Question about Keurig B70 Coffee Maker
A few days after descaling my Keurig (because the machine asked me to) using the white vinegar method, I am getting the descale message again. Do I really need to descale once again?
    Problem Solver:
  • 10 Answers
Instead of 4 hours (descaling as instructed in the manual), soak it longer 16-24 hours if possible. The only way that worked for me. I tried the paperclip trick. I also used the hose (water pressure) to the reservoir input (tank removed) to blast any clog. Nothing worked except the longer vinegar soaking.
Posted on Jun 10, 2015
  • Keurig Master
  • 43,501 Answers
Yes, it may take more then one time...
Check out this tip about how to descale your Keurig coffee brewer
How to Descale your Keurig Coffee Brewer
heatman101
Posted on Feb 23, 2011
How to descale keurig elite 40 coffee maker with vinigar
Unfortunately you will need to use vinegar. The acetic acid in vinegar is strong enough to clean most brewing machines.
Use distilled white vinegar.
Aug 17, 2014 | Keurig Elite B40 Coffee Maker
No water coming out of keurig
You need to descale it. Mine usually just stops working like that without the descale light coming on until after I start the descale procedure (go figure). This is from the Keurig website. Don't bother starting until after you get a bottle of white vinegar...in fact, get TWO bottles because you will probably need it again in the future.
http://www.keurig.com/customer-service/brewer-registration-and-support/~/media/files/keurig%20brewer%20manuals/de-scaling_instructions.ashx
Apr 16, 2014 | Keurig B60 Coffee Maker
Regardless of setting, I have not been able to get any more than 1/4 to 1/3 of a cup of coffee. The water barely comes out and now the descale message is on the screen. I need instructions for...
Although this is in "Problem with Vacuums," I found it while searching for a solution to my steam cleaner vacuum problem. You must be talking about a Keurig or Breville-Keurig coffee maker. Tap water, especially chemically softened tap water, contains minerals that require periodic descaling, as often as every two months if you make only a couple of cups a day.
Filling the tank with white vinegar and making multiple large mugs without a Keurig coffee cup in the holder will remove most scale. There are products that claim to do better than white vinegar if this does not work. Amazon sells a couple of brands in its Keurig section.
It will take several tank fulls of clean water to rid the machine of the vinegar or commercial cleaning solution. Use distilled water for this. Then switch to good bottled water without a heavy mineral load.
Jun 13, 2011 | Vacuums
The message "descale" is on and even though we
the best and cheapest descaler is vinegar. Let it sit in the machine for a couple of hours and then run it through a few times. Works wonderfully!
May 02, 2011 | Keurig Platinum B70 Coffee Maker
Keurig B70 won't stop cycling water. it just keeps draining the resevoir. Water is cold, not heated.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Feb 02, 2011 | Keurig B70 Coffee Maker
Will not fill cup and descale light stays on have descaled about 6 times and still want go off on large cup of coffee setting it takes about 4 times to fill cup really love the machine but its screwed up...
We have a Keurig ourselves and were stumped when we first saw that descale message on the brewer.
There are a number of ways to descale a brewer, the least expensive being to run some vinegar through the machine a couple of times, and then run cold water through a few more times to rinse it.
However, simply trying to clear the lines often doesn't work. And as you will see from the many comments below, by far the most reliable way to get your Keurig brewer working again is the "Slap and Burp" method.
Here is how you do it.
First, unplug the brewer and remove both the water reservoir and drip tray.
Next, hold the brewer upside down over the sink and slap the base a few times. And I mean really slap it.
Now put everything back together and try brewing again. Most of the time this works with a couple of good slaps. If not, try it again.
And don't worry, there are no laws against giving your Keurig a good slapping!
Sep 21, 2010 | Keurig Platinum B70 Coffee Maker
Descale light stays on and the rubber washer on tthe top spikeseems to be part of the problem. help me
Jul 31, 2010 | Keurig B60 Coffee Maker
How to descale
Use 1/2 cup white vinegar in 1 quart water. No need to let it sit. After descaling, remember to run at least 3 cycles with clean water to remove any vinegar.
Jul 11, 2010 | Keurig B50 Coffee Maker
How do I get the de scale light to go off at start up?
Hi
The descale light will only go off if you complete a descale on the machine. You will have to go to your owners manual and read how to descale your machine.
Here is a PDF page for Keurig machines if you don't have your manual.
http://www.keurig.com/help/De-scaling_instructions.pdf?mscsid=M01CDDDKUQG48JSQ2VFR393P4B500439
They say to use white vinegar but I recommend Commercial descaler like from Starbucks or you can get it from online vendors. Vinegar leaves a taste unless you get it all out, after a couple of rinsings.
Oct 18, 2009 | Keurig Coffee Makers & Espresso Machines
How do you descale the keurig B40
use descaling product not vinegar ,vinegar remove calcium in little piece descaler melt calcium 1 part descaler 1 part water fill water container start machine for a few second turn off let it seat for 15 minute repeat untill empty to reset the lightnormally its maneer of pressing the on button
i get back to you on that one pierre
Feb 24, 2008 | Keurig Elite B40 Coffee Maker
Keurig B70 Coffee Maker Logo
2,856 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
