Question about Humminbird 383c Fish Finder Gps Combo
383c no temp reading,even in simulator mode? replaced transducer already,still no temp reading...
  • 743 Answers
Try these steps:
Posted on May 26, 2012
2 Suggested Answers
  • 29 Answers
SOURCE: I have my Humminbird fishfinder
I would contact our customer service group and they will be able to help you. Our number is 800-633-1468.
Posted on Jan 11, 2011
Says no transducer connected and is in simulator mode. How do I get out of simulator mode?
the manual is here
http://www.humminbird.com/Category/Support/Product-Manuals/
I had this unit but gave it away recently. From memory, you just need to connect the transducer and make sure the transducer is in water. If not, it reverts to Demo Mode.
Aug 20, 2015 | Humminbird Piranhamax 170
Garmin 100 echo stays in simulate mode. Is there a setting to change it to live mode?
1 turn off the simulator in the menu.
if that does not work
2. Check the connection to the transducer, if it is unhooked or corroded, clean and reattach the connector, the unit will stay in simulator mode if it does not detect a transducer attached to it
Apr 21, 2014 | Garmin Gsd 21 Sounder Blackbox Fishfinder...
Hi I live in NZ and have a Humminbird 383c GPS Chartplottter which was purchased in the US. approx 2 years ago.It has a transom mounted transducer which I mounted in a piece of plastic pipe, epoxied in the...
Don,
We would recommend that you replace the transducer (if you want to keep the transducer inside the hull you may use the
XP 9 20 T with temperature and you can use epoxy to mount the transducer) If you want to keep in the compartment you have created you may want to just put water in the compartment with the transducer so its not shooting through the air.
If you have any other questions please email customer service at service@humminbird.com
Thank you,
Deborah
Humminbird Customer Service
Jan 12, 2011 | Humminbird XNT Transducers XNT 9 20 T ...
Raymarine a65 transducer 200kh fine 50kh not reading bottom
First do a factory reset and determine that all the setting are correct. You can get this info from the manual. Remember you will loose any saved way points when you do the reset. If that does not sort you out;Remove transducer from transom mount and duck tape it to a broom stick so that the transducer face is facing down. With the boat standing still in calm water and the ducer hooked to the DSM25 push it below the water and see if it see bottom on 50khz.The idea here is to get the ducer in another location to see that it is not getting reflections of the boat. 50Khz is very prone to reflecting of stuff around it. If you still have a problem I would send the ducer and DSM25 unit back under warrant .No need to send A65 back it should not have a problem.
Mar 30, 2009 | Raymarine A65 Combo GPS...
Eagle Cuda 128 does not read water depth
Hi Chris, Did you get a fix for this issue? My Dad's Eagle Cuda 128 is also having the same problem - constant reading of 60ft. I'd love to hear if you have a solution. Many thanks,
Mar 14, 2009 | Eagle Boating
383c transducer gives nothing but noisy red feedback at medium or high speeds
If it works at low speeds fine but has problems at higher speeds, basically you need to lower the transducer down further as it is lifted by the boat at higher speeds, or is getting caught in the turbulence of surface water created at higher speed. Lower the transducer a half inch at a time and re-test.
Sep 19, 2008 | Humminbird XNT Transducers XNT 9 20 T ...
Humminbird 383c Fish Finder Gps Combo Logo
134 people viewed this question
Top Humminbird Boating Experts
Mike Marcotte
Mike Marcotte
Phil Walker
Phil Walker
Steve
Steve
Are you a Humminbird Boating Expert? Answer questions, earn points and help others
