Laptop help Hi there. My laptop seems to have some booting up issues. When I press the power button, the power LED lights up, but the pc does not boot up and nothing is displayed on the screen. Other times, the pc does boot up but freezes and crashes. The times that it does boot up, it freezes/crashes during the booting process, and even while idle'ing after booting up. Any suggestions? The laptop is a Sony Vaio VGNS150.
  • BigMac Sep 05, 2008
    When I press the power button, the power LED lights up, but the pc does not boot up and nothing is displayed on the screen. Toshiba Satellite 1415.
    Genius:
  • 1,847 Answers
For free sony support go the link choose the produce and chat for free
http://esupport.sony.com/US/perl/support-contacts.pl
Thanks for using fixya. Hope this solution may have helped you.
Posted on Jun 17, 2008
My Asus X553M laptop is not booting up. Any ideas how to fix this problem?
Temitope, Hard reset. Open computer, remove battery,hold power button down (((1 minute))), reinsert battery, reassemble laptop, push/hold power button a couple seconds.
2nd fix, try to boot laptop without hdd.(hard drive). Remove the hdd, then turn on the laptop.. then it can get into the bios.. reset the bios to the default setting, turn off the laptop, and then turn it on again with hdd reinstalled. This seems to be what works in the forums with this issue found in Asus laptops. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Asus Laptop unable to boot black screen no bios
How to Fix Laptop that Won Turn On Asus X551M
Laptop Won Turn on Fix How to Hard Reset Laptop
Asus laptop not booting
Aug 21, 2016 | ASUS Computers & Internet
Toshiba Laptop will not boot
Either the battery is dead or the power supply is damaged.
Mar 19, 2014 | Toshiba Satellite L875ds7332 Notebook...
Laptop problem
If the fan runs and you see lights that's a good thing. It means the laptop is getting power and trying to boot. Now do you hear the hard drive turning? When you press the Power Button do you hear the CD drive click once and notice that the light on the cd drive door turns on for a second or two? These are all good signs of the laptop trying to boot. When you press the power button did you hear any beeps or notice that the lights blink continuously such as 1 long beep and 2 short beeps. The lights and blinks tells the technician what is wrong. When you press the power button do you see anything on the LCD Screen as it goes thru the boot process?
Try removing the battery and the power cord from the laptop. Then press and hold the power button for 30 seconds. After 30 seconds, plug only the power cord in and press the power button to reboot. If it boots that means you had a static buildup which is normal in computers. By hold the power button you released the static. If it boots you can put the battery back in. If it does not boot and if the lights are blinking or you hear beeps you might have a bad memory chip. Unplug the laptop and turn it over to remove the screws tht house the memory chips. Remove one of the memory chips and set it aside. Now try to boot your laptop. If it does not boot, move the memory chip to the other slot and try rebooting. If it boots place an x on the memory chip that you have set aside. If it does not boot remove that chip and put the memory chip you have set aside in the laptop and repeat the process of moving in into each memory slot and trying to boot. If you get it to boot with one memory chip, place the other chip in the available slot (make sure it has an x mark on it so that you will know which one might be bad), then try rebooting. If it fails, that chip is bad. If it does not boot for either chip then more than likely you have a motherboard issue.
Mar 20, 2012 | Compaq Computers & Internet
NO Display in my laptop
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Jan 20, 2012 | HP Computers & Internet
I have an intermittent power-on issue with my Dell E4200. Sometimes it is very hard to turn on - pressing the power button makes the button light up, the fan runs for a few seconds, then the caps lock icon...
Try performing a hard reset on the laptop. Remove the battery and all peripherals connected to the laptop (including the AC adapter). Once everything is removed/disconnected, press and hold the power button for around 15 seconds. This will drain all remaining charge in the motherboards capacitors which usually causes this kind of issue.
Hope this help. Goodluck!
Mar 28, 2011 | Dell Latitude E4200 Notebook
Laptop won't switch on although blue power light on is showing power is getting to the machine
Check the power adaptor led is not flashing. Flashing Adaptor LED indicates fault with laptop charging circuit / powerboard
If it will not boot on battery, and you know the adaptor to be good, the issue lies with the motherboard.
Sometimes, removing the battery, and unplugging, pressing the power button and holding it for 30 secs, replacing the adaptor only will allow it to boot up, but this will only work if the motherboard is not damaged r the CPU fan has not failed.
Jan 27, 2011 | Toshiba Satellite P200-13Z Laptop AC Power...
My HP dv4 1120us laptop will not power on. When I insert the power cord the led for power bolt comes on and when I press the power button the power LED flashes once and then nothing happens. The power bolt...
Sounds light a power switch short, but lets try to take the memory out of the laptop and power on the laptop. Does it boot up? if so lets try 1 memory stick at a time.
Nov 29, 2010 | HP Pavilion dv4-1120us Notebook
The power button LED will lights on but the laptop is not boot-up,no power at all ,only the power button led remains lit.
Hi!
Press the power button for 4 seconds, until the laptop powers off, then press again (shortly) to power up...
Good luck,
Pelu.
Aug 18, 2010 | Computers & Internet
My Dell Vostro 1310 won't turn on. I get a black screen (well actually, a bit of colors are coming, but nothing else ...). Tried again and again to turn on, seems to be a problem with the video card....
check for led lights if they come on.
note down the lights.
If you are able to remove the connection of the lcd to the laptop do so for instruction refer to www.dellsupport.com click on manal
Oct 05, 2009 | Dell Vostro 1310 Laptop Computer PC...
Black screen will not boot up
try removing the battery and just run off power cord this may be a bad battery seen it before
Apr 15, 2009 | ASUS Eee PC 1000H Laptop
Computers & Internet Logo
230 people viewed this question
David Payne
David Payne
