Question about Panasonic KX-TGA560 Cordless Expansion Handset
Phones work normal, but won't ring for incoming calls
  • 2 more comments
  • whtwolf810 Nov 11, 2010
    I did that. The phone works normal, we can call out, it will ring when we use the intercom, so the speaker is working. It just won't ring for incoming calls. We have a regular line line that rings.
    No broadband, Verizon.
    We have a short cable, We bought new phones with new cables and the phone rang for the first few times and stopped. We sent he phones back.
    We have tried everything with no luck.
    I am thinking of rewireing the phone lines. Thank you.
  • whtwolf810 Nov 14, 2010
    My problem was resolved by replacing a 17 year old wall receptacle.
    Thank you for trying to help me.
    President:
  • 1,932 Answers
Try this
Go to Menu > Ringer setting > Ringer volume.
Use right and loft navigational key to change it. If the ringer volume is set to maximum then the problem lies with the hardware only.That is the speaker is not working.Contact the nearest Panasonic service centre.
Thank You
Posted on Nov 10, 2010
  • 2 more comments
  • Udhaya Rajan
    Udhaya Rajan Nov 11, 2010
    Do you have any broadband connecting this phone through filters?Try connecting directly to the phone with out filters.Which network provider you are using?
    Thank you
  • Udhaya Rajan
    This happens due to the fault in cable.The cable which coming to the cordless phone should be less than 6 feet.Due to using large length cables the voltage drop is more and the required voltage is not supplied.Due to aging also this happens.
    Thank you
  • Udhaya Rajan
    Yes rewire it and use the new cables.That is problem.
    Thank You
  • Udhaya Rajan
    Udhaya Rajan Nov 14, 2010
    Thank You
SOURCE: Two incoming calls issues
What type of phone system do you have?
Posted on Dec 22, 2007
cnavarro
  • 2460 Answers
SOURCE: Night switching for KX-T7630
You have 4 different modes of calling available to be programmed: DAY NIGHT BREAK and LUNCH. Your installer has to set up the ICD groups, but you can create a LUNCH group which looks like the day mode but rings all phones. The codes are accessed by dialing on the intercom *780x where 0 is day 1 is night 2 is lunch and 3 is break.
You may use the NIGHT mode in the daytime, but if you have voice mail, it will play the night greeting instead of a day greeting.
Carl
Posted on Sep 09, 2008
consultel1
  • 860 Answers
SOURCE: Incoming calls to office cause all phones to ring in classrooms
Changing ringing on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
Next press the left hand intercom twice
The display should say system programming
Press the right hand intercom once. The display should say Centralized Programming.
Enter in the extension number that you want to program.
Press the line that you want to ring.
A solid light on the line means immediate ringing
A slow flashing light means delayed ringing (meaning the phone will wait 3 rings before starting to ring.)
A fast flashing light means no ringing.
When finished with that station press the right hand intercom and enter in the next extension to program and set ringing accordingly.
Press feature "00" to logout
Hope that helps
Posted on Feb 19, 2009
SOURCE: Make All phones ring when there is an incoming call
I have a DtermSeries E and the second line blinks but does not rings.
Posted on Aug 03, 2009
consultel1
  • 860 Answers
SOURCE: Norstar Meridian M7100 incoming calls - no ringing tone
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear & ring
press the Chng key till it says appear only press next key (lower right arrow)
The display should say line 002: appear & ring
repeat the procedure the same as line 001 for the remaining ringing lines
press the release key when finished
Posted on Jan 12, 2010
Remove the ringing from incoming calls on a norstar. I have multiple extensions in the building but want the incoming calls only to ring to a few extensions
You need administrative rights to get into the PBX. Once in there, you can assign which phones receive incoming calls. It has been years since I worked on the meridian system, so I can't tell you the way to do it, but it is in the manual. It's not complicated. You can also set it up for DAY/NIGHT mode so that in the evening, if required, all phones could ring on incoming calls so that anyone in the building can answer them.
Feb 04, 2015 | NorStar Meridian M7310 Phone
Phone does not ring
Time to get new phones. You incoming wires are not operating on the base of the phone. It is called the 'ring-side' or 'red' wire. Unless you know where the break is, you cannot fix it. because it happens on all the phones....it has to be broken in the base that serves them all. This isolation is furthered by the fact that a corded phone works fine on incoming calls, so it is not in the line to the building, broken on the ring side that is. Happy phone hunting!
blkqueentech
Apr 05, 2014 | Panasonic KX TG6511 Cordless Phone
My Norstar Phone Won't Let Me Pick Up Incoming Calls
Make sure they are Line Buttons, do FEATURE * 0 then press buttons to see what they are/do
Or maybe the key pad inside has failed.
Mar 04, 2013 | NorStar Lands Phones
Nokia 2730 - not getting ring tone with some incoming calls. Message left that I have missed a call
If you are facing the problem with some incoming calls it is an indication that you have set different ring tones for different users or incoming calls.
Very simply reset your mobile to a default setting by going to setting, restore factory setting and every thing shall be back to normal.
Oct 24, 2012 | Nokia 2730 Cell Phone
I can call out on my cell phone..BUT it won't ring
The ring signal may be turned off and incoming calls go directly to voicemail
Sep 12, 2012 | Samsung Cell Phones
The ringing tone just stopped - it won't ring with an incoming call. All settings are correct - and volume is set at the highest
try to assign a different ringtone (if it works its not a problem with the phone its with ringtone itself that you are currently using)
Aug 27, 2011 | Nokia 6300 Cellular Phone
My nokia 6030 doesn't always ring to announce an incoming call. More and more frequently, all I hear is a single tone. How can I fix this so it rings with every call?
Change you profile to Normal (so it will ring)
> try customizing your profile by going to:
Menu> Settings> Profile> Normal > personalize> ring tone > ringning.
Sep 01, 2010 | Nokia 6030 Cellular Phone
Intermittently my iPhone does not ring and incoming calls get forwarded.
Through the iPhone to dustbin and buy a normal phone. It works better than this iphone. This happens to a lot of people.
Jul 14, 2008 | Apple iPhone Smartphone
Model 28112ee2-4 dect 6.0
For the handset, you can use the menu button to check the HS Setup settings. For the answering machine, you may have pressed the side button that turns it off. It would say "off" on the lcd if you did that. According to the manual (I just bought one of these).
Dec 21, 2007 | Uniden Cordless Phone
Panasonic KX-TGA560 Cordless Expansion Handset Logo
167 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
