Our Canon C5051i imagerunner advance had a problem with the finishing unit. There was an option to retart with 'Function limitations', which I opted for. Now I cannot find how you turn the limitations off?
checkitright
  • 1362 Answers
SOURCE: Printing on Imagerunner 210s
depends on which additional function you are trying to do.
You have it as a copier only right now, you can add
duplexer for two sided copies
network for your computer to fax and print and scan
document feeder to put copies on top and feed automatically
There are a lot of options you need to decide which function you are willing to pay for.
Good luck
Posted on Dec 04, 2007
  • 168 Answers
SOURCE: Canon ImageRunner Scan feature won't connect to network
its waiting for the command from the computer. in order to use scan you have to down load the canon scan tool from imagerunner.com / support/ downloads/ office products/ then canon network utilities. look for network scan gear tool ... down load save open run setup then open the program and you can either let it search for a scanner or you can put in the IP adress for the copier. then under your scanning software ( ADOBE PRO) eg. you selesct the scan gear tool as the scanner. to scan a doc you put paper in feeder select scan online then from your computer tell your software to scan good luck
Posted on Jan 03, 2009
idriss47
  • 26 Answers
SOURCE: e000 error message on canon imagerunner 2000 copier
Hello.
E000 means :
"The main thermistor reading does not reach 40oC 14 sec after the fixing heater goes ON (fixing low temperature error)"
Posted on Jan 20, 2009
  • 168 Answers
SOURCE: Canon Imagerunner 7200 At the bottom of the
touch the add func key then common settings scroll till you see limited functions mode touch it then turn limited function to off then turn copier off then on
Posted on Nov 20, 2009
Elbastardo
  • 21 Answers
SOURCE: My Canon ImageRunner gives me a message of
Buy the optinal equipement which can be a fax card or a universal send kit
Posted on Sep 14, 2010
How to Hard Reset Canon iR6000
press aditional function ,then 17+39 ( 1and 7 same time , 3 and 9 same time) again additional function .and select 95 th option in display (e355 and all ram clear ) press 2 and enter ..within few minitus mechine restart if restartting time just swich of mechine manually and on
Dec 14, 2013 | Canon imageRUNNER 6000 Copier
I want canon ir 3300machine price
in EU from 800 EUR with limited option's to 1000-1500EUR in good condition with full otions ( fax, finisher, send, ... )
Aug 02, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
Canon Imagerunner 7200 At the bottom of the screen it says "Finisher Can Not Be Used" Also says "Ready to Copy (Function Limited)"
Nov 18, 2009 | Canon imageRUNNER 7200 Copier
Finisher setting will not work
touch the additional functions key then touch custom settings scrolll till you find limited function mode touch it then turn limited function off turn copier off then on this should turn the finisher back on unless the finisher has an error
Sep 25, 2009 | Canon imageRUNNER 5000 Copier
Canon IR 7095
if you can not use the finisher and the machine says Functions limited
press additional function
press common settings and then scroll to find limited functions mode if its on press the off button press ok and turn off the machine and then back on
Jul 28, 2009 | Canon imageRUNNER 3570 Copier
We have a Canon ImageRunner 8500 and we get this error code E000542 0003. How do we fix it?
In this case the finisher motor or motor sensor does not work properly. AS SM Main cause - The tray B lift motor (M12) is faulty. The tray B idle rotation sensor (PI18) is faulty. The tray B lower limit sensor (PI24) is faulty. The tray B paper sensor (PI17) is faulty. Main cause The tray B lift motor (M12) is faulty. The tray B idle rotation sensor (PI18) is faulty. The tray B lower limit sensor (PI24) is faulty. The tray B paper sensor (PI17) is faulty. Try operating copier without finisher or contact an technician to repair finisher.
Jun 10, 2009 | Canon imageRUNNER 8500 Copier
Does canon imagerunner 2010f have a scanner function?
Some may have the feature. The unit would have a SCAN button or option clearly visible on the front panel.
This method of scanning would be pull scanning and would work with TWAIN compatible software.
You cannot get Universal Send on this unit.
Mar 30, 2009 | Canon imageRUNNER 2010F All-In-One Printer
ImageRunner 6570 Stuck on limited functions
Press the "Additional Functions" button on the control panel. Press the "copier settings" button. Then scroll through the screens to the fourth or fifth screen (I forget which but you'll find it) and you will see "limited functions" "on" and "off". Press "off", then turn the copier off and then turn it back on again. Your finisher should work now.
Jul 29, 2008 | Canon IMAGERUNNER 6570 Copier
k24674
