Question about Kenmore 24032\24036 Top Load Washer
Cycle stops... My Kenmore Elite Top Loader just stops running once it fills with water. I have to slam the lid and then it starts. Sometimes it stops midway through the cycle and i have to slam the lid again to get it start again.
  • 426 Answers
Replace the lid switch, or check the connections it might even be your pusing rod for activating the switch
Posted on Jun 17, 2008
Kenmore top loader mod. 110 29522801 does not run after filling with water. The lid switch could be bad. Are there other problems that should be addressed?
if the unit is filling with water it is not the lid switch because it will not fill with water if the lid is open
problem areas are the water level switch is not energizing the wash cycle as well as switching off the incoming water
if it is stopping the water but nothing else , have a technician check the program board
Jan 13, 2017 | Kenmore Washing Machines
I have a top loader washing machine with a filling problem. don't think its hoses or valves I think its electrical in the control panel. after the machine filled, I opened the lid to switch the water
most washers will stop what ever there doing (filling) if you open the lid this is a std safety feature . and sometimes this same switch malfunctions and gives a false indication of a door open
Feb 10, 2015 | Kenmore Washing Machines
Fills with water then won't go to the wash cycle until you slam the lid several times
It sounds like the lid switch is faulty. The washer has a lid switch that checks to see if the lid is open, if lid is open the washer will not start the wash cycle. Check/replace the lid switch and you should be back in business.
Oct 04, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
My Kenmore washer 26 26962 MO 110 26962503 will start the cycle..
It sounds like it is your water level control. Here is a link to the Kenmore site which has your manual use these numbers ( Kenmore washer 26 26962 ) for your model unless asked for more Kenmore Manuals
Oct 09, 2009 | Kenmore 26882 Top Load Washer
Kenmore Elite Washer 110.24992300 spin problems
The pressure switch is mis-reporting the water level to the ECU.
Test/replace the pressure switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 29, 2009 | Kenmore 24032\24036 Top Load Washer
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Cycle won't start
the lid is not making proper contact with the lid switch, easy repair.
the lid is held to the maintop with a set of hinges. The left side hinge actually doubles as the lid switch actuator. so youll need to lift the lid, and feel for the opposite end of the hinge assy. when you feel the metal "arm " for lack of better word. youll need to bend it slightly towards the back of machine( usually use a hollow shafted screwdriver) as you bend backward the lid will want to close, so apply a little pressure. Your bending the "arm" to make better contact with the switch which ismounted tothe underside of the main top assembly. Before starting open and close the lid a few times and listen for the "click" of the switch activating. then recheck after bending youll hear a big diff
Nov 28, 2008 | Kenmore Elite 45986 Front Load Washer
Washer filled with water & then stopped & will not work in any cycle.
could be a bad pressure switch did it fill all the way is it a top loader or front loader any noise or nothing
Dec 31, 2007 | Kenmore 24622 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
270 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
