Question about Dell E156FP 15" LCD Monitor
Power supply Please help me with my problem i have a dell lcd monitor and everytime i try to open it the main switch automatically turns orange as it it was on a sleep mode, i have already adjusted its power cord but still nothing happens and upto this time i still cant open my monitor. What do you think is the problem? pls. advise..Thanx..Bankero
  • dell monitor Aug 03, 2008
    My Dell 15 inch LCD Monitor started shutting down a few weeks ago. Sometimes I can click the monitor power button, the green light appears, the monitor comes on, then the screen goes black and the green light turns orange. How can I fix this and what is the problem?
    Genius:
  • 1,847 Answers
It is not the power cord you should chk for th video cord. it mean there is no siginal coming from the CPU.
Thanks for using fixya. Hope this solution may have helped you.
Posted on Jun 17, 2008
Dell cannot on, orange bling on power
Is this on the monitor on the machine itself?
If it is on the dell workstation you may need to replace the Power Supply Unit (PSU). A strong indicator of this is when you go to turn on the machine the power light continuously flashes an amber color, which may appear to be orange.
Let me know if that helps.
Apr 26, 2014 | Microsoft HannsG HU171D 17" LCD Monitor
Dell monitor E156FPb went black
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Jul 29, 2010 | Dell E156FP 15" LCD Monitor
The screen on my computer (dell E153FP 15" lcd) keeps going black everytime I turn it on. I can still see a very dark picture and the green light is still on but I can't see much. Usually I just turn it...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Replacement bd. www.lcdrepair.us
May 20, 2010 | Dell E153FP 15" LCD Monitor
My dell monitor turns on for 2 seconds then goes black and the green light blinks orange
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Replacement bd: www.lcdreapir.us
May 14, 2010 | Dell E173FP 17" LCD Monitor
Acer al511 Powers on Problem
I would try this monitor with other PC first before taking it apart.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Apr 03, 2010 | Acer AL511 15" Flat Panel LCD Monitor
I assume that you already try this monitor on another PC to verify that the problem is in the monitor, in this case you need to open it up and inspect the fuse, transitors, solder connections on the power/inverter board, see failed Dell monitors here for guide: http://s807.photobucket.com/home/budm/allalbums
Mar 23, 2010 | Dell E173FP 17" LCD Monitor
I have a dell lcd tv/monitor that just stopped powering on. it flashes an orange light where the power button is.
Power supply module will be the first place to look at, from what you describe, at least the 5v standby power supply is still working, It can be the power supply module is bad or it is not getting the control signal from the main board to turn on the main power supply on.
Oct 31, 2009 | Dell W2606C 26 in. HD-Ready LCD Television
Problem in Auto adjust mode
Auto Adjust work on the basis of resolution to which Windows set. It occurs mostly if Video drivers are not installed. Please check and install video drivers and also try to change screen resolutions from display properties in control panel.....
Nov 06, 2008 | Dell E176FP 17" LCD Monitor
Dell Monitor won't stay on
When it goes black, does the power buton stay green or is it orange? If it's orange, the power supply/inverter is your main culprit. If the power button stays green, it sounds like the backlight for the display is bad. Either way, unless you have parts for the same monitor laying around to swap out, you're due for a new monitor. The good news- with the economy in the tank, you can search online and find some reputable vendors selling nicely sized screens for less than $100! Heck, I've even seen a 22" for $129 (once but it was there).
Sep 23, 2008 | Dell E177FP LCD Monitor
Monitor lives its own life ;) Turnes off and on in random moments
It sounds like there's a problem in the power supply or inverter section and it's just teetering on the edge of failure. The disruption of the signal is apparently just enough to kick it over the cliff until it's reset. Sooner or later, it'll need some help, like connections, capacitors, output transistors, capacitors, transformers. Those are the most common failures in these. I think you'll see it get worse
Jan 25, 2007 | Dell E173FP 17" LCD Monitor
Dell E156FP 15" LCD Monitor Logo
139 people viewed this question
Alun Cox
