Question about Panasonic DP-C264 Copier
Forgotten key operator password for Panasonic DP-C264. How do i reset it?
5 Suggested Answers
  • 990 Answers
SOURCE: Fault E05-02
Hello sir; According the manu, the error you display,it means 12 volt low voltage power supply board have problem, change it.
Posted on Apr 28, 2009
SOURCE: password reset
You can not reset without old pass word , remove back panel and look for a round battery (disk ) remove for 30 Sec. turn on & off , and then replace battery. reset pass word
Posted on Apr 25, 2008
  • 990 Answers
SOURCE: I miss my manual of Panasonic DP-C264 1 year old;
Hello sir; You may go on web side to down load, the address is www.panasonic.com
wheatlandsvc
  • 1110 Answers
SOURCE: what is the default username and password for the
Try this:
User Name:
Password: 00000000
Posted on Oct 21, 2009
Drum reset counter
When the drum is replaced the counter on the DP-C264 automatically resets. If it does not reset then the flag on the back of the drum has been damaged in shipment or during the install of the drum.
Oct 11, 2013 | Panasonic DP-C264 Color Copier
Panasonic service mode
5.1.1. Service Mode Procedure
1. To select the Service Mode
The Service Mode is selected when "FUNCTION", "ORIGINAL SIZE (LEDGER/A3)" Keys and Key "3"
enter password (00000000) and enter
on the keypad are simultaneously pressed, then F1 will appear in the display.
2. To exit the Service Mode
The Service Mode is reset when the "FUNCTION" and "C (CLEAR)" keys are pressed simultaneously
Sep 06, 2012 | Panasonic DP-C264 Copier
HOW CAN I CHANGE PAPER SETTING IN PANASONIC DP-C264
It is a little more difficult to explain. If you send an email to LBrown18062@hotmail.com I will send you the manual that has a step-by-step picture guide that will guide you thru this process. Please put "panasonic dp-c264" as the subject.
Jan 31, 2012 | Panasonic DP-C264 Copier
Got a panasonic dp-c264 at a clearance auction/liquidation. It has a password to print. Any way around it. Also, how do i get it connected to a standard home computer. It eems to only have a ohone line...
You have to go into F-5 service mode to disable it.
While holding "function" key,press and hold "copy" key. While holding these two keys, press and hold "3" key. Press "5" then the green start key. Key in "42" then start key. Should show "KEY/DEPT counter". Press "no" to disable all codes. If you just want to disable printer codes while leaving copy codes intact, go to F5-65 to disable printer mode. After this, press "stop" key twice. While holding "function" key, press "clear" key to return to ready mode.
On the right side near the rear, there are ethernet and USB connections. You can get the drivers from Panasonic.net.
If you have a phone input on the back right near the bottom, you have a fax board installed.
Feb 27, 2011 | Panasonic DP-C264 Copier
Ho un problema devo resettare il drum panasonic 264
press the ''function' key the 'original size' key and the number '3' all at the same time. scrren will display self test then press '9' or you can scroll down to 'unit maintainance ' press 'Start' key then you need to scroll to RAM initialize press 'start' key then scroll to 'All job clear' machine will restart when operation complete.
Jan 28, 2010 | Panasonic DP-C264 Copier
How do I get a meter reading on a DP-C264?
Press Funtion Key. Menu will pop up on display to see counter. Press this key to get color and black and white page counts.
Dec 29, 2009 | Panasonic DP-C264 Copier
What is the recommended copier maintenance for Panasonic DP-C264?
120K and 240K are the big ones? as for the price call around?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Aug 17, 2009 | Panasonic DP-C264 Copier
Panasonic dp c-264 error e04-34
Fuser code, reset in service mode F9 -06-04, continues to come back new fuser required
Aug 05, 2009 | Panasonic DP-C264 Copier
I miss my manual of Panasonic DP-C264 1 year old; how can I do?
Mar 15, 2009 | Panasonic DP-C264 Copier
Panasonic DP-C264 Copier Logo
345 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
HEMANT GROVER
mahesh y.h
mahesh y.h
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
