f05 error clean the pump clean out you have items stuck on the inside or as they say if you have kids special surprises lol if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations in the future Thanks again Rick
Feb 08, 2011 | Hotpoint Washing Machines
Hotpoint WMF720p - getting message F05 can you help? Water trickling out when draining and error message F05 appears inbetween all cycles.
You need to check and clean the pump filter.
If there is no filter located at the front of washer, (check handbook),
Then remove the rear lower rear panel of washer.
Remove large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Fit back and test
Please rate my solution.
Thankyou.t.
Jan 31, 2010 | Hotpoint Ultima WF860 Front Load Washer
F05 error for Whirlpool GHW9100L Front Load Washer
The following link explains the "F05" error code:
http://www.fixya.com/support/r629462-f05_error_code_whirlpool_duet_kenmore
I hope you find this information helpful. I have seen this error code generated by something as simple as a loose connector on the NTC sensor. Hopefully, you can resolve this with no expense. If you do require any parts, however, you can locate parts with illustrations at searspartsdirect.com or repairclinic.com. If you require further assistance, please let me know.
Sep 10, 2008 | Whirlpool GHW9100L Front Load Washer
ERROR CODE F05, FOR KENMORE ELITE HE3 WASHER MOD.110.43862400
Click on the following link for diagnoses and troubleshooting tips for the "F05" Error code.
If you have questions and/or require further assistance, please post back and let me know. I hope this helps you.
Jun 12, 2008 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
233 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
