Question about Frigidaire Freezers
Ffu17fc4aw2 model commercial freezer won't get cold. has defrosted on its own before, then worked. Now defrosted and won't get cold again.
SOURCE: True Commercial freezer not cutting out
Tech. can not find freeon leak in line but endicator is regestering freeon leak in side of back panel.
Posted on Aug 27, 2008
SOURCE: Frigidaire MOdel LFFU1765DW9
I have a frifigidaire freezer LFFU1765DW9 . it is not cold at all the light in side is on the power is on but the fan no run and the compressor is not run.
Help please
Posted on Jun 01, 2010
  • 384 Answers
SOURCE: Older Gibsonl upright freezer not cold
dear sir
please make sure first your freezer is well clean if it is already clean then contect to maintenance personell for refilling the gas.
hope answer the question.
thank you.
Posted on Jul 09, 2010
SOURCE: We have an imperial upright ''commercial grade''
just to be sure that your door is sealing properly, put a flashlight into the freezer and turn off all of the lights in the room to see if there are any openings in the seal. Iam suggesting you this coz sometimes a small opening may pass our eyes easily....
if the door is sealing properly......
If this is the type of freezer where the shelves are the evaporator coils, the coolant goes through the shelves(tubing) and the formation of frost is normal and has to be manually defrosted.All the shelves should be as cold asd the top one. The fact that just one has any frost may indicate that it is low on freon. If this is the case you should notice that the freezer doesn't get cold enought just like you said... so check your freon levels.
This could also be because of the thermostat not sensing when the fridge reaches its set temperature and as a result of this the compressor will keep on running and build-up of ice will occur.
Follow the advices in the order prescribed above and you should be set
Posted on Jul 27, 2010
miket756
  • 2702 Answers
SOURCE: freezer is only 6 years old and compressor stopped
this could be just the thermostat stoped working and not the compressor at all, check the stat out first
Posted on Nov 28, 2010
Testimonial: "Great will check out thermostat. many thanks"
Freezer makes really loud noise
You need someone to check the fans and where the noise is coming from before the repair cost you a lot of money because of damage it can cause. The fan may be hitting ice in the freezer or out of balance because it is worn out. No one can hear what you hear and someone will need to be there to check these things out, Sea Breeze
Jun 10, 2013 | Frigidaire Freezers
My true freezer won't defrost?
Check the defrost timer (in the base, circular knob you can turn till it clicks) If it doesn't heat up rapidly in the evaporator, there is a safety overheat device (thermistor) that may be cutting power to the heater, or there may be a fault with the heater itself. Are you sure the fans are working, and the condenser grill is nice and clean?
May 14, 2012 | True 72 cu. ft. / 2039 liter Commercial...
True model gdim-26. runs fine unitl defrost then does not keep cold after defrost.
Hi, sounds like your defrost clock is stuck in the defrost mode. On most true boxes they have a paragon defrost clock with adjustable pins you can set the amount of cycles and duration of the defrost cycle. Find the clock and give it a turn in the direction of the arrow or cw. It will come out of defrost and start to freeze again. If it continues, you may need a new clock. Let me know what you find. Keep me posted. True boxes are top of the line
Sincerely,
Shastalaker7
Mar 23, 2010 | True 26 cu. ft. Commercial Freezer GDIM-26
Frigidaire MOdel LFFU1765DW9 This is a commercial self defrosting model freezer, upright, and water leaks out of the bottom right side every so often. Why and what should I look for to fix it.
Help please
Jun 21, 2009 | Frigidaire Freezer Refrigeration White...
Traulsen freezer URS48DT
Turn cold control to Max. This keeps your compressor running for this troubleshooting exercise. Find and manually advance the defrost timer with a screwdriver or something similar. This will shut the compressor down and bring the defrost heater on. If this happens then you will know that your timer is bad.
If it is not that, the next thing to look at is the defrost heater itself or the thermal overload on your defrost heater. This keeps your defroster from overheating.
Jan 20, 2008 | Traulsen 7 cu. ft. / 198 liter Commercial...
Freezers Logo
76 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
