Question about Crystal Decisions Analysis 8.5 User Manual for PC
Crystal Reports Print Engine error text: Error detected by database DLL CRW 8.5
2 Suggested Answers
  • 394 Answers
SOURCE: I have a Ora10gR2 database
hi, I am Steve, lets get you some help
This sounds like a problem with the permissions for the read only user account in Oracle.
The quickest way to check whether it is a permissions issue is to log Crystal Reports into Oracle using an account with full access privileges and check the results then. If you can see the views and the fields, then it is a privileges problem with the read only user account.
Posted on Feb 01, 2011
Clkern.dll was loaded,but the dll register server entry point was not found.this file can not be registered
http://www.fix-all-dll-errors.com/clkern.dll/
Once you go to the above link click "Fix dll errors now" button,
it will register the dll file for you.
Dec 29, 2010 | Car Audio & Video
Canon i350 not recognised by any applications
This is quite a long one so be prepared: Assuming you use IE7 on Win XP FIRST: Are you using a Packard Bell machine or do you have "Surfairy" installed? If so you need to remove Surfairy. To see if it is present if you are not sure use the windows search facility to look for surfairy in my computer. It would also be usefull if you could post the exact text (if any) contained within the Script Error window. Second: pen a new notepad session, to be called IE_fix.cmd, and copy/paste the below: regsvr32 urlmon.dll regsvr32 Shdocvw.dll regsvr32 Msjava.dll regsvr32 Actxprxy.dll regsvr32 Oleaut32.dll regsvr32 Mshtml.dll regsvr32 Browseui.dll regsvr32 Shell32.dll regsvr32 Ole32.dll Save the file, then double click IE_fix.cmd and answer the prompts. Ignore any error messages. Reboot and test. If the problem remains follow the method below Start, Run, SFC /Scannow (Have your XP CD Handy. Note that this command does not give feedback on the repairs it makes. The repairs are listed in your Event Logs.) The error may be linked to a missing/corrupt system file in XP that IE 7 exposes. A repair reinstallatiion of XP will fix it, but the above steps are less drastic.
Jul 11, 2007 | Canon i350 InkJet Printer
The request could not be submitted for background processing
apo ke he nyo nih yob??kome doh make ko??
nate babi sggh mat/minoh saleh nihh..jubo ite..
Jan 11, 2010 | Crystal Decisions Crystal Reports 10.0...
Different Crystal output from model 9835 and 9855 Monarchs
Your software wouldn't care whether it's a 9835 or a 9855. It can't even tell the difference. Are your supply settings and communications settings the same for both printers? Any error messages on the display when you print?
Jul 08, 2009 | Paxar Monarch 9855 Barcode Label Printers...
Out of memory error
1. Use with - End With for values
with xlWbk.Worksheets(1)
.Range(.cells(1), .cells(4)).value = "Some Repeated Text"
end with
2. Use following VB code for killing excle at the end:
Private Declare Function FindWindow Lib "user32" Alias "FindWindowA" (ByVal
lpClassName As Any, ByVal lpWindowName As Any) As Long
Private Declare Function PostMessage Lib "user32" Alias "PostMessageA" (ByVal
hwnd As Long, ByVal wMsg As Long, ByVal wParam As Long, ByVal lParam As Long) As
Long
Private Const WM_QUIT = &H12
Sub TerminateExcel()
Dim lpClassName As String
Dim iHwnd As Long
Dim iReturn As Long
lpClassName = "XLMain"
iHwnd = FindWindow(lpClassName, 0&)
If iHwnd Then
iReturn = PostMessage(iHwnd, WM_QUIT, 0&, 0&)
End If
End Sub
Mar 17, 2009 | Business Objects Crystal ReportsĀ® XI...
Datamax WS6308 print error in .net
El controlador de Seagull es muy bueno y con muchos parametros, intenta modificar los parametros del spooler. Seagull driver is very good and with many parameters, try to modify the parameters of the spooler. buscar
Nov 24, 2008 | Epson Printer
Crystal reports version 8.5
I'm not an expert in Crystal Reports, however you might find my info and experiences to be of some use with your question. I've been working with VB6.0 for some time. One day I decided to checkout Visual Studio 2008, (which came with crystal reports) I decided I didn't like it and removed it from my computer. It was after the removal of crystal reports that my computer went to hell. Every program I tried to install since it's removal was not being allowed, also every program I tried to uninstall was not being allowed. After some research I found out that Crystal Reports was the culprit. It has a management package that was designed to protect it's rights management. Simply stated.....it was governing parts of my registry by setting certain parts of my registry key permissions to, "read only". I ended up having to use the administrative tool in Windows XP and reloading default permissions through an existing INF file thus resetting every registry key back to it's default read/write state. I would not recommend you do this. Doing so may harm your existing install of Crystal Reports. What I would do though if I was in your situation, would be to change just the one key that pertains to your .tmp file location in regedit. My guess is it would be located HKLM under software. You can change any key permissions by simply right clicking any key and go to, "permissions" However, if i'm guessing right, Crystal Reports has a backup mech. that would not allow you to change the key permissions even in regedit. In wich case you'll have to use a utility like ::.HERE.:: and create a custom bat file for just that one key. You can try contacting Crystal Reports directly but i'm quite sure they'll just tell you to kindly, "get bent" lol. This method of protection serves no purpose other then to protect their software from being pirated. So i'm 99% sure they won't help you in the matter that you need. Changing permissions to registry keys back to default would negate their program protective measures. From the problem you described i'm 90% sure that is exactly what is going on due to what I already know about the protection measures of Crystal Reports. Any file that is being generated with Crystal Reports, temp or otherwise is now governed by Crystal Reports through your registry, through a registry like firewall, also run by Crystal Reports. This is why you're getting Access Denied when you try to right click the file and delete it locally. You have two options.
1.) Become submissive and a slave to their tech support and wait for them to come up with a solution that will allow them to maintain control over your registry, with a patch of some sort provided by either Microsft Visual Studio or through Crystal Reports directly that will resolve your particular issue.
2.) Setup a dummy computer install all the crystal reports programs on it. Get it all setup, then do a full registry reset (from that link i posted above) and see if you can still use crystal reports after the full registry reset and if that truely resolves all the access conflicts. If so then apply it your main work machine and once again become the master of your registry.
Hope that helps,
9x
Aug 26, 2008 | Computers & Internet
Sharp copy/printer to staple Crystal Reports
this should be an option in your print driver make sure when you set up the print driver you added the accessories ie. a finisher
Mar 26, 2008 | Sharp AR-M550N Copier
Crystal Decisions Analysis 8.5 User Manual for PC Logo
164 people viewed this question
Top Crystal Decisions Computers & Internet Experts
David Payne
David Payne
Are you a Crystal Decisions Computer and Internet Expert? Answer questions, earn points and help others
