Question about Lexmark E342n Laser Printer
My 343n is printing faint on one side does anyone know why, we have 80% toner and 28% left on the photoconductor life
    Genius:
  • 1,087 Answers
Try to use different supplies - if you have another toner and another PC kit. If the supplies are working fine, it could be the transfer roller that's causing the faint prints. I would suggest cleaning the transfer roll with a soft cloth. If problem continues, you might need to replace the roller.
Posted on Nov 10, 2010
Testimonial: "Thanks Printech I will try them and hopefully it will sort out my problem many thanks"
It only prints on the left side of the paper. The print fades and then there is nothing on the right hand side. It doesn't matter what you print or from what program, only about 2" prints down the...
1. Take the toner out and shake it side to side so you even the toner level in the cartridge.
2. If this won't fix it, check toner level, might be low. If low, you need to replace toner.
3. Last option, you might have to replace the Photoconductor Unit.
Nov 11, 2010 | Lexmark C543dn 26B0000 Workgroup Up to 21...
Right hand side page print quality very poor, almost unreadable
this is cause of the lens is dirty with toner droping..
open the front cover and on the right side, there is a level for you to pull out.. at the right side of the printer, open the small cover and you will be able to find a cleaner. To clean..pull out the holder few times.. by applying slight pressure..that will clean the bottom lens..and u should be able to print out fine now..
Feb 26, 2010 | Epson Aculaser C1100 Printer
I swapped Photoconductors from 2 other 1710's; no go. Reset?
Problem
Dell 1700 printer prints out a page announcing that “the photoconductor has reached its useable life and it needs to be replaced for a new one”. You replace the photoconductor for a new one and the error light is still blinking and the printer keeps on printing the above mentioned page.
Solution
Steps to Reset the Photoconductor:
  1. Power off printer
  2. Open the front cover.
  3. Press the continue button; while pressing the continue button power on the printer and wait (still pressing the continue button) until the error led is solid, then release the continue button.
  4. Close the front door, all light should be solid.
  5. Wait until POST finishes.
  6. Press the Cancel button 4 times slowly, the toner led should be solid.
  7. Press the Continue button until all lights go up and down, then release; the Toner Low led is solid.
  8. Power off printer and then back on.
  9. Press continue button once, print a test page.
  10. Check the information about the photoconductor in test page, it should display an OK status.
Note: if these steps don’t work for the first time repeat three times. If still the steps don’t work, the printer needs to be replaced for a new one.
Jun 26, 2009 | Dell 1700n Laser Printer
Printer making marks down the left hand side of every page
hello,
This sounds like the photoconductor units for both black and blue need to e replaced. Open the front of the printer like you are changing toner cartridges. On the front door parts that opens to you there will e four pieces, 1 for each color. Look at the one with blue on it and the one with black and look on the ends of these, they are the photoconductor units. I bet both of the colors have worn sections compared tothe magenta and yellow ones. The replacement part number is C53030X and you will need 2 of these. They have a life span just like toner and have to be replaced too.
I hope this helps,
Buddy
Corporate Computer
Over 21 years of PC and printer support/repair
Jun 18, 2009 | Lexmark E232 Laser Printer
Ghost image on Epson Acculaser C4000
Ghosting can be caused by several components: 2nd BTR transfer roller, Photoconductor Unit (PCU) or the Fuser unit. The most likely is the PCU contacts being dirty, caused by toner getting between them. Open the front of the printer (cover B) and lift out the photoconductor. Clean all of the metal contacts down the sides of the PCU with a cloth and wipe out any loose toner from inside the printer and give the contacts inside the printer on the R/H side a good clean. Replace the PCU and close the front cover.
Hopefully all will now be well, if not open cover A and clean the transfer roller on the inside of the cover. If problem persists you will need to get a Tech out to look further as without seeing the printer it is pretty hard to diagnose.
Good luck.
May 20, 2009 | Epson AcuLaser C1900 Printer
Black streaks down left side of printouts Epson Aculaser C2600
I had exactly the same problem. Luckily we have 3 of these printers. Swapped the photoconductor and it solved the vertical streaking, even though the photoconductor was only half way through its life.
Dec 02, 2008 | Office Equipment & Supplies
Lexmark E232 Printer prints all characters fine but leaves about an inch gray/black margin on the left side of the paper. Tried replacing the toner cartridge and it didn't help. Any suggestions?
If this model has separate toner and photoconductor then the photoconductor is at end of life and needs to be replaced. Follow the directions that come in the new photoconductor package to install and reset the PC count this is important.
Luck
Mar 07, 2008 | Lexmark E232 Laser Printer
Faint Black Lines
Hi best way to check is to remove the black photoconductor and you should be able to see the little lines on it also check the the black dev/toner unit for the lines. most likely to be the black photoconductor unit though.
Thanks J
Jan 24, 2008 | Ricoh Aficio CL3500N Laser Printer
Lexmark printer error at power up
pc stands for photoconductor or print cartridge or in layman's term toner
the toner has reached its expected life or toner has ran out
Oct 03, 2007 | Lexmark Optra SC 1275 Laser Printer
Lexmark E342n Laser Printer Logo
226 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
