Question about HP Photosmart C6180 All-In-One InkJet Printer
Grey background in all pictures
Started out with beautiful pics. Now, all pics print with a (Grey) background. I changed all inks and paper, still (Grey). I tried a different machine to print pics, all pics are GREAT. I even took pic card to different location and all prints are good. Not sure what to do next. All other print projects still work fine and look good.
Any input is welcomed.
Thanks so much.
  • 426 Answers
Your printer is set to print in Gray Scale under the settings tab, take it off GrayScale, :) its a common mistake
Posted on Jun 17, 2008
My sahara Flatbed Scanner works fine except that I cannot find how to print without a "grey:" background. What should I do to print with a clear white background? Eric Schafer. Cape Town RSA.
you will find if you reduce the dpi the scanner is scanning the pictures or documents in, that you will not get a grey background , as you describe, what it is printing is actually the paper itself, if you have it set for say 1200 dpi then reduce it to 600 dpi or even 300 dpi and you will see the difference when you print it
or only select the exact area you want to scan in the document, click preview then move the scan area selection box to exactly fit the picture you want to scan
Mar 27, 2011 | Office Equipment & Supplies
Printing black on paper
Some of these machines will allow you to printe a grey scale test copy.
This will readjust the fax machine back to a nominal mode.
Not knowing how old or how long the machine has been serviced, background can be caused by dirty optics somewhere in the machine.
A remanufactured drum unit can cause this type of problem, (defective unit)
Competitive toner in the toner unit can cause poor copy quality.
Reinstall the old cartrige and see if the problem changes.
Not knowing if the machine has a seperate drum unit and developer housing, it would be hard to answer anything else.
Oct 15, 2009 | Brother IntelliFAX 4100 Laser Fax
Printing grayscale
in MS office you change pictures 's colour and print them in garyscale go to picture tool bar and change its colour and in printing prefrence from printer properties change dpi setting to save ink
Aug 09, 2009 | Dell 810 All-In-One InkJet Printer
My HP C4480 all in one printer is working fine accept when I try to print things, the first half of the page is fab however the second half looks like the colours are running out. The ink is new and it...
check the page setup and verify that the paper type is A4 also check the margins of ur paper which u want to print it by check it on print preview before printing
Jun 08, 2009 | HP Photosmart C4480 All-In-One InkJet...
Smudged Printing
replace the toner. many remanufactured cartridges will do this due to leaks during/after refill.
Nov 07, 2008 | HP LaserJet 4 plus Printer
Grey background over entire page.
If toner is getting onto the transfer belt, it can only get there by either being put there intentionally, or leaking.
Failure of Transfer Belt is normally degraded print quality - usually poor density, or a failure of the support behind the belt (usually puncturing the belt), and scoring a drum.
Sep 15, 2008 | HP Color LaserJet 2600n Printer
New printer cartridge in Lexmark 8350; blue lines on pics and papers
In Lexmark printers the ink cartridges can get clogged sometimes. Re-cleaning the nozzles might help fix your problem. Make sure your ink cartridge is not getting empty.
Hope this helps.
Jul 29, 2008 | Lexmark X6170 All-In-One InkJet Printer
HP Laser Jet 4L Printer Model #C2003
Try lowering the toner density using the printing software or the printer menu.
Feb 03, 2008 | HP LaserJet 4L Printer
Ink won't dry
Unless the problem coincides with a change in ink cartridge, my guess is an incompatibility between the ink and the paper. Could you have changed the paper you're printing on. If so, is the new paper of a different quality? If you're using coated (eg photo) paper, are you printing on the right side? Check the "paper quality" setting on the printer (or the software you're using to drive it) - it needs to match the specification of the stuff you're printing onto. Photo quality papers are capable of absorbing much more ink than plain paper (which is how you get the colour intensity). If the printer thinks it's using photo paper, it will throw out enough ink to get that colour build - leaving a sticky mess if what is really loaded is just plain paper. A.
Apr 28, 2007 | Canon i860 InkJet Photo Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
152 people viewed this question
Ben Johnson
