Question about Cuisinart DCC-1200 Coffee Maker
Cuisinart coffee maker stuck in cleaning mode keeps steaming
  • 85 Answers
SOURCE: self clean light keeps blinking
Hello guindonlm,
I recently had this similar problem. Try the following.
Your described problem may be one of two problems. Let's start with the easier solution first. In the DCC 1200 there is a filter "stick or column" in the left rear. Pull it out and remove the clogged carbon filter(s) that are in there. Shine a light into the receptacle and remove the debris in the bottom. It is likely that this is causing the problem with you machine needing to be started on multiple times. See if this solution works. If it does, you might run 8 cups of water and 4 cups of vinegar through to help decalcify the units plumbing. Do this once or twice and then rinse with at least one pot run-through of clean water. If this works then you are good to go.
Next, if this does not solve your problem we can do the following: unplug the unit and lay it on its back. You will need a #10 torx driver (hardware store if you don't have one) to remove the bottom cover plate. There are 4 torx screws holding it on. When removed, you will find 2 orange hoses. Carefully attempt to remove the left hose without splitting. I used a eyeglas screwdriver to loosen it up. If it splits, just cut off the split and stretch it to reconnect when time comes. As you look into the hose you will find a little black valve inside as well a some gunk. Clean it all out with a fine wire as best you can. Rinse well. Attempt to reconnect the hose back onto the pipe. Slip the pipe clamp back into place. Replace the cover and screws and you should be good to go again. This is not as daunting as it may seem. You can do it. :o) Good luck! If this answer helps, please leave positive feedback for me. Much appreciated. Regards, NormanZ
Posted on Jul 08, 2009
  • 4 Answers
SOURCE: Cuisinart Dcc-1200 coffee maker is gurgling a lot,
I had this same problem and found that coffee grounds had somehow gotten in to the water reservoir and had been circulating thru the machine clogging the charcoal filter. This must have prevented the water from entering the heating chamber efficiently and therefore continued to gurgle until it all got thru. I flushed out the reservoir by holding the pot upside down and shooting water into the reservoir. It took some time to get all the grounds out. I took out the charcoal filter, flushed out that section and replaced it with a new filter. When finished, I ran thru a solution of white vinegar for good measure and bingo!! The coffee pot works perfectly.
Posted on Mar 05, 2010
  • 4 Answers
SOURCE: my 12 cup cuisinart coffee pot keeps shutting off
I have the same pot except for the 10 cup model, and it has been doing the same thing. I realized that I have never changed the charcoal filter inside, and I believe that may have been the problem. I removed the filter, ran vinegar through the pot several times as well as cleaned some nasty looking scum out of the water reservoir. I ran 3 pots of water after that. The problem has not recurred so far. I think it may be fixed although time will tell for certain.
Posted on Mar 27, 2010
  • 19 Answers
SOURCE: Cuisinart Coffee Maker DCC 2200
The user manual is a free pdf download from the cuisinart web site.
Posted on Jan 19, 2008
  • 4 Answers
SOURCE: Cuisinart DCC-2000 12-Cup Coffee Maker shuts off after brewing
Turn the function knob to Auto Off
Hold down the hour button til you see the clock display blinking
you can then use the Hour and Minute buttons to program how long you want the coffee maker to stay on.
You can choose from 0 minutes (seems to be what you have it set on now) to 4 hours.
Posted on Nov 15, 2008
Cuisinart DC 1150 (10 cup) coffee maker leaks out of the top.
I have experienced this same problem. You have to pour the water directly into the holding bay, avoiding the edges. I think water gets stuck around the rim, it just steams over the edge, or drips down the front and back onto the counter. I don't know why, but it happens, so just make sure you pour the water directly into the bay avoiding edges.
Nov 27, 2010 | Cuisinart DCC-1200 Coffee Maker
Will switch during brew cycle to clean
I'm dealing with the same problem! It steams so much my cabinets are wet and the coffee is way too strong.
Oct 10, 2009 | Cuisinart DCC-1200 Coffee Maker
Cuisinart 12-cup grinder coffemaker all gummed up
It is endemic to this unit - condensation builds up in the grind chute, which makes the grinds stick to the walls of the chute. Decalcifying with vinegar/water helps, but only in an indirect way - by keeping the inside tubing clean, decalcifying generally allows the water to flow through the machine without obstruction. Inside tubing that has calcium, lime deposits built up obstructs water, and makes it flow through the machine slower - when water flows more slowly through the machine, the machine steams off the water at a higher rate, hence more condensation builds up in the grind chute walls.
Generally, i have found all Cuisinart coffee and espresso makers to be high maintenance to a greater or lesser extent, but the Grind-n-Brews have the highest cleaning/maintenance requirement.
Mar 26, 2009 | Cuisinart Coffee Makers & Espresso...
Can't get milk to foam
Place 1/3 part distilled white vinegar and 2/3 part water into the water reservoir. Turn the machine on and wait for the heat light to go off. Once the heat light goes off, turn the steam vs. water knob to the water drop icon, and turn the main function knob to steam/water. Make sure to have your frothing cup underneath the steam element ready to catch the water. The vinegar/water solution should clear out the calcium that clogs the steam element. Also, remove the cover to the steam element and dip it in a bowl with vinegar for about 5 minutes, and use something like a pipe cleaner to clean out that cover. Then apply vinegar and hot water to a rag and clean the calcium off the shaft of the steam element. Once you are all finished with this, run plain water through the espresso maker on the steam/water setting to clear out the bitter vinegar residue. Now, try again to make espresso and froth it.
Since milk contains calcium, the steam element has to be decalcified more often than a regular coffee maker. The EM-100 is a beautiful machine, but it is definitely high-maintenance - you will probably spend more time cleaning it than making cappuccino, etc.
-Tha Mp3 Doctor (is also a huge Cuisinart fan)
Feb 22, 2009 | Cuisinart EM-200 Espresso Machine
When brewing, it steams and spits the water out
this is what happened to me, I didn't have the filter basket all the way down so the pot lid didn't open the valve that lets coffee flow so the coffee and grounds ran into the water resevior and plugged the filter, so I did the worst thing possible and took the filter out so the grounds got into the check valve that keeps the hot water going in the right direction. that makes it spit and sputter and brew slow.
after trying to flush it out forever I tore the metal plate on the bottom off and unhooked the rubber hoses (don't do this unless you have a needle nose pliers, you'll never get them back on) one should go to the brew head and the other is the water inlet, this has the check valve. you can tell which is which by blowing through them and seeing which one goes to the brew head. if you can blow through the other one the check valve is stuck open, I blew air into it with an air compresor and this forced the check valve shut and now it works fine. I know this is the same symptons as calcium deposits but I had cleaned it twice.
try flushing it with water first but sometimes it takes extreme measures
Jan 11, 2009 | Cuisinart DCC-1200 Coffee Maker
I got a Cuisinart coffee maker DCC 1400C for a wedding present, worked fine, then all of a sudden STOPPED. I did the self clean, and that worked fine, the brew setting doesn't. The water doesn't go...
Unplug for 20 minutes or longer to reset. Make sure the lid is on the caraffe, or the brew basket will be stuck in the closed position. If the water still won't go through, consider ordering a new brew basket, because yours might have a faulty spring.
-Tha Mp3 Doctor
Dec 30, 2008 | Cuisinart DCC-1200 Coffee Maker
Cuisinart automatic grind and brew
Clean it out with vinegar and water - 2 ozs distilled white vinegar, 2ozs water
Dec 08, 2008 | Cuisinart DCC-1200 Coffee Maker
Cuisinart DCC-1200 Coffee Maker Logo
1,017 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
