Question about Lenovo Thinkpad T60 Notebook
How to put extra memory in Lenovo T60 laptop
I check the back side of Lenovo T60 laptop, but still can not find where I can pull out the cover and put more memory in it. Would you please find the solution for me? Many thanks
  • shell174 Sep 26, 2008
    i have a lenovo r60 and i would like to upload pictures from my camera memory card but cannot find where to insert it
  • Anonymous May 21, 2009
Ok the RAM location is actually underneath the touch pad on the top of your keyboard. However, to get to the memory area where you can add/remove RAM cards you need to do the following:
STEP 1) On the botton the latop you should see 4 screws that have a "memory chip" ICON. These are the 4 screws you want to take out. (important note: my T60 has 4 screws with this icon, yours might have 5). Please the screws somewhere secure so they are not lost.
STEP 2) After you take out the screws noted in step 1. Flip your laptop and open it up as if you were going to type something.
On each side just below the keys pull up gently and the botton portion that has the touch pad will come up. You want to pull it back towards you. You won't be able to complete remove it away from the laptop, because there's a ribbon cable connecting the touch pad. So just move the piece back toward you out of the way (in essence peeling it back toward you).
STEP 3) You should now see the RAM card(s) they will have a bracket mechanism on each side of the RAM card, push them outward to unlock the RAM card (if your removing.
STEP 4) If your ADDING RAM. Evaluate if you need to remove existing cards or not. To install RAM you insert the new card in the slot, then push it down and it should snap int place.
STEP 5) Place the touch pad plate back into position and push it to snap down.
STEP 5) Close laptop cover, flip over and insert the screws back into their positions.
Posted on Jul 26, 2008
    Genius:
  • 1,847 Answers
On the bottom of the laptop you will find the compartment for the memory.
Posted on Jun 17, 2008
Bios password lenovo T60
there are 2 ways to attempt it. 1/ you need the diagram of your mother board as it involves changing a jumper setting on the board to clear the pass. 2/there is a small round battery inside ( could be under a cover under the laptop ) unplug that battery for a while to clear the cmos. hope this helps
May 01, 2015 | IBM Lenovo ThinkPad T60
Where can I find lenovo t60 good video driver?
Here they are:
http://support.lenovo.com/us/en/products/laptops-and-netbooks/thinkpad-t-series-laptops/thinkpad-t60
May 04, 2014 | IBM ThinkPad T60 Notebook
My Lenovo Thinkpad T60 Won't load pass thinkpad Logo. I can't access Bios and ThinkVantage button is useless PLEASE HELP!
A burning smell is a good indication that some component burnt up. Could be a fan and that would cause it to shut down. If it's hung on the logo I would start by removing the memory, hard drive and optical drive and see if it boots past the logo. If it does then power down and add one item back in and test again until you find the bad part. Can you hear the fan spinning when you power it on?
Dec 02, 2012 | IBM Lenovo ThinkPad T60
Added a ST95005620AS in Lenovo (2503) docking station as a second drive and it is causing a slow boot in Lenovo T60
Very strange, I added a WD 500GB in place of my CD drive in my R60 and have had no issues. I suggest the following:
1. Pull the Seagate drive from the docking station, does the laptop boot faster (confirm the added drive is really the problem).
2. Put the drive caddy back in with a drive with one of another brand other than the Seagate, see if the performance imorives (confirm its the Seagate which is the problem and not the caddy or docking station).
If performance increases in both cases, do some research on compatibility issues between the IBM and Seagate drives. I would also go to Lenovo's website and update the laptop BIOS... this can easily be accomplished by downloading a tool and doing it through Windows. I had issues with using a non-Lenovo battery with my R60 till I updated the BIOS. Good luck, let me know if you get to the bottom of this. Please rate me if this helps you. Thanks.
Jan 04, 2012 | IBM Lenovo ThinkPad T60
I forget my Laptop Startup password of IBM T60.
For IBM/Lenovo Password
there is solution for all IBM/Lenovo laptop
check this site... http://ja.axxs.net. u need to buy this device Key maker pro...
OR
there is one more way to break password for many laptop ..u need to make com port or printer port and there is software for it ...
check this site http://www.lancos.com/prog.html
Thanks
Jan 17, 2010 | IBM Lenovo ThinkPad T60
How can disable password lenovo t60
Is it a boot login or a Windows login?
Jul 02, 2009 | Lenovo Thinkpad T60 Notebook
My Lenovo T60 will not boot up
ok...and these beeps..do they happen before screen shows anything?
Nov 21, 2008 | Lenovo Thinkpad T60 Notebook
Back-up on Laptop
Hi there, please at first delete some old backups and then search Lenovo support for the fix to avoid wasting space using backup.
Regards from germany,
Dieter
May 22, 2008 | Lenovo Thinkpad T60 Notebook
Lenovo Thinkpad T60 Notebook Logo
2,952 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
