Question about Whirlpool Washing Machines
How do i reset my front panel?it says control locked and will not start
  • Whirlpool Master
  • 19,396 Answers
Hi.
If the front light lit is control locked, that means that your Whirlpool washer has been set in control lock mode.
Control lock is a special mode that will prevent user from changing settings or using control until the appliance gets unlocked again.
Most machines are set to control lock mode by holding down the CONTROL LOCK/UNLOCK button for several seconds. In the same way you can stop the control lock mode when the machine is already set to Control Lock.
When the washer is running and Control Lock is on, the machine can still be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
If the front light lit is control locked but the dryer door opens and it does not turn off, then you are probably in this situation. In that case, the door will be opening , but the machine still stays locked.
Disconnecting the machine from power, either unplugging power cord or tripping circuit breaker, won't help. The control lock system is designed to stay on in case of power failure.
If the machine is control locked, try unlocking it with the following procedure.
This is the procedure that works on most models:
To unlock: Press and hold down the CONTROL LOCK/UNLOCK button for 3 to 5 seconds to turn the control lock feature off.
If that does not work, try disconnecting power for five minutes to reset the machine, and eventually do unlock again. As said, cutting power alone will not cause the machine to unlock.
If still no luck, then please give us the model number, some model may require a different procedure.
If the machine is still not responding, the lights stay on all the time, the dryer panel does not respond to control unlock procedure, and the door does not lock anymore, then it may be a defective control board.
If you are in this situation, before replacing the control board more parts, including the door lock must be tested. In that case the best option may be contacting the Whirlpool support number listed on the Dryer use and care manual, usually in the last pages.
If you need more help, then please provide the model number.
Thanks.
Ginko.
Posted on Nov 10, 2010
My front load washer is a model 9150pw4 and the control locked light is on and there is no functions. What happened and can it be reset?
The Control Lock is a safety feature that enables the consumer to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance. This can normally be reset and usually is not an indication of a malfunction.
With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. It can inadvertently be set following a power outage, leaning against the control panel, or pressing and holding the wrong button.
If this is a Whirlpool manufactured appliance (such as Kenmore Elite, Maytag Epic or Whirlpool Duet), the following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
These instructions are also printed on the front panel of the appliance and in the owner's manual.
If this does not correct your problem, then you may have a more serious problem than a simple operator control button issue (such as an operator console problem or main control board issue). Please post back and let me know if you need further assistance.
Jun 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control lock on
The Control Lock is actually a safety feature that enables the consumer to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance. This can usually be reset and does not require a technician.
With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. It can inadvertently be set following a power outage, leaning against the control panel, or pressing and holding the wrong button. This is usually not an indication of a malfunction.
If this is a Whirlpool manufactured appliance (such as Kenmore Elite or Whirlpool Duet), the following link explains how to lock/unlock this feature:
May 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Controls locked
The Control Lock is a safety feature that enables the consumer to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance. This can usually be reset and does not require a technician.
May 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do I unlock the controls on the washing machine. Control Locked light is on and I am unalble to start machine,
If this is a Whirlpool manufactured front loader, the following link explains how to lock/unlock this feature:
If this does not correct your problem, then you may have a more serious problem than a simple operator control button issue (such as an operator console problem or main control board issue). Please post back and let me know if you need further assistance. I hope you find this information helpful.
Apr 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control panel locked,how to unlock
Please post back if you still need assistance. I hope this helps you.
Apr 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control lock stays on how do I reset
Try the "End of Cycle" button to the right of panel front, next to Start button.Hold for three seconds to lock/ unlock control.
Apr 09, 2010 | Maytag MAH8700A Front Load Washer
It is showing control locked
The Control Lock is actually a safety feature that enables the consumer to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance. This can easily be reset and does not require a technician.
With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. It can inadvertently be set following a power outage, or by leaning against the control panel and is usually not an indication of a washer malfunction.
If this is a Whirlpool Duet series, the following link explains how to lock/unlock this feature:
These instructions are printed on the front panel of the appliance and in the owner's manual.
If this does not correct your problem, then you may have a more serious problem than a simple operator control issue (such as an operator console problem or main control board issue). If you need further assistance, please post back and let me know. I hope you find this information helpful.
Apr 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My control locked button is lit on the control panel of my front loading Maytag Epic. Therefore, I cannot start a new load (which I just put in). The door easily opens and shuts as itnormally does. Any...
The Control Lock is a safety feature that enables the consumer to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance. With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. So, holding the "OFF" button will not clear it. It can inadvertently be set following a power outage, or by leaning against the control panel and usually is not an indication of a washer malfunction.
If this is a Whirlpool Duet, Kenmore Elite or Maytag Epic series FRONT LOADER, the following link explains how to lock/unlock this feature:
If this does not correct your problem, then you may have a more serious problem than a simple operator control issue (such as an operator console problem or main control board issue). If you need further assistance, please post back and let me know. I hope this corrects the problem for you.
Mar 17, 2010 | Maytag EPIC MFW9700S Front Load Washer
It said contorls locked and will not work. I tried to unplug and reset no luck.. any suggestions please!!!!!
The Control Lock is a designed safety feature that enables the us to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance.
The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Mar 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore elite washer- won't start - control on front says controls locked. I tried unplugging it but still won't start.
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 28, 2010 | Kenmore HE2 Plus Front Load Washer
Washing Machines Logo
335 people viewed this question
Sal De
Marvin
Marvin
jimorris77
