Question about Acer AL2017 20" LCD Monitor
Hello I see noting one my screen the lichgt is on i see only black monitor sorry engische is not good am from the netherslands
  • 11,361 Answers
Check the fuse and the transistors as shown in my pictures here:
http://s807.photobucket.com/albums/yy352/budm/ACER%20AL2017%20Abd/
Also check the caps.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, capacitors, and lamps pictures: http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Nov 10, 2010
Acer monitor screen showing partial screen only. rest of screen showing black & white dots.
Hello there.
Try the monitor with ANOTHER computer,
This will prove whether it is the Monitor at fault or not.
Sep 25, 2014 | Computers & Internet
Apparently takes pictures ... but black out the screen .... if you turn on and everything but can not see anything ... Sorry about my English
I see nothing on the monitor screen when I want to capture a picture. The screen monitor remaind black but I can capture new pictures. when I press the play button, I can't see the picture. When I retreive the picture from the camera to a computer, I realize the picture is black and I can't distinguish anything.
But when I introduce the good picture from my computer to the Digital Camera, from the Sceen Monitor, I can visualize only the good picture I introduce in mysefl.
The flash is working properly, the on/Off button is ok, the lens appear to be normal.
My Digital Camera is Casio EX-S880 EXILIM
Jan 29, 2010 | Casio Exilim EX-S880 Digital Camera
Monitor receiving signal, but no image
Hello!
I see many monitor with that trouble.
When you turn on comp., you can have a picture on monitor about 10-30 min. and that go in black screen, or If you change resolution again go in black screen.
You must repair monitor or bay another.
Nov 02, 2009 | Acer AL2416W Monitor
My LG Flatron L1717S wen I power up it flashes good for 2 sec
are you getting a check signal cable message? any on screen instructions?
try the cable, if it works on another monitor, then sorry to say but your monitor is fried
Sep 01, 2009 | LG Flatron L1750S 17" LCD Monitor
Screen is black and power button is blinking
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Aug 06, 2009 | Samsung SyncMaster 204B (Silver, Black)...
With my hpvs17e power goes on then a black screen why does that
Buddy
Corporate Computer
www.ccl-la.com
Jul 21, 2009 | HP Vs17 17" LCD Flat Panel Monitor
Screen is black
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
Buddy
Corporate Computer
www.ccl-la.com
Jun 30, 2009 | Samsung SyncMaster 175V 17" LCD Monitor
Syncmaster 226bw goes black
If you can still faintly see data on your screen, it will be a faulty backlight in the panel most likely.
LCD panels have fluorescent tubes in them that provide the light needed to see the data. If one of these goes faulty, the circuit that drives it will turn off ALL the backlights, giving you a black screen.
Note: a faulty circuit that drives the backlights will often give the same apparent fault.
You will need to take the monitor in for repair.
Jun 23, 2008 | Samsung SyncMaster 214T 21.3" LCD Monitor
Green instead of black
According to what you both have described in your scenarios, I am sorry to say that your monitors are going bad. When you take a known good monitor and plug it into your computer systems and everything is working normally, it is not your graphics card. If your graphics card was going bad it would not matter what monitor you connected your system to, the results would be the same. You can try adjusting your color and tint, vertical and horizontal if you would like, but I doubt it would make any difference. You both need to replace your monitors. It is not really worth fixing unless you have an lcd monitor or something expensive, but this is not the case. I am sorry to give you the bad news. I hope this has helped you in some way. You can see this exact same scenario in my tip, under my profile.
If you would not mind, would you please rate my help. I would really appreciate it.
Apr 27, 2008 | Acer AL1912 19" LCD Monitor
Acer AL2017 20" LCD Monitor Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
